HID Keyboard Example
Results 1 to 9 of 9
    apitaru's Avatar
    apitaru Guest
    Default HID Keyboard Example
    Hi everybody,
    I am attempting to extend the USBMOUSE example (provided with PBP under /usb18 folder), so the target device (18F2550 or 18F4550) would be recognized by WinXP/OsX as both an HID Mouse and Keyboard. I'm not clear on how to use the USB desc files and would appreciate any examples and advise. If anyone has an example for just a Keyboard, that would also be of great help.
    Cheers
    Amit Pitaru
    Brooklyn, NY
    Merfy's Avatar
    Merfy Guest
    Default Keyboard Descriptors
    To implement a usb keyboard it is just a matter of setting up the descriptors properly. The hid documentation has a good example of the keyboard descriptor. http://www.usb.org/developers/devclass_docs/HID1_11.pdf
    Here is the mouse example descriptor that has been modified to work as a keyboard. To send a key stroke to the PC is as simple as (similar to mouse example included with PBP):
    USBOut 1, buffer, 8, endgame
    after initializing the device
    where buffer is 8x8bytes
    1st byte = modifier keys (i.e. ctrl, alt, shift)
    2nd byte = reserved
    3-8 = keys pressed ( 0x04 = a, 0x05 = b, ...)
    I don't know how to combine both a keyboard and a mouse together in one device but I have heard of making a composite device being one possible way. But as of yet, I have not got anything working.
    I understand this is a late reply but hopefully someone else might get something from it.
    Perth, Australia
    I realize I am resurrecting an old thread here, but I'm trying to get an 18F4550 to act as a "virtual keyboard". I've used Merfy's KBDDESC.ASM (above) and i've managed to get the PC to detect it as a keyboard, and can send keystrokes, however when I do, it seems to send the keystroke over and over and over until I send another one.
    If I do this for example (and keep in mind this line is only run once):
    where buffer=[0,0,$14,0,0,0,0,0] ' ($14=q)
    the pc types "qqqqqqqqqqqqqqqqqqqqqq....." and on forever.
    any suggestions?
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by Kamikaze47 View Post
    any suggestions?
    Not really sure if this has anything to do with your problem...
    http://www.beyondlogic.org/keyboard/keybrd.htm
    Looks to me like you you're on the right track...just not all the way there yet.
    You've told the PC that you've pressed the 'q' key, but you haven't told the PC that you've released it, therefore, it repeats.
    The first paragraph of the link above has some good info in it on the whole keyboard theory...should give you all the answers you need.
    Aug 2008
    Question
    I can't seem to get the USB to work with PIC18F4550 using the KBDDESC.ASM
    I keep getting USB error if i plug in the PIC.
    buffer	Var	Byte[8]
    loopcnt	Var	Byte
    state	Var	Byte
    Define  OSC     48
    	Pause 10
    	USBInit
    	buffer[0] = 0
    	buffer[1] = 0
    	buffer[2] = 0
                    buffer[3] = 0
                    buffer[4] = 0
    	buffer[5] = 0
    	buffer[6] = 0
                     buffer[7] = 0
    movecursor:
                   buffer[0] = 0
    	buffer[1] = 0
    	buffer[2] = $14
                    buffer[3] = 0
    endgame:
    			USBService	' Must service USB regularly
    			USBOut 1, buffer, 8, endgame  ' Send buffer to endpoint 1
    	while(1)
    	wend
    	Goto movecursor	' Do it forever
    Anyone knows what is wrong ?
    Perth, Australia
    what speed external clock are you using?
    and what configs are you using?
    "I think fish is nice, but then I think that rain is wet, so who am I to judge?" - Douglas Adams
    Aug 2008
    Using 20Mhz crystal.
    Config is:
    __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    I have tried using diff cap recommended in this forum.
    Try this
    DEFINE OSC 48
    @ __CONFIG   _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    @ __CONFIG   _CONFIG1H, _FOSC_HSPLL_HS_1H
    @ __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
    @ __CONFIG    _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_OFF_3H
    @ __CONFIG    _CONFIG4L, _LVP_OFF_4L & _ICPRT_OFF_4L &_XINST_OFF_4L
    Sep 2006
    Venezuela - Caracas
    I use KBDDESC.txt
    t = $0
    where buffer=[t,0,$14,0,0,0,0,0] ' ($14=q) OK
    t = $2
    buffer=[t,0,$33,0,0,0,0,0]' ($33 = /) error
    i need send "?" = #33 + shift = $2
    ..: Don't worry, be happy :..
  1. USB hid maker help please.
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2013, 15:49
  2. i cant get 18f2550 work as HID
    By Ahmadabuomar in forum mel PIC BASIC Pro
    Last Post: - 13th October 2009, 17:39
  3. AT/PS2 Keybord - PIC Interface?
    By Kamikaze47 in forum Code Examples
    Last Post: - 9th August 2009, 17:10
  4. One USB keyboard to Two USB Ports
    By picnaut in forum mel PIC BASIC Pro
    Last Post: - 11th June 2009, 01:04
  5. My wish: AT Keyboard and Mouse commands
    By sayzer in forum PBP Wish List
    Last Post: - 4th February 2006, 09:23
