About 0.96" 128x64 SSD1306
Results 1 to 3 of 3
    Aug 2008
    Default About 0.96" 128x64 SSD1306
    Hi
    About 0.96" 128x64 SSD1306 display
    Someone to help me with this code that was posted there for some time it only works when it starts the first time.
    Any help and welcome on this code
    It seems all right to me, isn't it.
        __config _HS_OSC & _WDT_OFF & _PWRTE_OFF & _CP_OFF & _PWRTE_OFF & _LVP_OFF & _WRT_OFF
    ;----[Oscillator Setup]---------------------------------------------------------
    DEFINE OSC 20
    ;----[Initialize Hardware]------------------------------------------------------
    TRISA=%11111111:PORTA=%00000000
    TRISC=%10000000:PORTC=%00000000
    TRISB=%11111111:PORTB=%00000000
    OPTION_REG.7=0
    I2CDevice var byte
    SCL var PortC.3          ' I2C Clock  PortB.4
    SDA var PortC.4          ' I2C Data   PortB.1
    TEXT VAR BYTE[20]
    LENGTH VAR BYTE[2]
    DC VAR Byte              ' "DATA OR COMMAND", $40=DATA; $0=COMMAND --> changed from bit to byte
    LCD_DATA VAR BYTE
    COM VAR BYTE             'COMMAND
                             'PAGE VAR BYTE'LCD PAGE(B0 TO B7)
    I VAR BYTE
    J VAR BYTE
    X VAR BYTE  'LCD POSITION X(0 TO 127)
    Y VAR BYTE  'LCD POSITION Y(0 TO 7)
    CLEAR
    'PAGE = $B0
    I2CDevice = $78      ' X/Y/Z = $3C, Display = $78,
    PAUSE 20
    GOSUB INIT
    GOSUB CLEAR_LCD
    GOSUB TITLE
    MAIN:
        COM=$A6:GOSUB SEND_COMMAND '$A6=NORMAL MODE;$A7=INVERSE MODE
        'PAUSE 100
        COM=$2E:GOSUB SEND_COMMAND
        COM=$27:GOSUB SEND_COMMAND
        COM=$00:GOSUB SEND_COMMAND
        COM=$03:GOSUB SEND_COMMAND
        COM=$04:GOSUB SEND_COMMAND
        COM=$06:GOSUB SEND_COMMAND
        COM=$FF:GOSUB SEND_COMMAND
        COM=$2F:GOSUB SEND_COMMAND
        PAUSE 10000
        GOTO MAIN
    '=========================lcd initialization====================================
    INIT:
        COM=$AE:GOSUB SEND_COMMAND' DISPALY OFF
        COM=$20:GOSUB SEND_COMMAND' HORIZONTAL MODE
        COM=$40:GOSUB SEND_COMMAND' DISPLAY START AT 0
        COM=$A1:GOSUB SEND_COMMAND' REMAP 0-127 ----> Mirror display
        COM=$C8:GOSUB SEND_COMMAND' SCAN DIRECTION
        COM=$DA:GOSUB SEND_COMMAND' COM PINS ------> Not Sure what this does
        COM=$10:GOSUB SEND_COMMAND' COM PINS ------> Not Sure what this does
        COM=$A4:GOSUB SEND_COMMAND' DISPLAY ON
        COM=$A7:GOSUB SEND_COMMAND' $A6=NORMAL MODE;$A7=INVERSE MODE
        COM=$AF:GOSUB SEND_COMMAND' DISPLAY ON
    '==============================clear lcd========================================
    CLEAR_LCD:
        FOR J=0 TO 7
        FOR I=0 TO 127
        LCD_DATA=$00:GOSUB SEND_DATA  ' was $00
        NEXT I
        NEXT J
    '****************SEND COMMAND************************************************
    SEND_COMMAND:
        dc=$0
        I2CWrite SDA,SCL,I2CDevice,DC,[COM]
        dc=$40
    '======================Send data===============================================
    SEND_DATA:
        DC=$40
        I2CWrite SDA,SCL,I2CDevice,DC,[LCD_DATA]
    '=============================FILL=============================================
    FILL:
        FOR J=0 TO 7
        FOR I=0 TO 127
        LCD_DATA=$FF:GOSUB SEND_DATA
        NEXT I
        NEXT J
    '=========================TITLE=================================================
    TITLE:
        X=0:Y=0 :GOSUB SET_XY
        FOR I=0 TO 127
        LOOKUP I,[$00,$40,$60,$50,$7E,$50,$60,$40,$02,$06,$0E,$1E,$3E,$00,$00,$00,_
        $00,$00,$00,$00,$00,$1F,$3F,$60,$60,$60,$60,$60,$60,$3C,$1C,$00,_
        $00,$7F,$7F,$61,$61,$61,$61,$61,$61,$3F,$1E,$00,$00,$1E,$3F,$61,_
        $61,$61,$61,$61,$61,$38,$18,$00,$00,$00,$00,$00,$00,$00,$00,$00,_
        $00,$00,$00,$00,$00,$00,$00,$1F,$3F,$60,$60,$60,$60,$60,$60,$3C,_
        $1C,$00,$00,$1E,$3F,$61,$61,$61,$61,$61,$61,$38,$18,$00,$00,$3F,_
        $7F,$60,$18,$06,$06,$18,$60,$7F,$3F,$00,$00,$00,$00,$00,$00,$00,_
        $00,$00,$00,$1C,$63,$41,$5D,$41,$5D,$41,$5D,$41,$5D,$41,$7F,$00],LCD_DATA
        lcd_data=lcd_data rev 8
        GOSUB SEND_DATA
        NEXT I
        X=0:Y=1 :GOSUB SET_XY
        for i=0 to 127
        lookup i,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,_
        $00,$00,$00,$00,$00,$F8,$FC,$06,$06,$06,$C6,$C6,$C6,$FC,$F8,$00,_
        $00,$FE,$FE,$80,$80,$80,$80,$80,$80,$00,$00,$00,$00,$18,$1C,$86,_
        $86,$86,$86,$86,$86,$FC,$78,$00,$00,$00,$00,$00,$00,$00,$00,$00,_
        $00,$00,$00,$00,$00,$00,$00,$F8,$FC,$06,$06,$06,$C6,$C6,$C6,$FC,_
        $F8,$00,$00,$18,$1C,$86,$86,$86,$86,$86,$86,$FC,$78,$00,$00,$FE,_
        $FE,$00,$00,$00,$00,$00,$00,$FE,$FE,$00,$00,$00,$00,$00,$00,$00,_
        $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00],lcd_data
        GOSUB SEND_DATA
        NEXT I
        X=0:Y=3:GOSUB SET_XY
        for i=0 to 127
        lookup i,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$3C,$7E,$C3,$C3,$C3,$C3,_
        $C3,$C3,$71,$30,$00,$00,$7F,$FF,$C3,$C3,$C3,$C3,$C3,$C3,$C3,$C3,_
        $00,$00,$7F,$FF,$C1,$C1,$C1,$C1,$C1,$C1,$FF,$7F,$00,$00,$7F,$FF,_
        $C3,$C3,$C3,$C3,$C3,$C3,$7E,$3C,$00,$00,$3F,$7F,$C0,$C0,$C0,$C0,_
        $C0,$C0,$70,$30,$00,$00,$FF,$FF,$03,$03,$03,$03,$03,$03,$FF,$FF,_
        $00,$00,$C0,$C0,$C0,$C0,$FF,$FF,$C0,$C0,$C0,$C0,$00,$00,$FF,$FF,_
        $0C,$0C,$03,$03,$00,$00,$FF,$FF,$00,$00,$3F,$7F,$C0,$C0,$C0,$C1,_
        $C1,$C1,$79,$39,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00],lcd_data
        GOSUB SEND_DATA
        NEXT I
        X=0:Y=4:GOSUB SET_XY
        for i=0 to 127
        lookup i,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$30,$38,$0C,$0C,$0C,$0C,_
        $0C,$0C,$F8,$F0,$00,$00,$F8,$FC,$0C,$0C,$0C,$0C,$0C,$0C,$0C,$0C,_
        $00,$00,$FC,$FC,$80,$80,$80,$80,$80,$80,$FC,$FC,$00,$00,$FC,$FC,_
        $80,$C0,$60,$30,$18,$0C,$04,$00,$00,$00,$F0,$F8,$0C,$0C,$0C,$0C,_
        $0C,$0C,$38,$30,$00,$00,$FC,$FC,$00,$00,$00,$00,$00,$00,$FC,$FC,_
        $00,$00,$0C,$0C,$0C,$0C,$FC,$FC,$0C,$0C,$0C,$0C,$00,$00,$FC,$FC,_
        $00,$00,$00,$00,$C0,$C0,$FC,$FC,$00,$00,$F0,$F8,$0C,$0C,$0C,$8C,_
        $8C,$8C,$F8,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00],lcd_data
        GOSUB SEND_DATA
        NEXT I
        X=0:Y=5:GOSUB SET_XY
        for i=0 to 127
        lookup i,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$1F,$3F,$30,$30,$30,$30,_
        $30,$30,$30,$30,$00,$00,$0F,$1F,$30,$30,$30,$30,$30,$30,$1F,$0F,_
        $00,$00,$1F,$3F,$30,$30,$30,$30,$30,$30,$1F,$0F,$00,$00,$00,$00,_
        $00,$00,$00,$0F,$1F,$30,$30,$30,$30,$30,$30,$1C,$0C,$00,$00,$30,_
        $30,$30,$30,$3F,$3F,$30,$30,$30,$30,$00,$00,$0F,$1F,$30,$30,$30,_
        $30,$30,$30,$1E,$0E,$00,$00,$3F,$3F,$03,$03,$00,$00,$00,$00,$3F,_
        $3F,$00,$00,$1F,$3F,$30,$30,$30,$30,$30,$30,$3F,$1F,$00,$00,$3F,_
        $3F,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00],lcd_data
        GOSUB SEND_DATA
        NEXT I
        X=0:Y=6:GOSUB SET_XY
        for i=0 to 127
        lookup i,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$FF,$FF,$C0,$C0,$C0,$C0,_
        $C0,$C0,$00,$00,$00,$00,$FC,$FE,$03,$03,$03,$03,$03,$03,$FE,$FC,_
        $00,$00,$FF,$FF,$E0,$F0,$D8,$CC,$C6,$C3,$81,$00,$00,$00,$00,$00,_
        $00,$00,$00,$0C,$8E,$C3,$C3,$C3,$C3,$C3,$C3,$7E,$3C,$00,$00,$03,_
        $03,$03,$03,$FF,$FF,$03,$03,$03,$03,$00,$00,$FC,$FE,$03,$03,$03,_
        $63,$63,$63,$7E,$7C,$00,$00,$FF,$FF,$00,$00,$C0,$C0,$30,$30,$FF,_
        $FF,$00,$00,$FF,$FF,$60,$60,$60,$60,$60,$60,$FF,$FF,$00,$00,$FF,_
        $FF,$03,$03,$03,$03,$03,$03,$03,$03,$00,$00,$00,$00,$00,$00,$00],lcd_data
        GOSUB SEND_DATA
        NEXT I
    '===========================================SET X AND Y=========================
    SET_XY:
        COM=$21:GOSUB SEND_COMMAND
        COM=X:GOSUB SEND_COMMAND
        COM=127:GOSUB SEND_COMMAND
        COM=$22:GOSUB SEND_COMMAND
        COM=Y:GOSUB SEND_COMMAND
    Default Re: About 0.96" 128x64 SSD1306
    Your main loop is this:
    MAIN:
        'PAUSE 100
        PAUSE 10000
        GOTO MAIN
    According to this lines, it should send the commands, wait 10sec and then ... END! Meaning the PIC enters an endless loop for ever. So, it realy does what you wanted to do!
    Maybe you wanted to do the above of MAIN series of GOSUB's?
    Ioannis.
    Aug 2008
    Ioannis.
    It is already running
    Thank you for your answer
    peace
  1. SSD1306 INCLUDE for PBP3
    By richard in forum PBP3
    Last Post: - 23rd February 2024, 19:47
  2. SSD1306 Include example
    By timc in forum Code Examples
    Last Post: - 28th November 2017, 09:53
  3. SSD1306 start display problem
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 14th December 2016, 20:16
  4. Replies: 0
    Last Post: - 14th November 2013, 04:32
  5. Help With OLED Display / 128X64 SSD1306
    By Denner in forum General
    Last Post: - 25th May 2013, 16:40
