Equating Ports to Data Bits
Results 1 to 7 of 7
    Osiris's Avatar
    Osiris Guest
    Question Equating Ports to Data Bits
    Hi There,
    I'm to this forum so I'd first like to say hi to all you people out there. My question seems rather trivial but I can't seem to figure it out. Basically I have a 16 bit bus which is scattered through PortA, B, and C on an 16F877A. I would like to define the 16 bit data and have each bit of the data automatically associated with the PortX.Y like so
    BUS_DATA var word
    BUS_DATA.0 = PortA.0
    ..etc
    The problem is that I can't get it to work and had to do the following routine:
    If BUS_DATA=1 then
    PortA.0 = 1
    Else
    PortA.0 = 0
    Endif
    ...etc
    This is rather lengthy and eats lots of space. I've done it before were I define a byte like MY_INFO var PortE.0 but that's an entity on it's own. I can't seem to associate data bits with port bits.
    Can anybody help me out?
    Many thanks,
    Osiris
    Feb 2005
    Kolkata-India
    Cool Two ways as far as I know
    Hi there,
    If you have a variable say "PORTDATA" then it could be like this
    PORTA.1 = PORTDATA.0
    PORTB.1 = PORTDATA.15
    and so on. Or you can create bit alliases like
    PORTA.1 VAR PORTDATA.7
    and so on.
    Sougata
    Osiris's Avatar
    Osiris Guest
    Hi Sougata,
    Thanks for the tips. I tried them today and they do not seem to work for me. I know they should because it seems logical that they should work but somehow it's not working.
    The first idea: PortA.1 = Data.0 compiled without error, the second one gave me lots of errors "redefinition of VAR".
    It's strange but there must be a simple way to do this.
    Many thanks,
    Osiris
    Feb 2005
    Kolkata-India
    Question Can you post your entire code.
    I would like to see the entire code and find out whats going on. Sometimes "typos" are hard to find.
    Sougata
    Re the second example...
    A Variable is a Variable, and a Port is a Port. You CAN'T define one as another which is why the second example is illegal. You CAN make a Port equal the state of a Variable, or you can make a Variable equal the state of a Port.
    Going back to your problem... if you have arranged your 16-bit BUS illogically and without thought scattering it randomly across many Port Pins, then you can only gather it together with (worst case) sixteen individual statements like so...
    Myword.0=PortA.3
    Myword.1=PortB.7
    Myword.2=PortB.3
    Myword.3=PortB.5
    Myword.4=PortA.0
    Myword.5=PortC.4
    and so on...
    The best scenario was you had your 16-bit bus arriving sensibly at two PIC Ports and you caould have gathered it like so...
    Myword.Lowbyte=PortB
    Myword.Highbyte=PortC
    You can of course redefine the name 'Myword', and you can redefine the Port names, but you CANNOT automatically associate a physical lump of Hardware (ie a Port pin) to a virtual object (ie a RAM variable).
    Osiris's Avatar
    Osiris Guest
    Hi Melanie,
    Thanks for the explanation. Indeed I had no choice but to scatter my bus around because some of my port bits are for dedicated hardware and since the pins have special features (like hardware interrupt, HUART, HPWM, etc) I had no choice but to scatter them about.
    My worry is that I did try the following:
    Myword Var word
    Myword.0=PortA.3
    Myword.1=PortB.7
    Myword.15=PortC.4
    But when I write the following statement it does not transfer the configuration to the port:
    newdata var word
    Newdata = 1234
    Myword = Newdata
    I would assume it would transfer the bit pattering from "newdata" to "myword" which would then output the bits on the associated ports.
    It seems too simple of a problem and at the back of my head I have a feeling that I'm missing something very fundamental which does not allow the program to work.
    Many thanks,
    Osiris
  1. Using Nokia LCD
    By BobP in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2018, 05:47
  2. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  3. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  4. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
  5. Sinus calculating !
    By Don Mario in forum mel PIC BASIC Pro
    Last Post: - 29th November 2004, 00:56
