Blocking problem with 18F252
Results 1 to 3 of 3
    Jul 2005
    Default Blocking problem with 18F252
    hi everybody.
    I have a problem pls look this simple code;
    START:
    IF BUTTON1 = 0 THEN
    GOSUB HEBELE
    GOTO START
    HEBELE:
    I = I + 1
    LCDOUT 254, 200, DEC2 I
    PAUSE 500
    GOSUB HEBELE
    this code is working normally with 16F876 so I can see the values of I variable on my lcd. Like this;
    01, 02, 03 ....... 99, 00, 01 .... etc.
    but when I use 18F252, the program is starting to work normally but when the I variable value is 28 (decimal) the program restarts or the program is blocking. like this;
    01, 02, 03 ...... 28 --> blocking or restart
    Everytime its blocking when the I variable value is 28. I dont know what is the problem? I need your opinions...
    thank you so much
    tegel2's Avatar
    tegel2 Guest
    You need to clear I to zero on initialisation. as I can be up to 255 you are only displaying 2 of the three digits.
    You also have no way out of your Gosub routine.
    Once it gets there there is no way out as you have a gosub to the same gosub !
    It's amazing how many times this has come up recently, hmmm.
    Another Stack overflow that doesn't get found to you switch to an 18F.
    See Bruce's explanation here...
    http://www.picbasic.co.uk/forum/show...=2686#post2686
    <br>
  1. Problem with ASM IRQ using FSR0 on PIC18F252
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 21:48
  2. A/D conversion problem in 18F2520, 2523, 2550 etc.
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 17:26
  3. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 09:12
  4. Hardware problem or what ?
    By Steve S. in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 22:39
  5. 1 slave 1 master 1 MAX232 1 problem ?
    By SuB-ZeRo in forum mel PIC BASIC Pro
    Last Post: - 31st July 2005, 23:59
