Pic18 Syntax problem
Results 1 to 4 of 4
    Philip Biebach's Avatar
    Philip Biebach Guest
    Default Pic18 Syntax problem
    hi im just begining to use the pic18 series
    my current setup is:
    a melabs USB programmer
    PBP 2.45A
    Microcode Studio 2.3.0.0
    my problem is that when i try to do a really basic thing such as make portb.0 go low it doesent work properly
    the following has no effect :
    PORTB.0 = 0
    however this works for some reson:
    low PORTB.4
    thanks in advance for any help and responses
    O.K. LOW and HIGH function set the i/o of the PIC as output.
    When you apply the power to the PIC, the POR(Power on Default) value set the i/o as input. You need to set it by writing to the TRISB register (se datasheet for that). Once the i/o is properly set as output you can write it as you did.
    TRISB=0
    PORTB.0=0
    should work. TRISx is placed at the top of your code. You can Even use the OUTPUT directive wich do almost the same thing.
    hth
    Thumbs up
    exelent that worked, iv only used the pic16s up until now and was not used to needing Tris, although I was familiar with it.
    I appreciate the quick response mister_e
    Well TRISx is needed in all PIC family when you Write directly to the PORT register. You don't need the TRISx setting if you use PBP statement, HSEROUT,SERIN... HIGH, LOW...
  1. Need help with I2C syntax problem?
    By Michael Wakileh in forum mel PIC BASIC Pro
    Last Post: - 19th July 2007, 20:11
  2. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 09:12
  3. Correct syntax please ?
    By malc-c in forum mel PIC BASIC Pro
    Last Post: - 11th June 2006, 10:09
  4. 1 slave 1 master 1 MAX232 1 problem ?
    By SuB-ZeRo in forum mel PIC BASIC Pro
    Last Post: - 31st July 2005, 23:59
  5. Replies: 22
    Last Post: - 12th July 2005, 18:39
