SEROUT2 Byte Array In HEX Format
Results 1 to 14 of 14
    Miami, Florida USA
    Default SEROUT2 Byte Array In HEX Format
    Hi, I have an array of 32 bytes. I need to send it to a Bluetooth module in HEX format. The only way I have been able to do it is,
        FOR I = 0 TO 31
            SEROUT2 PORTC.1,84,[HEX2 SquaresArray[I]]
        NEXT I
        SEROUT2 PORTC.1,84,[","]
    I get many missing packages using this code. I get around 1 out of 8 missing packages. If I try the following code, it fails. I get a "Bad expression" error.
    SEROUT2 PORTC.1,84,[hex2 STR SquaresArray\32, ","]
    Any ideas on how I can do this? Thanks.
    Anonymous
    OK
    Default Re: SEROUT2 Byte Array In HEX Format
    You are probably overwriting the TXREG before it's finished sending the previous packet. You didn't mention which PIC you're using, so refer to the appropriate data sheet for the exact Register naming, but something like this:
    FOR I = 0 TO 31
            WHILE TXIF = 0
             WEND
         NEXT I
    No, that can't be it.
    SEROUT and SEROUT2 are bitbanged routines so they don't use the (E)USART and therefor not the TXREG. HSEROUT does use the (E)USART but its smart enough to pace itself as to not overwrite TXREG.
    The receive buffer in the Bluetooth module on the other hand...what if you split the string and send it two chunks with some delay in between?
    What is a package.?
    What else is sent ?
    Are interrupts involved ?
    My best guess is that the trouble is in the code not shown and that snippets are a yet again a pointless waste of time and effort
    Miami, Florida USA
    What is a package.?
    What else is sent ?
    The data package looks like this 432551346666666600000000000000000000000000000000CC CCCCCCA98BB79A,. This is just 32 bytes in HEX format followed by a comma. The comma is just to delimit the packages. There are not interrupts involved. I'm trying to use the following code, but it doesn't work
    Anonymous
    This string is 65 bytes long and has a space after the CC.
    Is that correct?
    Miami, Florida USA
    Hmm, how is that going to help? What amount of delay should I use?
    Anonymous
    Since you don't say which Bluetooth module you're using I can't tell what size the buffer is but if you keep feeding that buffer faster than the module is able to send the data out over the air it will eventually overflow and things happens as a result. As a test try a 1 second delay, if it seems to work you've probably found the cause and can start to think about what to do about it.
    If the Bluetooth module have flow control pins it might be a good option.
    I'm not saying this IS the issue but it's something I'd try.
    Miami, Florida USA
    I'm using an HC-05 module to send data to a PC or cellphone.
    Anonymous
  1. Byte to Hex
    By enigma in forum General
    Last Post: - 11th July 2017, 14:39
  2. Struggling again with SEROUT2 and numbers format
    By Fanias in forum mel PIC BASIC Pro
    Last Post: - 12th April 2014, 05:42
  3. Serial Byte Format
    By mbruno in forum Serial
    Last Post: - 7th February 2008, 14:27
  4. Need help converting to ASCII Hex format
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 26th August 2007, 19:14
  5. Word array behaving like byte array.... wierd
    By forgie in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2005, 15:43
