Using Nokia LCD
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 40 of 301
Thread: Using Nokia LCD
    Mar 2004
    UK-Midlands
    Default Using Nokia LCD
    Hi all,
    I have noticed recently that LCD displays from Nokia phones (6310, etc.) are being used in PIC projects.
    I have collected datasheets and before I loose more hair I wondered if anyone has written PBP code to drive this display?
    Any snippets of code or hints would be appreciated.
    Bob
    Edit from Moderator:
    A Wiki has been created for one solution for the Nokia 3310 display from a few of the posts in this thread. It can be found here: http://www.picbasic.co.uk/forum/cont...Nokia-3310-LCD.
    Original's Avatar
    Original Guest
    Default Nokia
    Try here:
    Is in CCS C code not picbasic pro though!
    http://users.skynet.be/bk317494/
    INIT_LCD:
    SSPSTAT.6 = 1 'CKE
    SSPCON.0 = 1 'TCK / 16
    SSPCON.5 = 1 'ENABLE MSSP
    HIGH CMD_DAT 'COMMAND / DATA LINE
    HIGH LCD_C_S 'LCD CHIP SELECT
    HIGH LCD_PWR 'LCD POWER ENABLE
    LOW LCD_RST 'LCD RESET LINE
    PAUSE 20
    HIGH LCD_RST
    LOW CMD_DAT
    SSPBUF = 33 'EXTENDED COMMAND SET
    PAUSE 1
    SSPBUF = 200 'SETUP VOP
    PAUSE 1
    SSPBUF = 19 'SETUP BIAS
    PAUSE 1
    SSPBUF = 32 'NORMAL COMMAND SET
    PAUSE 1
    SSPBUF = 9 'TURN ON ALL SEGMENTS
    PAUSE 100
    SSPBUF = %00001100 'DISPLAY NORMAL
    PAUSE 1
    HIGH CMD_DAT ' GET READY TO SEND PIXEL DATA
    HIGH LCD_C_S ' DESELECT LCD
    Mar 2004
    UK-Midlands
    Thats enought to get me started. I will post the code here once I have finished it.
    Bob.
    Original's Avatar
    Original Guest
    Default nokia lcd
    Here's one submitted on the Proton Picbasic site.
    Hawkesy's Avatar
    Hawkesy Guest
    Hi all,
    I have just got my Nokia 5110 LCD working, I tried the ASM code from Berty's page (http://sandiding.tripod.com/Bertys.html), however I had problems getting it going. I re-wrote the code using PBP, now I can display stuff. It is very code intensive as the display is dumb and you have to set each pixel. I used a PIC16F628 and the Shiftout command. I will attach the .BAS file. If anybody wants to improve the code please do I would be interested in any improvements. i would also like to know how to use a lookup table to display pre defined characters.
    Cheers
    Hawkesy's Avatar
    Hawkesy Guest
    Oh yeah here is a txt file for the charater set and their associated hex codes.
    Jan 2004
    Thessaloniki , GREECE
    Talking nokia_lcd_pbp_pro code
    Hi!
    Guys
    I have already smth ready for you (I think)
    two months ago I tried to figure out a way to drive a nokia
    LCD using just a pic and Picbasic pro!
    Here is the good news: SUCCESS
    As i am at work now, as soon as I find some time I will dig-out and send you the simple schematic and of course the source!
    Wait till then...
    See you
    P.S As I can remember the only limit was that you need a lot of eeprom space to 'throw in' the character bitmap mask data.
    Jan 2004
    Arrow Picbasic pro code !
    Hi,Guys!
    At last I managed to dig out the infos you want.
    I attached the pbp source for anyone interested
    Also I have written a very good utilty in VB (included in zip)that
    helps you create the graphic data you can inport in
    pic basic in order to diaplsy bitmap images on the nokia lcd!
    I hope you find then usefull
    Also included is the connection to nokia lcd
    NOTE:You MUST unzip the file in your c:\matrix , in order
    to run properly!
    Tim B's Avatar
    Tim B Guest
    If you want a font to bit map converter have a look at the one written for PPrint.
    http://users.picbasic.org/Howto/PPRI...le_fonts_o.htm
    Tim
    Mar 2004
    UK-Midlands
    Many thanks for all the replies, I have written some code but it needed tidyed up before posting. But it will now gather dust on the hard drive.
    look forward to building something (even an egg timer!) just to try the code.
    BobP
    stu746's Avatar
    stu746 Guest
    Angry
    been trying to get this working for a while now, i am beginning to think my lcd does not work or maybe i damaged it when soldering it,
    should the lcd turn black or anything when power is applied?
    i used bitmaniacs code and compiled it for a 16f877a but the lcd does nothing when I power up
    i also have a nokia 6610 lcd if anyone has a circuit and any code to get this working?
    thanks for any help
    Stu
    Sao Paulo - Brazil
    Smile
    Hi Bob,
    the same thing happened to me this weekend !
    As I can not find the 16F648 to buy here in Brazil, I´m using the 16f877 to do the tests.
    I Just removed the CMCON line from the code and changed the cristal to 10 Mhz, but the display still not responding.
    I have conected the Vout pin to Gnd via a 1 uf Cap.
    I´m powering up the display with 5 V (maybe I should change to 3,3v)
    I have seen other project powering up the display with 5V with out problems.
    After some hours testin the circuit and the software with no success, I decided to test another display. But the results were the same... a blank display.
    If could someone help us, it will be apreciated.
    Regards !
    Sérgio
    stu746's Avatar
    stu746 Guest
    Hi Sérgio,
    seems like you are having same problem as me, did u manage to get it working yet?
    i am using 5v too and am unsure wether this is the problem, but i have seen a few circuits using 5v.
    Stu
    Sao Paulo - Brazil
    Hi Stu,
    I'm still trying... but the display still blank, showing nothing, even a small flash when I turn on the 5 Volts.
    I got two more displays, but they are 9 pin version. I will connect them using the mobile's main board 8 pin (in the PCI's Back).
    Other weird behavior I'm facing is the fact of the 877, sometimes, don't start. I have to wait for some minutes and try again.
    I don't have much experience in electronics, as I'm just a curious but a behavior like that is really strange.
    TInight I will try the other dispplay type and if I get some good result, don't worry, I will let you know ! ! !
    Regards.
    Sérgio Pinheiro (Brazil)
    ps. sorry for my bad english... portuguese is my mother language...
    stu746's Avatar
    stu746 Guest
    Hi again,
    yeah i have problems like that with pics sometimes, i usually find it is the batteries gowing flat and need to change them.
    I also have one of the 9 pin versions from a nokia 5110 I think, it seems impossible to solder to the lcd, so i tried soldering to the back of the pcb, but i could not trace one of the connections, i took a bit of a guess in the end as i think it is connected to the lcd via a capacitor.
    but could not get this working any better. let me know how u get one, i am begining to think i need a better power suplpy.
    Stu
    Jan 2004
    Question !
    Hi Guys
    Well I see that you have problems with F877 andmy code
    I will try and re-try my code on an F877 to see what happens
    I hope to find some time this week to try and find out what happens)
    Sao Paulo - Brazil
    Hi People,
    Alexandros, your help will be really apreciated.
    Well, in the link below, there's some explanation about on how to connect the nokia display to the pc's printer port in order to show Winamp's information.
    I Know that it'is not what we want but there's some explanation about the different types of Nokia's LCD (8 and 9 Pins)
    http://serdisplib.sourceforge.net/ser/pcd8544.html
    And for those who can read and/or undestand spanish, the link bellow show how to connect a Pic to a COLOR nokia's LCD (Epson Controller). The code is in Pic CCS.
    http://www.comunicom.com.py/juno/3595/
    The link bellow is the original code used by the spanish guy above and his page is in English (source code in HiTec C)
    http://67.15.78.55/~spiral/colorlcd/colorlcd.html
    My idea is get the monochrome working first and change the code and work with the color version.
    The Nokia's LCD are getting cheap, even the color modules, and I think they could be a very good option for some projects, like meters and machine monitors as we can buy them for a good price and every cell phone service store havem them to sell. In other hand, graphical displays are not very easy and, sometimes, expansive.
    My best regards to all
    stu746's Avatar
    stu746 Guest
    Talking
    Woohooo!!!
    got it workin at last with a 6110 lcd
    it was just the contrast setting in the code!
    i had tried changing it ealier, but i changed the last number only
    i now have it set at d1 and works great
    it now reads
    SHiftOUT Lcd_SDA , Lcd_CLK , MSBFIRST, [ $21,$d1,$20 ]
    i hope this is some help to others as it was driving me nuts
    i used a 16f877a in the end and also used 4.5v, so 3.3 is not required.
    Stu
    Sao Paulo - Brazil
    Hi Stu,
    Nice tip !
    I ´ll try this tonight.
    thank you.
    Sérgio Pinheiro
    stu746's Avatar
    stu746 Guest
    just tried with a display from a 3310 again and worked great with the contrast changed
    Jan 2004
    Default nice!
    Hi! Guys
    I have just finished verifying my code with 16f648 and works Fine!
    I was just about to mention to check lcd initilization, contrast, etc but you have already found it by yourself so.... ALL is FINE!
    I hope you have success make it work with F877
    Nokia lcds is a perfect option for projects.
    Also download Nokia lcd pdf it will be very useful for seting differnet parameters to lcd
    I am here for any help.
    Sao Paulo - Brazil
    Hi Guys,
    I changed the contrast value and guess what....
    It is working ! ! !
    thank you Alexandros and Stu
    soon I will try a color display, and if I get it working fine I will let you know here in the forum
    Just one more thiing : Have you ever faced problems with Pic's in a protoboard ?
    I just can not make it working. It seems to have some parasite capacitancce between the holes.
    I had to move the project to a experimental PCB and make all the soldering.
    Thank you again
    Sérgio Pinheiro
    at wich frequency??? 20MHZ, on protoboard it's a common problem due to the capacitance of your protoboard. In many case, you can simply remove the capacitor around your crystal. and the problem will be fix .... on proto only.
    Monitoring your crystal oscillation amplitude with/without capacitor with a scope (10X probe or bigger) will teach you more.
    Also you must add 0.1uF and 10uF tantalum, close to your PIC.
    Sao Paulo - Brazil
    Hi Steve,
    thank you for your advice.
    I`ve moved my circuit from the ProtoBoard to a PCB (universal one, with isolated holes), reduced the crystal speed to 10 Mhz and now, everything is soldered.
    Just the power supply lines are a bit long (I´m using a regulated 5 V Power supply).
    I still have problems to make the 16F877-20 and the 16F877A working. I have to touch the PIC with my fingers many, many times to make it working ! ! ! really strange...
    I tried to substitute the crystal for a ressonator too... but I got the same problem...
    Is there another option rahter than the Tantalum Caps ?
    Is this problem related to the Power supply or to the Crystal Speed ? (maybe both ?)
    Sérgio Pinheiro
    rastan's Avatar
    rastan Guest
    Hi, just noticed this, I had many problems all over the place to do with touching the pic to make it work, with serial comms, LCD etc etc.
    It turned out that i did not connect MCLRE. it was floating. so it never worked untill my static charge from my fingers pulled the pin high. Also check that other main pins arnt floating. (by main i mean not output/input pins.)
    capacitors from +V to Ground near the pic also help. They basically filter out noise from the powerline/regulator. 100nf usually do the trick
    phil
    Sao Paulo - Brazil
    Hi Phil,
    thank you for your tips.
    I will try them tonight
    Regards.
    Sérgio Pinheiro
    Sao Paulo - Brazil
    Question Drawing on the LCD
    Hi everyone !
    after some good results working with the nokia LCD, I decided to wite a routine in order to draw an small histogram in the Nokia´s LCD.
    But, after reading the PCD8544´s datasheet, i discovered that the LCD doesn´t have a direct mode wich allow us to draw on it pixel by pixel, and when we need to set a single pixel, we need to know its other 7 neighbour pixels.
    Is taht right ?
    Do I need to read the memory first and make some logical operation with the bits to draw what I want ?
    Have someone developped a routine to draw lines (for example) on this LCD ?
    thank tou
    Tim B's Avatar
    Tim B Guest
    PCD8544 will not let you read the screen so the best you will ever be able to do is keep a copy of the screen in the PIC's ram and then dump the whole screen to it at once. The data rate to these devices is slow though so you will not want to do it often.
    ice's Avatar
    ice Guest
    Hello,
    I am trying to interface the Nokia 3310 LCD to a PIC16F876A.
    Im using bitmaniacs schematic/code
    Im running on a 16Mhz crystal.
    I tried everything possible mentioned in the last posts
    change the contrast from $a7 to $d1
    Theres no response on the LCD..doesnt even turn dark..
    Is there anything im missing out.
    Thank you
    Feb 2004
    Germany
    ice,
    attached is a working piece of code to play with.
    (Tested on a 16F877A)
    regards
    Ralph
    ice's Avatar
    ice Guest
    Thank you Nav,
    but it still shows no response..i tried it with 2 displays with the circuit as in bitmaniac's
    are there any other values ,other than $d1 which i can use to adjust contrast?
    Ive tried changing sll the other parameters like bias,temperature coeff..
    Feb 2004
    Germany
    ice,
    the code example is tested and working.
    There must be something wrong in your Hardware.
    could you post your schematic?
    regards
    Ralph
    Dec 2006
    Default Isıs library for 3310 lcd
    Have you 3310 lcd library for isis ?
    Dec 2006
    Default Matrix data problem
    i make the data with using Matrix program but Where will i place data after scaned picture in pbp program? ? have you any example about it?
    PROGRAM:
    DEFINE LOADER_USED 1
    DEFINE OSC 20
    DC VAR PortB.6
    DTA VAR PortB.5
    RST VAR PortB.7
    CLK VAR PortB.4
    Chr VAR Byte
    BitMap VAR Word
    CharCount VAR Byte
    PosX VAR Byte
    PosY VAR Byte
    Column VAR Byte [6]
    LCDstr VAR Byte [26]
    LcdData VAR Byte
    PAUSE 100
    GOSUB LCD_INIT
    PAUSE 100
    GOSUB LCD_Clear
    Start:
    Loop:
    'PAUSE 2000
    'LOW DC
    'LcdData= %00001101:GOSUB LCD_ByteOut ' Invert
    'PAUSE 2000
    'LcdData= %00001000:GOSUB LCD_ByteOut ' Blank
    'PAUSE 2000
    'LcdData= %00001100:GOSUB LCD_ByteOut ' Normal
    GOTO loop
    LCD_Init:
    LOW RST ause 20 : HIGH RST : LOW DC ' RESET LCD
    LcdData= $21: GOSUB LCD_ByteOut ' LCD EXTENDED COMMANDS
    LcdData= $c8: GOSUB LCD_ByteOut ' SET LCD Vop (CONTRAST)
    LcdData= $06: GOSUB LCD_ByteOut ' SET TEMP COEFFICENT
    LcdData= $13: GOSUB LCD_ByteOut ' LCD BIAS MODE
    LcdData= $20: GOSUB LCD_ByteOut ' LCD STANDARD COMMANDS
    LcdData= $0c: GOSUB LCD_ByteOut ' LCD IN NORMAL MODE
    LCD_ByteOut:
    SHIFTOUT DTA,CLK,1,[LcdData]
    LCD_CharOut:
    IF lcddata=32 THEN BitMap=216 ' SPACE
    IF lcddata=42 THEN BitMap=240 ' *
    IF lcddata=43 THEN BitMap=222 ' +
    IF lcddata=45 THEN BitMap=228 ' -
    IF lcddata=46 THEN BitMap=234 ' .
    IF lcddata=58 THEN BitMap=246 ' :
    IF LCDData > 47 THEN ' Numbers 0-9
    IF lcddata < 59 THEN
    BitMap=6*(lcddata-48)+156
    ELSE ' Capital Letters A-Z
    BitMap=(LcdData-65) * 6
    FOR Chr=0 TO 5
    READ BitMap+Chr,Column(Chr)
    NEXT Chr
    HIGH DC
    SHIFTOUT DTA,CLK,1,[Column(0),Column(1),Column(2),Column(3),Column(4), Column(5)]
    LCD_StringOut:
    FOR CharCount=0 TO 13
    LcdData=LCDstr(CharCount)
    PAUSE 80
    GOSUB LCD_CharOut
    NEXT CharCount
    LCD_Clear:
    PosX=0:PosY=0:GOSUB LCD_GotoXY
    HIGH DC
    FOR Chr=1 TO 252
    LcdData=0:GOSUB LCD_ByteOut
    NEXT Chr
    LCD_GotoXY:
    LOW DC
    LcdData=%01000000 | PosY :GOSUB LCD_ByteOut
    LcdData=%10000000 | PosX :GOSUB LCD_ByteOut
    ' Font DATA table
    ' DEC Chr HEX
    Data $7E,$11,$11,$11,$7E,$00 ' 65 A 41
    Data $7F,$49,$49,$49,$36,$00 ' 66 B 42
    Data $3E,$41,$41,$41,$22,$00 ' 67 C 43
    Data $7F,$41,$41,$22,$1C,$00 ' 68 D 44
    Data $7F,$49,$49,$49,$41,$00 ' 69 E 45
    Data $7F,$09,$09,$09,$01,$00 ' 70 F 46
    Data $3E,$41,$49,$49,$7A,$00 ' 71 G 47
    Data $7F,$08,$08,$08,$7F,$00 ' 72 H 48
    Data $00,$41,$7F,$41,$00,$00 ' 73 I 49
    Data $20,$40,$41,$3F,$01,$00 ' 74 J 4A
    Data $7F,$08,$14,$22,$41,$00 ' 75 K 4B
    Data $7F,$40,$40,$40,$40,$00 ' 76 L 4C
    Data $7F,$02,$0C,$02,$7F,$00 ' 77 M 4D
    Data $7F,$04,$08,$10,$7F,$00 ' 78 N 4E
    Data $3E,$41,$41,$41,$3E,$00 ' 79 O 4F
    Data $7F,$09,$09,$09,$06,$00 ' 80 P 50
    Data $3E,$41,$51,$21,$5E,$00 ' 81 Q 51
    Data $7F,$09,$19,$29,$46,$00 ' 82 R 52
    Data $46,$49,$49,$49,$31,$00 ' 83 S 53
    Data $01,$01,$7F,$01,$01,$00 ' 84 T 54
    Data $3F,$40,$40,$40,$3F,$00 ' 85 U 55
    Data $1F,$20,$40,$20,$1F,$00 ' 86 V 56
    Data $3F,$40,$38,$40,$3F,$00 ' 87 W 57
    Data $63,$14,$08,$14,$63,$00 ' 88 X 58
    Data $07,$08,$70,$08,$07,$00 ' 89 Y 59
    Data $61,$51,$49,$45,$43,$00 ' 90 Z 5A
    Data $3E,$51,$49,$45,$3E,$00 ' 48 0 30
    Data $00,$42,$7F,$40,$00,$00 ' 49 1 31
    Data $42,$61,$51,$49,$46,$00 ' 50 2 32
    Data $21,$41,$45,$4B,$31,$00 ' 51 3 33
    Data $18,$14,$12,$7F,$10,$00 ' 52 4 34
    Data $27,$45,$45,$45,$39,$00 ' 53 5 35
    Data $3C,$4A,$49,$49,$30,$00 ' 54 6 36
    Data $01,$71,$09,$05,$03,$00 ' 55 7 37
    Data $36,$49,$49,$49,$36,$00 ' 56 8 38
    Data $06,$49,$49,$49,$3E,$00 ' 57 9 39
    Data $00,$00,$00,$00,$00,$00 ' 32 20
    Data $08,$08,$3E,$08,$08,$00 ' 43 + 2B
    Data $08,$08,$08,$08,$08,$00 ' 45 - 2D
    Data $00,$60,$60,$00,$00,$00 ' 46 . 2E
    Data $14,$08,$3E,$08,$14,$00 ' 42 * 2A
    Data $00,$36,$36,$00,$00,$00 ' 58 : 3A
    DATA
    $0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0 ,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$ 0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0, $0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0 ,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$ 0,
    DATA $0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0 ,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$ 0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0, $0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$F0,$F0,$0,$0,$0,$0, $0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0 ,$0,
    DATA $0,$0,$0,$0,$0,$0,$30,$7C,$C4,$86,$86,$86,$86,$4,$ 4,$0,$0,$C,$84,$86,$86,$86,$C6,$C4,$FC,$F0,$0,$0,$ 0,$FE,$FE,$8,$4,$6,$6,$6,$FC,$F8,$8,$4,$6,$6,$6,$F 0,$0,$0,$0,$FE,$FE,$8,$4,$4,$6,$6,$4,$C,$F8,$E0,$0 ,$0,$FF,$FF,$0,$0,$C0,$F8,$CC,$C4,$C6,$C6,$C6,$C4, $CC,$F8,$E0,$0,$0,$0,$0,$0,$0,$0,$0,$0,
    DATA $0,$0,$0,$0,$0,$0,$18,$10,$30,$30,$30,$30,$11,$1F, $6,$0,$6,$1F,$11,$30,$30,$10,$10,$8,$3F,$3F,$0,$0, $0,$3F,$3F,$0,$0,$0,$0,$0,$3F,$3F,$0,$0,$0,$0,$0,$ 3F,$0,$0,$0,$FF,$FF,$10,$10,$30,$30,$30,$10,$18,$F ,$1,$0,$0,$3F,$3F,$0,$0,$1,$F,$18,$10,$10,$30,$30, $30,$10,$10,$18,$0,$0,$0,$0,$0,$0,$0,$0,$0,
    DATA $0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0 ,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$ 0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$7,$7,$0, $0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0 ,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$ 0,
    DATA $0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0 ,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$ 0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0, $0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0 ,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$0,$ 0,
    Jan 2004
    Hi PCBB
    As there has been a lot of time since last worked in this project (matrix proggy of mine e.t.c) I have to re-scan my nokialcd files to answer you...
    Please wait a little and I 'll see what I can do for you.
    Dec 2006
    Default ok
    i wait your message back. Thanks for interest.
    Dec 2006
    Unhappy Which converter ?
    Which program did you use for convert to hex ? there are many program for graphic lcd but they dont make 5 columns about data, more! So Microcode program give error "Address exceeds maximum range for this processor " My processor is 16F877
    There are many converter in this site, h**p://www.compsys1.com/workbench/Benchware/GLiPIC2/glipic_2.html
    Can you help me for this problem ?
    Jan 2004
    I didn't manage yet to visit my lab (upstairs) to compile and try my code for you !
    I hope this weekend
    Default gameboy GLCD to PIC16F877A
    hi guys, pls i need help on interfacing a game boyGLCD to PIC16F877.
    thanks in anticipation
    Jun 2006
    Bangalore, India
    Question 3310 thermo
    How can i make this in PicBasic Pro ?
    http://free-vz.htnet.hr/Ivica-Novako...ometar-eng.htm
    I want to use the 12F629 , a 3310 lcd and the DS1820.
    Currently i have got the DS1820 running and readings displayed onto a 16x1 LCD.
  1. Nokia COLOR LCD PicBasicPro 2.50a example code
    Last Post: - 28th September 2011, 02:43
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  5. LCD will not start
