send and receive data using pic 16f84a
Results 1 to 2 of 2
    johor,Malaysia
    Default send and receive data using pic 16f84a
    Need Help
    I write the serout and serin command to send data from PIC to another PIC
    can anyone tell me, how to solve it, thank you
    i am try many way to solve it , but still cant solve it
    i am using PIC16F84A model try a simple code below
    TX DATA
    INCLUDE "modedefs.bas"
    loop:
    IF PORTB.0=0 Then
    GoSub led_on
    Else
    GoSub led_off
    EndIF
    GoTo loop
    led_on:
    SerOut PORTB.1,N2400,[$FF,$FF,"OK","A"]
    led_off:
    SerOut PORTB.1,N2400,[$FF,$FF,"OK","B"]
    RX DATA
    dataon VAR BYTE
    led1 VAR PORTB.1
    led2 VAR PORTB.2
    Loop:
    SerIn PORTB.0,N2400,["OK"],dataon
    IF dataon="A" Then led_on
    IF dataon="B" Then led_off
    GoTo Loop
    led_on:
    High led1
    Low led2
    GoTo Loop
    led_off:
    Low led1
    High led2
    GoTo Loop
    after i on the supply and push the switch the led does not light
    to see the led light on/off how could be???
    really need a help
    thank you
    win_832001's Avatar
    win_832001 Guest
    Default Snang je
    Projek ko tu xyah la nak gune serin seout... buat mcm aku je. ko gune concept parallel. mcm kite baljo digit dlu tu... klu xblh tanye laban lah..!!
    -AiLiF-
  1. Send data PIC to PC
    By konter in forum Off Topic
    Last Post: - 25th December 2009, 22:04
  2. Send data to PC USB
    Last Post: - 18th December 2009, 21:57
  3. send data from VB 6 to PIC 16f84
    By win_832001 in forum Serial
    Last Post: - 9th March 2006, 14:21
  4. send and receive data using pic 16f84a
    By PoTeToJB in forum mel PIC BASIC Pro
    Last Post: - 28th February 2006, 20:12
  5. how to send data from VB to PIC 16f84
    Last Post: - 25th February 2006, 16:15
