Timer with TMR0
Results 1 to 6 of 6
Thread: Timer with TMR0
    Dec 2005
    Question Timer with TMR0
    Help me,
    i want create a counter in 1 sec with the TMR0 and interrupt, the pic is 16f877a osc 20Mhz.
    I have utilized the formule Time = Mhz * periode * (Tmr0-N) * prescaler
    Time = (20 * 50 *(256)*64)/1M= 16384*61 =999.424
    but it not functional.
    Help Me
    SOS.
    Aiutoooooo
    Apr 2005
    Look here, even if on a different pic than yours:
    http://www.microengineeringlabs.com/...BP/CLOCKX4.BAS
    bye ( se sei italiano ciaooo)
    roberto
    Dec 2005
    Hy Robert (ciao si sono Italiano )
    thank you for answer
    but the osc in the example is 4 Mhz,
    i use a osc to 20 Mhz.
    Help Me.
     @ DEVICE LVP_OFF,HS_OSC
        DEFINE OSC 20
        DEFINE INTHAND TMRint
        'Variables for saving state in interrupt handler
        wsave	VAR	BYTE $70 system		' Saves W
        ssave	VAR	BYTE bank0 system	' Saves STATUS
        psave	VAR	BYTE bank0 system	' Saves PCLATH
        fsave	VAR	BYTE bank0 system	' Saves FSR
        TMR0_Ticks VAR BYTE system
        TMR0 = 96
        GoTo Init
    Asm
    TMRint
        ; Uncomment the following if the device has less than 2k of code space
    	; movwf	wsave			; Save W
    	; swapf	STATUS, W		; Swap STATUS to W (swap avoids changing STATUS)
    	; clrf	STATUS			; Clear STATUS
    	; movwf	ssave			; Save swapped STATUS
    	; movf	PCLATH, W		; Move PCLATH to W
    	; movwf	psave			; Save PCLATH
        ; Increment ticks, reload, clr int flags
        incf    TMR0_Ticks,f    ; increment overflow ticks
        movlw   96              ; 256-96=160. 160x200nSx256=8.192mS. 8.192mSx122=0.999mS= ~1S
        movwf   TMR0            ; reload
        bcf     INTCON,2        ; clear TMR0 int flag
        movf	fsave, W		; retrieve FSR value
    	movwf	FSR				; Restore FSR
    	movf	psave, W		; Retrieve PCLATH value
    	movwf	PCLATH			; Restore PCLATH
    	swapf	ssave, W		; (swap to avoid changing STATUS)
    	movwf	STATUS			; Restore STATUS
    	swapf	wsave, F		; Swap the stored W value
    	swapf	wsave, W		; Restore it to W (swap to avoid changing STATUS)
    	retfie					; Return from the interrupt
    EndAsm
    Init:
        PORTD = 0
        TRISD = 0
        OPTION_REG = %00000111 ' 1:256 prescaler to TMR0
        INTCON = %11100000     ' Enable TIMR0 interrupts
        IF TMR0_Ticks >= 122 THEN
         TMR0_Ticks = 0
         PORTD.0 = PORTD.0 ^ 1 ' ~1 second pulse on RD0
        GOTO Main
    Timer1 would be better, but this should get you started.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Dec 2005
    Thank You
    Bruce.
    Apr 2005
    I used Timer2 on a PIC16F628 for 1.5 seconds:
    T2CON=%01111010 'prescaler 1:16 POSTSCALER 1:16 ,STOP TIMER2
    Then start timer and in interrupt handler:
    if PIR1.1=1 then
    Count= Count +1
    if Count =100 then
    high led
    T2CON.2=0
    PIR1.1=0 'reset flag interrupt
    resume
    Every interrupt of timer Count is incremented....when is 100 =1,5 sec
    It's easy to change to TMR0 or Timer1....and also you can change the number of count
    Ciao
    Roberto
  1. Timer interrupt frequency
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 17th January 2009, 23:49
  2. TMR0 interrupt and HSERIN
    By boban in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 11:48
  3. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 15:10
  4. using TMR0 as a counter..
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 28th July 2007, 02:56
  5. Timer Accuracy
    By GEEZER in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 05:26
