Faster SHIFTOUT without dedicated hardware, possible?
Results 1 to 20 of 20
    Default Faster SHIFTOUT without dedicated hardware, possible?
    Hello, I'm driving APA102 LEDs with shiftout, and while for on-off speed is ok, when I want to do some cool and fast color change, speed is not enough.
    So as I understand, SHIFTOUT is just making data pin high-low with required bits, synced with clock pulses, right?
    So maybe there's a code which can do this at faster rate, than shiftout does? without using MSSP, 18F series and so on.
    Aug 2011
    2 out of 2 members found this post helpful. Did you find this post helpful? Yes | No
    Default Re: Faster SHIFTOUT without dedicated hardware, possible?
    Sure.
    Here's some code that would shift out a byte without using asm or anything special... should be much faster than SHIFTOUT since it's format is dedicated and loop is unrolled. Just set WREG to the value to shift out and call SHOUT.
    SHCLK var PORTB.0
    SHDAT var PORTB.1
    ; init pins to output low
    low SHCLK
    low SHDAT
    ; send $55
    WREG = $55
    call SHOUT
    ; send $AA
    WREG = $AA
    call SHOUT
    ; SHOUT
    ; shift out 8 bits of data, LSB to MSB
    ; data clocked on rising edge of SHCLK
    ; WREG = data to send
    SHOUT:
    SHDAT = 0
    if WREG.0 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.1 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.2 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.3 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.4 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.5 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.6 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.7 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    That would be the equivalent of
    SHIFTOUT SHDAT, SHCLK, LSBFIRST, [bval/8]
    Aug 2011
    You may find that routine is actually too fast for the hardware you're controlling.
    If so, you can add NOPs to slow it down a bit...
    SHDAT = 0
    if WREG.0 then
      SHDAT = 1
    asm NOP endasm
    SHCLK = 1
    asm NOP endasm
    SHCLK = 0
    asm NOP endasm
    Thanks, that's great!
    So if we can replace SHIFTOUT with faster code easily, maybe there is a such way for I2CREAD too? without using MSSP module?
    Aug 2011
    I2C operations are slower to begin with, but you could speed things up over the stock routines.
    Having the pins be set in software is what usually slows things down. I've implemented these before and ended up with something around 240KHz with programmable pins.
    Dedicated pins speeds it up a lot... think I got around 400KHz doing it that way (running at 64MHz).
    You have to watch out with the speed and open-drain IO operation to size the pullups as required.
    For faster speeds I like to use active pullups which can really speed up the low-to-high transitions vs using a resistor.
    This works out well when using the MSSP since you can get much faster speeds there.
    Well, I tried to use MSSP, but no luck, so this is why I'm asking.
    Current I2CREAD is too slow, it runs at about 50khz (and is NOT oscillator dependent, as someone stated, I checked with scope, it is around 50khz at 4mhz, 8mhz or 16mhz oscillator speed).
    200Khz would be fine for me. I'm using 24C64 as an external font data storage, and at current speed (50khz), reading 1kb of data takes about 1 second, which does looks cool at certain moment - you see how letters are being drawn on the screen, but absolutely not cool for long-time usage.
    Aug 2011
    which PIC device are you using?
    looking at some old posts, this thread here http://www.picbasic.co.uk/forum/showthread.php?t=5568 has a number of issues.
    Just got to PC today and wanted to run your code, but I have a little problem, my current code looks like this:
    SHIFTOUT SDA, SCK, 0, [$C0+row,col]
    It sends 2 bytes in a row. How should I do the same with your code?
    Aug 2011
    Just send each byte individually... the result will be the same since SHIFTOUT really does it that way too.
    WREG = $C0 + row
    call SHOUT
    WREG = col
    call SHOUT
    If you're using a PIC16 then you'll have to add a definition for a WREG variable
    WREG var byte
    If you wanted to make the code the same for all devices then change all the references to WREG to a byte variable instead, including the SHOUT subroutine.
    Here I've named it SHDATA.
    SHDATA var byte
    SHDATA = $55
    call SHOUT
    Just tried this code and it works, thanks!
    But need to use it for shiftout 1 - MSBFIRST.
    What should be changed in it?
    Aug 2011
    For MSBFIRST, just change the order of the 'WREG.bit' tests
    ; SHOUT
    ; shift out 8 bits of data, MSB to LSB
    SHOUT:
    SHDAT = 0
    if WREG.7 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.6 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.5 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.4 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.3 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.2 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.1 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    SHDAT = 0
    if WREG.0 then
      SHDAT = 1
    SHCLK = 1
    SHCLK = 0
    Thank you again!
    Only today I managed to adapt this code to my hardware and it works very fast!
    But I have a question, WREG is not an variable, but a register name, right?
    Aug 2011
    You're right, for a PIC18 WREG is the name of a register.
    If you're using a PIC16 then you have to declare a variable named WREG as I mentioned in post #9
    WREG var byte
    SHDATA var byte
    SHDATA = $55
    call SHOUT
    It works fine without definition on PIC16F1828.
    In fact, if I add definition, compiler gives an error - Redefiniton of VAR
    This is why I asked
    Aug 2011
    If you're using an enhanced midrange PIC16 device (like the PIC16F1828) then it has a WREG, so it works with them too without having to declare a 'WREG' variable.
    It's only for the older PIC16's you'd have to define it, or just change all the references to WREG to a new variable name of your choice.
    The above code works fine with TM1629A display.
    But it does not work properly with APA102C leds.
    I have the following statement:
    SHIFTOUT di, ci, 1,[224+Bri[x],COLORS[X+16],COLORS[X+8],COLORS[X]]
    Which I have replaced with
    wreg=224+Bri[x]
    gosub shout
    wreg=COLORS[X+16]
    gosub shout
    wreg=COLORS[X+8]
    gosub shout
    wreg=COLORS[X]
    gosub shout
    The issue is that only odd bytes got transferred.
    Say if I set some value to 2 or 4 it gets delivered to LEDs, but if I set it to 1 or 3 or 5 - nothing happens.
    Tried to insert pause between each subroutine call - no difference
    I also tried to add some NOPs as suggested above - no difference.
    Aug 2011
    Don't know what to tell you... the routine transfers any values for WREG so there's no difference between odd/even values.
    Must be some issue with the APA102C timing/format.
    I will hook up scope and check both "versions", to find the possible issue.
  1. Replies: 29
    Last Post: - 20th May 2010, 03:47
  2. Is there a faster way to compare?
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 8th February 2010, 19:48
  3. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 14:44
  4. Is there a faster/better way of doing this?
    By Mad_Labs in forum mel PIC BASIC Pro
    Last Post: - 8th October 2005, 11:01
