USBinit and USBservice
Results 1 to 6 of 6
    New Jersey
    Default USBinit and USBservice
    Why when I compile a program for an 18F4550 with MPASM and PBP, I keep getting an error that says "ERROR: Macro USBINIT? not found in macro file" and the same for USBSERVICE. Does anyone know how to solve this problem?
    Chris
    You have a number of support files that need to be in the same directory as
    the file you're compiling. If these files aren't in the same directory, you'll get
    this error.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    New Jersey
    Bruce,
    Can you elaborate? I understand what you are saying but I don't know what to look for.
    Chris
    Hi Chris,
    Look in USB.TXT in your USB18 directory.
    You can also download EasyHID from http://www.mecanique.co.uk/products/usb/easyhid.html
    It will create all the required files for you & place them all in one directory.
    -Bruce
    tech at rentron.com
    New Jersey
    I have those files but I still can't figure out why I am still getting this message. Any ideas?
    OK, but is the file you're trying to compile in the same sub directory as the
    USB support files?
    I can force this exact same error, but only if the file I'm compiling isn't in the
    same directory as the required USB include files.
    -Bruce
    tech at rentron.com
  1. PBPro error "Macro USBINIT? not found in macro file"
    By Bonxy in forum mel PIC BASIC Pro
    Last Post: - 4th October 2011, 10:06
  2. Easy HID Command -Response application
    By ptig185 in forum USB
    Last Post: - 22nd September 2010, 20:56
  3. Simple USB Comms Problem
    By awmt102 in forum mel PIC BASIC Pro
    Last Post: - 6th January 2010, 21:17
  4. Problem with enumeration and EasyHID
    By jizyjuice in forum USB
    Last Post: - 9th April 2007, 21:40
  5. PortA reset zero after USBINIT / Service ?
    By sirnoname in forum USB
    Last Post: - 1st December 2006, 16:37
