Remove Text Formatting
Loading...
+ Reply to Thread
Results 1 to 14 of 14
    micro's Avatar
    micro Guest
    Default how to use GLCD with picbasic pro
    can anyone tell me how to use Graphical LCD with picbasic pro., i do not use proton compiler but i use microcode studio plus.
    micro's Avatar
    micro Guest
    thanks for the site
    but if i want to add image BITMAP to Graphical LCD
    maybe i can use a software to convert it to hex file
    and catch these hex numaric, but it should add all of
    these hex symbol to basic codes??? like
    LCDOUT $c1,$26,........
    or is there a simple method to do that??
    i have read this site but that site dependece on assembly instructions
    http://www.geocities.com/dinceraydin/lcd/gfxhowto.htm
    Wink
    Hi,micro
    Understand GLCD have ( i.e)128x64 pixels to be driven ...
    so to have a picture, you must address them all ...by their code.
    just remember There's no miracle ... job has always to be done somewhere !!!
    Simple methods hide lots of intelligence ... and work.
    Mar 2005
    Iowa, USA
    Lightbulb
    THIS might be a good resource for you. Take a look around their site... lots of good info.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    micro's Avatar
    micro Guest
    thank you so much for this site, but i have a question is that the principle with mono graphical LCD the same as color graphical LCD or the idea is different??
    i use ISIS6 but there is no model for color graphical LCD, do you know how to add it or how to deal with it ????
    Mar 2005
    Iowa, USA
    Post
    Quote Originally Posted by micro
    Sorry, as far as I know, the code on that site will only work with mono LCD's. And for that matter, only LCD's with the KS0108 controller. I'm not familiar with ISIS6. You may be able to find something else on that site or linked sites. I stumbled across that link searching the forums here. Thought someday, I'd like to experiment with a GLCD, but haven't yet. Hope I've steered you in the right direction.... good luck!
    Ryan Miller
    micro's Avatar
    micro Guest
    thank you for your advices, but i am stil searching about color or polychrome LCD controller but i found nothing yet, all i found a datasheets with general information about specifiactions but not control insructions.
    i don't know what to do. any help ???
    Mentor, Ohio
    Smile
    Hi Micro,
    Goto www.earthlcd.com. They have a color LCD that displays graphics, etc.
    The product is called ezLCD-001. The ad says it's for the BAsic Stamp.. What is a Basic Stamp? A PIC! Not cheap! $149.00. There are some code examples also that may help you get started. Also MicroElektronica is selling an updated development board (EasyPIC3) with a graphics LCD display available. They have code examples along with the product. Their code is suppose to be easy to convert to PBP.
    BobK
    Apr 2006
    Smile Graphics LCD with different resolutions?
    Hi all,just want to know whether the pic basic pro program can be use to
    program a higher resolution like 320 X 240 Dots LCD Module instead of just
    the standard 128 X 64 Dots GLCD module?If no then is there any other way
    to drive /program those high resolution GLCD?
    Thanks.
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by mesamune80 View Post
    Thanks.
    And yet again, PBP does not have native high level graphic LCD support.
    There's too many types/standard/methods to operate them to combine them all into one inclusive package.
    If you're looking for the easy route, here's something you may want to take
    a look at.
    Just received a few samples of these from the mfg for evaluation.
    http://www.dontronics-shop.com/home.php?cat=371
    I was very impressed when I fired one up. A single I/O-pin is all you need.
    It's like adding a small full-color LCD TV to your project, and controlling it
    with simple serial commands.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Looks impressive indeed! Something to add in my next 'new toy' order i guess.
    Thanks Bruce!
    skimask's Avatar
    skimask Guest
    a look at.
    I'm tellin' ya, between this and mister_e USB example, I just might be single again by the end of the year! either that or broke...or maybe both!
  1. VB.net and Picbasic Pro
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 15th November 2007, 21:18
  2. How to configure SPI in PICBASIC PRO?
    By moogle in forum mel PIC BASIC Pro
    Last Post: - 15th April 2007, 18:31
  3. ICD, ICSP and Picbasic Pro
    By mwhatley in forum mel PIC BASIC Pro
    Last Post: - 30th July 2006, 19:38
  4. Question for all that use MELABS PICBASIC PRO
    By oskuro in forum Off Topic
    Last Post: - 24th March 2005, 18:15
  5. PicBasic Pro & PicBasic syntax different
    By Billyc in forum General
    Last Post: - 16th April 2004, 21:19
Members who have read this thread : 4
