On the PC-Side you can send your Byte in Text, wich will send 3 bytes 1,2,7 OR simply send the decimal Value 127, or.. or.. or...
ON the PIC Side, depending the way you sent the data on the PC side, you may need to use Serial qualifier like DEC or else
PBP manual in SERIN2 section for detailed explanation.
And if you search just a little bit on this forum, you may found 1-2 threads about serial communication.
