More I2C question with PBP
Results 1 to 4 of 4
    Qacer's Avatar
    Qacer Guest
    Question More I2C question with PBP
    Hello again kind folks,
    I am using a PIC12F675. My datapin is GP0. The clockpin is GP1. The I2C device that I want to use is characterized as a slave-transceiver. The datasheet states that its "IC address C0: 1100000." Looking through the PBP manual, it says I2CWRITE DataPin,ClockPin,Control, {Address,}, Value, Label.
    I am not quite sure what to put down in the Control option. I do not see any references to the Control option in the datasheet.
    Also, if I want to read data from the I2C device, do I need to set TRISIO and GPIO to inputs before invoking the I2CREAD routine?
    Another thing, the I2C datasheet does not state any pause between writing, so am I right to assume that I can just send multiple bytes in one I2CWRITE statement?
    Thanks again!
    Hangover, Germany
    Talking
    Quote Originally Posted by Qacer
    Use the adress of the slave-device as control.
    No.
    Yes. It depends on your slave-device what does happen....
    PBP 2.50C, MCS+ 3.0.0.5, MPLAB 8, MPASM 5.14, ASIX Presto, PoScope, mE mikroBasic V7.2, PICKIT2
    France
    Thumbs up I2C ans PBP
    I had quite the same question
    I got nice answer from Super Melanie
    see
    http://www.picbasic.co.uk/forum/show...referrerid=745
    good luck
    francois
    Qacer's Avatar
    Qacer Guest
    Talking
    Thanks, all! :-)
  1. I2C Master/Slave 16F88/16F767 working code
    By DanPBP in forum Code Examples
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    By Michael Wakileh in forum Code Examples
    Last Post: - 16th June 2009, 22:07
  3. I2C Master Slave issues.
    By cpayne in forum mel PIC BASIC Pro
    Last Post: - 29th March 2008, 20:33
  4. i2c PBP questions
    By TimV in forum General
    Last Post: - 5th February 2007, 18:58
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 14:55
