Well, since you got a grown-up compiler, we might as well do things properly...
	'	PIC Defines
	@ DEVICE pic12F675, INTRC_OSC_NOCLKOUT
		' System Clock Options (Internal)
	@ DEVICE pic12F675, WDT_ON
		' Watchdog Timer
	@ DEVICE pic12F675, PWRT_ON
		' Power-On Timer
	@ DEVICE pic12F675, MCLR_OFF
		' Master Clear Options (Internal)
	@ DEVICE pic12F675, BOD_ON
		' Brown-Out Detect
	@ DEVICE pic12F675, CPD_OFF
		' Data Memory Code Protect
	@ DEVICE pic12F675, PROTECT_OFF
		' Program Code Protection
	'	Hardware Defines
	LED var GPIO.1
	'	Initialise PIC
	TRISIO=%00001000	' All Output except GPIO.3
	CMCON=%00000111 	' Disable Comparators
	ANSEL=%00000000 	' Disable ADC
	'	Let's do Blinky Thing...
Start:
	Toggle LED
	Goto Start
 Compile using the command line...
PBP -p12F675 myprog -v
Then if you want to be exotic with your 12F675 download yankeedoodle from here...
http://www.picbasic.co.uk/forum/showthread.php?t=64
