Programming problem
+ Reply to Thread
Results 1 to 6 of 6
    Apr 2022
    Default Programming problem
    Hi. I'm having trouble programming 18F45K22 micros with the U2 programmer. The HEX file has been used multiple times before but now I get the following error message:
    "Configuration verify error at 0000.
    0200 should be 3200
    Continue verifying?"
    Any ideas
    Mo
    Default Re: Programming problem
    I do not know about the U2 programmer but in similar cases I had to erase first before programming.
    Apr 2022
    Hi. Thanks for the tip.
    I tried it but still no success but what I found was if I erase the chip, then read it back, reload my hex file, then it seems to programme ok.
    Weird. I've been using the Melabs U2 programmer for years and never had to go through that process.
    Mo
    Northeast
    Did you get the latest PBP3.1.5 update? If so, you need to update the U2 software as well. If you did update both, maybe there's a new bug in one of the two.
    I get that same error with my U2 with PIC16F819. The message will either be "Target device does not match specified device", "Configuration verify error at 0000" or "Configuration verify error at 0000 or 0200 should be 3200 Continue verifying?" Except I get different numbers for 0200 and 3200.
    Did you erased it first?
  1. Help - programming problem!
    By George in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2010, 12:52
  2. Re-Programming Problem
    Last Post: - 5th April 2009, 01:25
  3. PIC18F4620 Programming problem
    By JavPar in forum mel PIC BASIC Pro
    Last Post: - 6th December 2008, 04:21
  4. 18F1220 programming problem
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 26th June 2008, 14:03
  5. Problem programming the PIC16F648A
    By Edgardo_2 in forum General
    Last Post: - 29th December 2006, 00:02
