Pulsin to pulsout with up than 4MHZ crystal ?
Results 1 to 6 of 6
    Jan 2006
    North of France
    Unhappy Pulsin to pulsout with up than 4MHZ crystal ?
    Hello members.
    I'll try to explain my problem in a comprehensive english but don't blame me if my language is not perfect, English is not native for me.
    Well, i just wanna do that :
    Pulsin a value on a pin and pulsout this value on another pin.
    it's okay with a 4Mhz crystal but not with another one :O(
    Here is my code :
    @ device PIC16F871, HS_osc, wdt_off, pwrt_off, protect_off, bod_on, lvp_off, cpd_off, wrt_off, debug_off
    ADCON1 = 7 'Need this to turn off ADC
    DEFINE NO_CLRWDT 1 'Do not auto insert watchdog timer
    Define OSC 20 'Not important to define in this case but i want
    Clear
    TRISA = %11111111 'Pins A are in input mode
    TRISC = %00000000 'Pins C are in Output mode
    PORTC = %00000000 'Clear Port C
    Init:
    PULSIN PORTA.2,1,ValInPulse 'Measure the pulse who vary from 1ms to 2ms
    PULSOUT PORTC.5, ValInPulse 'Output the pulse
    GOTO Init 'Do it always
    And now, here is is what i don't understand :
    I know Pulsin and pulsout depend from the crystal, so, if the pulsin have a 5 times higher resolution with à 20MHZ crystal, it's the same for the pulsout (?) I think i don't have to multiply or divide the pulsin value before i output it via PORTC.5...
    May be someone could explain ?
    Thanx.
    RCtech , Yes you are correct. The commands resolution depends on the oscillator used. So you must multiply or divide the variable accordingly.
    Wink Pulsin and Pulsout Mysteries
    Hi, RCTech
    Assuming DEFINE OSC doesn't interfere with osc speed for pulsin and pulsout, result won't be the same @ 4Mhz and @ 20 MHz. ratio will be 5 , as you tell.
    The Valinpulse value will be the same for Pulsin and Pulsout.
    Now, as RC is in your pseudo ... RC pulses values are ~ 80 to 220 @ 4Mhz and 400 to 1100 @ 20 Mhz ... okay, but...
    @ 4Mhz, you write: Valinpulse var BYTE ....and @ 20 Mhz you MUST write : Valinpulse var WORD !!!
    and I didn't see that in your code ...
    Also take care, if you ever use DEFINE PULSIN_MAX to allow for the full signal ( 0 AND 1 state duration = full period )
    Now, a little Trick seen nowhere :
    Always Write : LOW PORTX.Y before a Pulsout statement ... many ununderstandable bugs come from here !!! ( explanation is in High capacitive loads behaviour of PICs ... and the Pulsout way of work )
    30 years of R/C ...
    Jan 2006
    North of France
    Smile
    Quote Originally Posted by Acetronics
    Hi, RCTech
    .../...The Valinpulse value will be the same for Pulsin and Pulsout.
    Okay, i'm not totally wrong ;O)
    Whow, i didn't know that little difference !
    Always Write : LOW PORTX.Y before a Pulsout statement .../...
    Thanx, i'm just a little bit more intelligent than yesterday, many many thanx.
    Now it's half past 3 AM : too late for me to do the tests but tomorrow probably, i'll post a feedback.
    And.... Nice to see i'm not the only one froggy here !
    Dave, i've tested with multiplying etc (just in case), but, today i'm sure it was a mistake because pulsin & pulsout have the same res. depending the X-tal used so if pulsin have a 5 times ratio at 20Mhz, then, the pulsout too and i don't need to do some corrections by calcs.
    I'll come back on the forum tomorrow or next day to tell if it's okay.
    RCTech
    Jan 2006
    North of France
    Thumbs up It's Okay !
    Back to confirm everything is okay, this stupid ''BYTEs'' are changed for ''WORDs'' now !
    Thanx for your help.
    Apr 2005
    If you don't mind me asking what is your application for this?
  1. Replies: 17
    Last Post: - 12th April 2014, 02:17
  2. pulsout pulsin on same pin - timing?
    By vacpress in forum mel PIC BASIC Pro
    Last Post: - 15th January 2009, 07:21
  3. Better understanding PULSIN
    By Wirecut in forum mel PIC BASIC
    Last Post: - 29th June 2008, 10:17
  4. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 20:10
  5. Help Quick Need to make code smaller
    By Programmednew in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 03:46
