16F627A portA4 problem?
Results 1 to 2 of 2
    Jun 2005
    Question 16F627A portA4 problem?
    I have recently changed from red LEDs to blue LEDs and encountered
    a strange problem on port A4 on a 16F627A. Port A4 is an open drain output
    connected to the LED cathode, the LED anode is connected to 5 vdc via a 1 K resistor. The red LED works as expected but the Blue LED will not turn off
    unless I use a 10 K pullup around the blue LED. The blue LED has a larger
    forward drop than the red and should have a lower current than the red LED.
    Does anybody have any ideas? Am I missing something?
    I defined my I/O and disabled the comparators
    TRISA = %00001100
    TRISB = %00000010
    CMCON=%00000111 ' Comparators OFF
    IF k = 1 Then
    F = $F8
    low portb.0 'turn on LED 1
    low porta.4 'turn on LED 2
    low porta.6 'turn on LED 3
    EndIF
    IF k = 2 Then
    F = $FE
    high porta.4 'turn off LED 2
    high porta.6 'turn off LED 3
    Hi Mark,
    This sounds like it might be a "read-modify-write" problem.
    Maybe you could try using INPUT instead of HIGH to turn off PORTA.4.
    <pre><b>INPUT porta.4 'turn off LED 2</b></pre>
  1. 16F627A to 16F88 conversion problem
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 18th February 2009, 20:20
  2. USART Problem , but don't know where, in pc? or in PIC?
  3. Microcode Studio 18f2455 problem?????
    By volkan in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 22:04
  4. PicBasic Pro Math Problem??
    By Glen65 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 05:36
  5. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
