Code check -- button not working
+ Reply to Thread
Results 1 to 13 of 13
    Jan 2006
    Default Code check -- button not working
    I have a number of buttons in my program, all are working except for the select button (SD). I have tried hooking the button to a different port with the same problem, I have swapped the button with others and the button itself works. So I am assuming its in the code somewhere.
    Im sure there are inefficiencies in the code, let me know if there are really bad ones.
    thanks
    p.s. I know I havent coded in the 2nd and 3rd hpwm lines yet, I only have 1 color LED hooked up to the board so far.
    TRISB = %00000000 'portb output
    ADCON1 = %11111111 'all ports digital
    define OSC 4 '4mhz oscillator
    DEFINE LCD_DREG PORTB ' Set LCD Data port
    DEFINE LCD_DBIT 0 ' Set starting Data bit (0)
    DEFINE LCD_RSBIT 4 ' Set LCD Register Select bit
    DEFINE LCD_EBIT 6 ' Set LCD Enable bit
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2000 ' Set command delay time in us
    DEFINE LCD_DATAUS 50 ' Set data delay time in us
    DEFINE CCP1_REG PORTC 'Hpwm 1 pin port
    DEFINE CCP1_BIT 2 'Hpwm 1 pin bit
    DEFINE CCP2_REG PORTC 'Hpwm 1 pin port
    DEFINE CCP2_BIT 1 'Hpwm 1 pin bit
    B0 Var Byte 'up button
    B1 var byte 'down button
    B2 var byte 'select button
    B3 var byte 'daylight button
    B4 Var byte 'tungsten
    B9 var byte 'lock button
    B10 var byte 'power button
    rval var byte 'red
    gval var byte 'green
    bval var byte 'blue
    rval = 0 'red at 0
    gval = 0 'green at 0
    bval = 0 'blue at 0
    B0 = 0 'zero button up
    B1 = 0 'zero button down
    B2 = 0 'zero select button
    B3 = 0 'zero daylight button
    B4 = 0 'zero tungsten button
    B9 = 0 'zero lock button
    B10 = 0 'zero power button
    while portc.6 = 0 'power button
    wend
    high portc.4 'power indicator
    pause 500 '.5 second delay
    LCDOUT $FE, 1, "LEADS ", $FE, $C0, "by MSL" 'tag line
    pause 1000 '1 second delay
    home:
    lcdout $fe, 1, " R", DEC3 rval, " G", $FE, $C0, DEC3 gval, " B", DEC3 bval
    hpwm 1, rval, 5000 'set dim level
    sd:
    button portb.7,1,255,0,B2,0,bru 'detect select button
    pause 20
    goto adjr
    bru:
    BUTTON porta.0,1,100,1,B0,0,brd 'detect + button
    pause 20
    goto brup
    brd:
    button porta.1,1,100,1,B1,0,ld 'detect - button
    pause 20
    goto brdown
    ld:
    button portc.7,1,255,0,B9,0,pd 'detect lock button
    pause 20
    goto lock
    pd:
    button portc.6,1,255,0,B10,0,dd 'detect power button
    pause 20
    goto power
    dd:
    button portc.5,1,255,0,B3,0,td 'detect daylight button
    pause 20
    goto daylight
    td:
    button portc.4,1,255,0,B4,0,bru 'detect tungsten button
    pause 20
    goto tungsten
    brup: 'brightness up
    rval = rval + 1
    gval = gval + 1
    bval = bval + 1
    hpwm 1, rval, 5000
    goto home
    brdown: 'brightness down
    rval = rval - 1
    gval = gval - 1
    bval = bval - 1
    hpwm 1, rval, 5000
    goto home
    adjr: 'adjust red level
    lcdout $fe, 1, "Red", $FE, $C0, DEC3 rval 'display red level
    ru: 'check up button
    BUTTON porta.0,1,100,1,B0,0,rd ' Check button
    pause 20
    goto rup
    rd: 'check up button
    button porta.1,1,100,1,B1,0,sd2
    pause 20
    goto rdown
    sd2: 'check for select button
    button portb.7,1,100,1,B2,0,ru
    pause 20
    goto adjg 'goto adjust green
    rup: 'red up
    rval = rval + 1
    hpwm 1, rval, 5000
    goto adjr
    rdown: 'red down
    rval = rval - 1
    hpwm 1, rval, 5000
    goto adjr
    adjg: 'adjust green
    lcdout $fe, 1, "Green", $FE, $C0, DEC3 gval 'display green level
    gu: 'check up button
    BUTTON porta.0,1,100,1,B0,0,gd ' Check button
    pause 20
    goto gup
    gd: 'check down button
    button porta.1,1,100,1,B1,0,sd3
    pause 20
    goto gdown
    sd3: 'check select button
    button portb.7,1,100,1,B2,0,gu
    pause 20
    goto adjb 'goto adjust blue
    gup: 'green up
    gval = gval + 1
    hpwm 2, gval, 5000
    goto adjg
    gdown: 'green down
    gval = gval - 1
    hpwm 2, gval, 5000
    goto adjg
    adjb: 'adjust blue
    lcdout $fe, 1, "Blue", $FE, $C0, DEC3 bval 'display green level
    bu: 'check up button
    BUTTON porta.0,1,100,1,B0,0,bd ' Check button
    pause 20
    goto bup
    bd: 'check down button
    button porta.1,1,100,1,B1,0,sd4
    pause 20
    goto bdown
    sd4: 'check select button
    button portb.7,1,100,1,B2,0,bu
    pause 20
    goto home 'goto home
    bup: 'blue up
    bval = bval + 1
    hpwm 1, bval, 5000
    goto adjb
    bdown: 'blue down
    bval = bval - 1
    hpwm 1, bval, 5000
    goto adjb
    lock: 'lock the keys
    high portc.3 'lock indicator
    while portc.7 = 0 'wait for unlock
    wend
    low portc.3 'lock indicator
    goto home
    power: 'power down display and LEDs
    low portc.4 'take down power indicator
    hpwm 1, 0, 5000 'take down red channel
    lcdout $fe, 1 'clear display
    while portc.6 = 0 'wait for power on
    wend
    high portc.4 'put up power indicator
    goto home
    daylight: 'set color levels to approx 5600k
    rval = 255
    gval = 255
    bval = 252
    goto home
    tungsten: 'set color levesl to approx 3200k
    rval = 255
    gval = 241
    bval = 224
    goto home
    What's Up DOC?
    The SD button is on portb.7, but at the very top TRISB is set to all outputs.
    The button command never sees the pin.
    HTH,
      Darrel
    Isn't the Button command supposed to take care of TRIS settings?
    The manual says "Pin is automatically made an input."
    http://www.melabs.com/resources/pbpm...5_4-5_6.htm#56
    Jan 2006
    Ill give it a shot. It sounds logical. It may be overriding the button commands ability to make it an input.
    Yes, someone keeping me in check. Good.
    You're right RRacer, it does say that.
    And now I'm back to gee, I don't know. Unless ...
    Since there isn't a LOADER_USED define, can I assume you are using ICSP?   And, is the programmer always connected?   Is the programmer conflicting with the RB7 input? Just another thought.
    <br>
    Darrel
    P.S. What chip are you using? 16F737? The ADCON1 seems odd. That won't affect PORTB.7, I'm just trying to figure out what chip it is.
    Jan 2006
    Yes, I am using ICSP. I only have a pin header connected, I disconnect the programmer after each burn.
    Like I said, I tried the same button on a pin on the porta side and still the same issue. The button registers voltage when pressed, so its not a hardware fault.
    check out the photos of the LED up and in action! Damn, Lamina makes some really bright stuff.
    http://share.shutterfly.com/action/w...=2CcN3DhozYuOg
    Jan 2006
    I am back, trying to get this problem solved again. Anyone have any new ideas on why this single button wont work?
    Feb 2005
    Kolkata-India
    Default Please post the schematic
    I would like to see the schematic and know which PIC you are using.
    Sougata
    Jan 2006
    I am using the 16F767. The select button (the one not working) is wired just as all the other buttons are, and they all work. So I am pretty confident the hardware is correct. As I stated before, I have tried a different pin, so I dont think that is the problem. I have also taken a volt meter to the output of the button and I get a 4.97 volt reading, so the button itself works.
    -brian
    Feb 2005
    Kolkata-India
    Default Unsubscribing from this thread
    Hi docwisdom,
    A quick glance at your code looked like everthing is okay by the algo. However the algo can be cut down pretty much. So my intensions were to duplicate your circuit since simulation works.
    The more peculiar a problem is the more I get interested.
    Hope somebody else solves the problem.
    Sougata
    Jan 2006
    sorry sougata, no full diagram has been made yet. My buttons are wired just as shown in the manual. Vin to button, button out to pin of PIC, and also pulled down to ground with a resistor.
    when the button is pressed i get voltage, just dont know why the pins not reading high.
    I wonder is this has anything to do with RB6 & RB7 being dedicated to
    in-circuit DEBUG is this bit is clear in config word?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2006
    I have an interesting solution. I retyped it.
    Maybe there was a glitch in MCS or something, but I retyped it, just as before and it works great now. Beats the heck out of me.
  1. Loop with two motor and 2 sensors
    Last Post: - 8th December 2008, 23:40
  2. My LCD code is not working...
    By kvrajasekar in forum mel PIC BASIC
    Last Post: - 7th December 2008, 05:41
  3. Making Program Code Space your playground...
    Last Post: - 19th July 2008, 08:26
  4. Can some one please check my code out thanks
    By Jhdgkss in forum mel PIC BASIC Pro
    Last Post: - 10th February 2006, 08:19
  5. button ,eeprom,read
    By mike12 in forum mel PIC BASIC Pro
    Last Post: - 31st December 2005, 11:19
