send data from VB 6 to PIC 16f84
Results 1 to 3 of 3
    win_832001's Avatar
    win_832001 Guest
    Default send data from VB 6 to PIC 16f84
    need help here...
    ive try to turn 'on' the LED through PIC 16f84
    can one help me:
    VB6 code :
    Private Sub Form_Load()
    ' Use COM1
    MSComm1.CommPort = 1
    ' 2400 baud, no parity, 8 data bits, 1 stop bit
    MSComm1.Settings = "2400,N,8,1"
    ' Disable DTR
    MSComm1.DTREnable = False
    ' Open the port
    MSComm1.PortOpen = True
    InputLen = 0
    RThreshold = 0
    End Sub
    MSComm1.Output = Chr$(255)
    End Sub
    from the coding the PIC shold receive the "255"
    and my PIC PRO Basic coding :
    INCLUDE "modedefs.bas" ' Include serial modes
    si VAR PORTA.4 ' Set portA.0 as our serial input pin
    loop VAR BYTE ' Define our storage location for the servo number to move.
    start:
    SerIn si,T2400,["255"],loop' Get the servo# and position for that servo.
    IF loop Then led
    led:
    High PORTB.4
    Pause 5000
    GoTo start
    can anyone help me to solve the problem...i really need help..thank you
    Jul 2004
    CA
    Default VB - PIC Serial Communication
    I have successfully used the serial communication from the VB.NET 2003 (not VB6) and have the data be downloaded, onto a PIC. And it worked. I do not know how different VB6 is from VB.net. Here is the link I used, and I donwloaded the program onto my project and it worked perfectly. You may want to get yourself upgraded to VB.net.
    I changed this program around to fit my needs, I hope this helps.
    http://www.codeworks.it/net/VBNetRs232.htm
    Srig
    kadirozen's Avatar
    kadirozen Guest
    Smile this is your solution
    hi,
    if you change your code like this you will success
    start:
    IF loop = 255 Then
    Goto led
    GOTO start
    led:
    High PORTB.4
    Pause 5000
    GoTo start
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. DS2760 Thermocouple Kit from Parallax in PicBasicPro
    By seanharmon in forum mel PIC BASIC Pro
    Last Post: - 8th July 2008, 23:19
  3. PIC data sheets - not comprehensive for beginners
    Last Post: - 29th August 2006, 03:28
  4. send serial data to PIC 16f84 ausing VB6
    By win_832001 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 21:14
  5. how to send data from VB to PIC 16f84
    By win_832001 in forum Serial
    Last Post: - 25th February 2006, 16:15
