Low cost bidirectional level shifter I2C and other
Results 1 to 4 of 4
    Feb 2004
    Germany
    Default Low cost bidirectional level shifter I2C and other
    If you are after a solution for a level shifter here is an interresting Application Note from PHILIPS
    AN97055
    With SOT23 FETs and 805 (or 1206) Resistors it takes minimal PCB space.
    regards
    Ralph
    Thanks Ralph for sharing. Nice pdf.
    Default Re: Low cost bidirectional level shifter I2C and other
    Yes it takes little space. And the new link is this
    www.adafruit.com/datasheets/an97055.pdf
    Or you could use one of these... I use them all the time. They make a 4 channel and an 8 channel version.
    Oops, I can't upload the data sheet, It's too big. The part number is TSX0102 for the 2 channel one and TSX0104 for the 4 channel one. They are made by Texas Instruments. Try it, Youl'l like it...
    EN82fn
