send and receive data using pic 16f84a
Results 1 to 6 of 6
    johor,Malaysia
    Default send and receive data using pic 16f84a
    Need Help
    I write the serout and serin command to send data from PIC to another PIC
    can anyone tell me, how to solve it, thank you
    i am try many way to solve it , but still cant solve it
    i am using PIC16F84A model try a simple code below
    TX DATA
    INCLUDE "modedefs.bas"
    loop:
    IF PORTB.0=0 Then
    GoSub led_on
    Else
    GoSub led_off
    EndIF
    GoTo loop
    led_on:
    SerOut PORTB.1,N2400,[$FF,$FF,"OK","A"]
    led_off:
    SerOut PORTB.1,N2400,[$FF,$FF,"OK","B"]
    RX DATA
    dataon VAR BYTE
    led1 VAR PORTB.1
    led2 VAR PORTB.2
    Loop:
    SerIn PORTB.0,N2400,["OK"],dataon
    IF dataon="A" Then led_on
    IF dataon="B" Then led_off
    GoTo Loop
    led_on:
    High led1
    Low led2
    GoTo Loop
    led_off:
    Low led1
    High led2
    GoTo Loop
    after i on the supply and push the switch the led does not light
    to see the led light on/off how could be???
    really need a help
    thank you
    Hangover, Germany
    Unhappy
    Huuuhh...
    you fire a lot of charaters by the TX-PIC, and the RX-PIC has to do his work by software.
    Just give him some time to does his work.
    Read the PBP-manual around the SEROUT-command and look at the DEFINE CHAR_PACING !!!
    Change the filling bytes from $FF to $00, maybe the RX-PIC will find the start of a new character even better.
    PBP 2.50C, MCS+ 3.0.0.5, MPLAB 8, MPASM 5.14, ASIX Presto, PoScope, mE mikroBasic V7.2, PICKIT2
    johor,Malaysia
    thankQ BigWumpus .
    now i try to send variable data to the another PIC and display the data in LCD HD44780.
    can u help me
    Hangover, Germany
    Ahhmmm...
    You read the PBP-manual ?
    You have found SEROUT, what's about SEROUT2 ?
    johor,Malaysia
    i have read pic basic manual in melabs but still cant understand it..
    can u give me another source...
    I am an amateur is PIC and pic basic pro program..
    this is myprogramming code can u help me in solving my problem..
    DEFINE CHAR_PACING
    cnt var byte
    TrisB=%00000011
    cnt=0
    loop:
    IF PORTB.0=1 Then
    cnt=cnt+1
    if PORTB.1=1
    GoSub senddata
    EndIF
    GoTo loop
    senddata:
    SerOut PORTB.1,N2400,["OK",#cnt]
    RX DATA
    symbol second = 1000
    dataon VAR BYTE
    TrisB=%000000001
    Pause second
    lcd $FE,1,"READY"
    Loop:
    LcdOut $FE,#C0
    LcdOut "Count= ",#dataon
    GoTo Loop
    my problem is the display doesnt show the correct data that is send from PIC
    i use LCD HD44780
    Hangover, Germany
    Wink
    I think you want to transfer byte-values.
    Use
    SerOut PORTB.1,N2400,["OK",cnt]
    and
    LcdOut $FE,$C0
    LcdOut "Count= ",dec dataon
  1. Send data PIC to PC
    By konter in forum Off Topic
    Last Post: - 25th December 2009, 23:04
  2. Send data to PC USB
    Last Post: - 18th December 2009, 22:57
  3. send data from VB 6 to PIC 16f84
    By win_832001 in forum Serial
    Last Post: - 9th March 2006, 15:21
  4. how to send data from VB to PIC 16f84
    Last Post: - 25th February 2006, 17:15
  5. send and receive data using pic 16f84a
    By PoTeToJB in forum Serial
    Last Post: - 25th February 2006, 15:47
