LCD with T6963C controller
Results 1 to 10 of 10
    Default LCD with T6963C controller
    I bought this LCD from EBay:
    http://cgi.ebay.ca/ws/eBayISAPI.dll?...tem=7590673939.
    WM-G2406D (ver. 2) is written on the back of the PCB. The only datasheet I have is here:
    http://zing.com.tw/WINTEK/wm-g2406de.htm
    I'm uncertain as to how to wire the V0 and VEE pins. I've found an unrelated schematic that connects them to ground with a potentiometer here:
    http://liquid-mp3.schijf.org/schemat...n_DG-24128.gif
    But I have doubts and would appreciate confirmation.
    I downloaded a PIC Basic Pro program to test my LCD from here:
    http://www.compsys1.com/support/PBP_Files/t6963c/
    File name: glipict2.bas
    I know the author of the program used a Toshiba LCD, but that should only affect the pinout on the LCD. What matters is that both use a T6963C controller and is of the same dimension as the Wintek (240x64).
    I am using a PIC 16F877 at 20MHz just like in the program, but nothing happens, blank screen with nice green backlight. I've wired the LCD as the datasheet recommends and I've double-checked the pins on the PIC. I'm at a loss to explain what I'm doing wrong. I know the pic works properly 'cause I've added some switches and LEDs and that works fine.
    Sorry for the long post, I tried to put in as much information as possible. I'm guessing that it has to do with the wiring of the LCD. The EBay seller said it only required 5V DC, but I'm wondering if he has his facts straight. The datasheet says model "D" has a single power supply, that would lead me to believe I need a 2nd one to power the LCD. Another thing that sticks out in the datasheet is the Supply Voltage for LCD: VDD-V0 = 12V typical.
    I just don't have enough knowledge and experience to link all the dots.
    have a look there
    http://www.geocities.com/researchtri...glcd_page.html
    be sure your supply is clean and un-noisy. Some GLCDs seems to be noise sensitive. Worst if the cable length between your Board and your LCD is a little bit long. Pace some 10uF tantalum+0.1 uF as close as you can of your GLCD supply lines.
    Should work... or you're another eBay victim LMAO!!!
    Oh here's a great source for about everything... www.epanorama.net
    The LCD still had the original protective film over the display, the contacts are unused and it is dust free. I'm pretty sure the claim of it being 'new' is true, I must be screwing up something.
    Thanks for the links, gonna check them out.
    Well, I got it working thanks to the folks who posted code over at CompSys.
    I was able to print, now if I can just figure out how to get a SED1335 gLCD going.
    Red face T6963c
    thinking about buying one of these any updates on this thread?
    Default Re: LCD with T6963C controller
    15 years passed since last post
    I ordered ST7920, but seller sent these instead by mistake. 240x64 resolution. They're on the way, and I'll give them a try once they arrive.
    But what I've curious about, documentation mentions built-in fonts, but sample code posted above seems to load own characters, why?
    The built in fonts are 6x8 or 8x8 pixels. So they are very small. Most users want different size fonts. The compsys1 pbp code works
    http://www.compsys1.com/workbench/On...3C/t6963c.html
    http://www.compsys1.com/support/gli2/
    Well, common HD44780 based displays have 5x7 font, but no one complains...
    Anyways, let them arrive and let me see, what they can do
    The pixels are smaller than on a charactor display.
    In the text mode you can get 8 lines by 30 charactors with a 240x64 display.
    Do you have a datasheet for the displays you are getting?
    Hopefully your displays have the built in negative voltage source for the contrast.
    Well as seller stated, they only need 5V for operation, no separate negative supply needed. It also has contrast adjustment pot soldered on it.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 11:43
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 14:44
