constants
Results 1 to 6 of 6
Thread: constants
    cmolson's Avatar
    cmolson Guest
    Default constants
    Hello, I am pretty new to picbasic and have some questions which should be pretty straight forward.
    I am writing a program to send data serially out using the debug command and have confirmed to be able to use 9600bps at 3.579mhz. I need to send the data in inverted form so this is the code I use to declare and invert a variable:
    A4 var byte
    A4=~$A4 REV 8
    Is there a way to do this using constants? I have a lot of bytes I need to do this with and I don't want to manually invert them by hand because they lose their meaning to people reading the code that way.
    I would like to do this for example:
    A4 CON ~$A4 REV 8
    The ~ inverts the bits, and the REV8 reverses it. However this does not compile. It only works when I declare it as a variable. Maybe i could use some kind of table and lookup method? Thanks!
    Perth, Australia
    Why not convert them manually and comment each line so u know whats going on... e.g.:
    A4 CON $DA 'Inverted and Reversed $A4
    cmolson's Avatar
    cmolson Guest
    wow, good idea thanks!. As all these variables will quickly eat up my ram space. I jsut wish it was easier for me to update the code later on without inversing stuff. Thansk for the quick reply!
    cmolson's Avatar
    cmolson Guest
    One more question though, is it possible to make an array constant? I would like to make one with 9 byts in it. I'm not sure how to go about that. The bytes are hex.
    Perth, Australia
    No I dont think you can make an array constant. If you want an array you will have to use a variable like this:
    label VAR BYTE[length]
    Quote Originally Posted by cmolson
    Why not using the internal eeprom instead?
    ArrayIndex var byte
    ArrayData var byte
        ' PreLoad EEPROM at programming time
    data @0,$10,$20,$30,$40,$50
        ' Read data from EEPROM
    Read ArrayIndex,ArrayData
    Usually that's what i do instead of using Array... well if the PIC have EEPROM and/or free EEPROM storage.
    Good luck!
  1. The EXT (external) modifier.
    By Darrel Taylor in forum FAQ - Frequently Asked Questions
    Last Post: - 11th July 2010, 01:21
  2. How to define constants that specify eeprom addresses
    By DwayneR in forum mel PIC BASIC Pro
    Last Post: - 8th December 2009, 05:07
  3. Problem with 16F648A
    By ngeronikolos in forum mel PIC BASIC Pro
    Last Post: - 7th March 2008, 00:08
  4. PORTC constants
    By Forkosh in forum mel PIC BASIC Pro
    Last Post: - 18th October 2007, 06:43
  5. Bug ? Error in calculating constants
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 11th October 2005, 22:55
