Anyone used smart leds with APA102/SK9822 controller, with Picbasic ?
+ Reply to Thread
Results 1 to 4 of 4
    Default Anyone used smart leds with APA102/SK9822 controller, with Picbasic ?
    Hello.
    These leds while delivering neopixel led like functionality, run on more common, SPI interface, with much more relaxed timing requirements. So they should be easier to use.
    Search delivers no results, does anyone tried to used them with PBP?
    Mar 2016
    Default Re: Anyone used smart leds with APA102/SK9822 controller, with Picbasic ?
    Hello.
    I use them a lot. Easy to use in PBP, here some test blinks:
    '*  Name    : APA LED                                           *
    '*  Author  : Louis                                             *
    '*  Notice  : Copyright (c) 2020                                *
    '*  Date    : 7. 10. 2020                                       *
    '*          : PIC 12F1840                                       *
      __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_ON
      __config _CONFIG2, _WRT_OFF & _PLLEN_ON & _STVREN_ON & _BORV_19 & _LVP_OFF
    DEFINE OSC 4                ; Use internal clock 4MHz
    OSCCON  = %01101010         ; 4 MHz internal
    OSCTUNE	= %00000000	        ; Internal osc tunning
    WHILE !OSCSTAT.3	; Wait for stable OSC
    WEND
    TRISA = %100100             ; RA.2, RA.5 input rest output
    ANSELA = %00000
    OPTION_REG.7=1              ; disable internal pull-ups
    INCLUDE "modedefs.bas"
    di       var porta.1
    ci       var porta.4
    r var byte
    g var byte
    b var byte
    n var byte
    nn var byte
    cyc var byte
    clear
    gosub clear_strip           ; clear strip
    gosub white_fade
    gosub police_blink
    gosub color_blink
    gosub Orange_Breathe
    gosub Red_flicker
    ; -------     BLINK CODES      --------
    police_blink:
    gosub clear_strip
    led:
    gosub start_frame
    for nn=0 to 2
    gosub start_frame
    r=250:g=0:b=0:SHIFTOUT di, ci, 1, [%11100111,b,g,r]
    r=0:g=0:b=0:SHIFTOUT di, ci, 1, [%11100111,b,g,r]
    gosub start_frame
    pause 30
    gosub clear_strip
    pause 30
    next nn : nn=0
    for nn=0 to 2
    gosub start_frame
    r=0:g=0:b=250:SHIFTOUT di, ci, 1, [%11100111,b,g,r]
    gosub start_frame
    pause 30
    gosub clear_strip
    pause 30
    next nn : nn=0
    ; --------- END of police Blink ----------
    ; ---------   Color Blink ----------
    color_blink:
    gosub clear_strip
    leds:
    gosub start_frame
    for nn=0 to 5
    gosub start_frame
    r=150:g=50:b=0:SHIFTOUT di, ci, 1, [%11100111,b,g,r]
    gosub start_frame
    pause 30
    gosub clear_strip
    pause 30
    next nn : nn=0
    for nn=0 to 5
    gosub start_frame
    r=0:g=50:b=10:SHIFTOUT di, ci, 1, [%11100111,b,g,r]
    r=0:g=200:b=0:SHIFTOUT di, ci, 1, [%11100111,b,g,r]
    gosub start_frame
    pause 30
    gosub clear_strip
    pause 30
    next nn : nn=0
    ; --------- END of color Blink ----------
    ; ---------      White Fade     ----------
    white_fade:
    gosub clear_strip
    gosub start_frame
    lit_up:
    for nn=0 to 3
    r=255:g=255:b=255:SHIFTOUT di, ci, 1, [%11100111,b,g,r]
    next nn : nn=0
    gosub start_frame
    for cyc = 0 to 254
    r=r-1:g=g-1:b=b-1
    for nn=0 to 3
    next nn : nn=0
    gosub start_frame
    next cyc  : cyc=0
    ; --------- END of White Fade ---------
    ; ---------   Orange Breathe  ---------
    Orange_Breathe:
    gosub clear_strip
    gosub start_frame
    for cyc = 0 to 24
    pause 30
    r=r+10:g=g+1:b=0
    for nn=0 to 3
    next nn : nn=0
    gosub start_frame
    next cyc : cyc=0
    pause 300
    for cyc = 0 to 24
    pause 30
    r=r-10:g=g-1:b=0
    for nn=0 to 3
    next nn : nn=0
    gosub start_frame
    next cyc  : cyc=0
    glow_up:
    gosub start_frame
    for nn=0 to 4
    r=10:g=0:b=0:SHIFTOUT di, ci, 1, [%11100111,b,g,r]
    next nn : nn=0
    ; ------- END of Orange Breathe -------
    ; ---------      Red flicker     ----------
    Red_flicker:
    gosub clear_strip
    gosub start_frame
    flicker:
    for nn=0 to 3
    r=255:g=0:b=0:SHIFTOUT di, ci, 1, [%11100111,b,g,r]
    next nn : nn=0
    gosub start_frame
    for cyc=0 to 10
    gosub start_frame
    for nn=0 to 3
    next nn : nn=0
    pause 50
    gosub clear_strip
    pause 50
    next cyc : cyc=0
    ; --------- END of Red flicker  ---------
    ; --------- Blink subroutines ----------
    start_frame:
    SHIFTOUT di, ci, 1, [%00000000,%00000000,%00000000,%00000000]
    clear_strip:
    for n=0 to 4
    r=0:g=0:b=0
    next n : n=0
    ; ---------- END of Blink Subroutines -----------
    Thanks!
    Will order some and let them go
    Tried it now with single led, it works!
    Thanks again
  1. Replies: 0
    Last Post: - 5th June 2012, 08:43
  2. Clock for smart card
    By aherrera in forum mel PIC BASIC Pro
    Last Post: - 24th August 2011, 16:34
  3. Smart Cards
    By lester in forum Adverts
    Last Post: - 21st July 2004, 17:30
  4. rs485 to rs232 smart switch
    By RSSHARPE in forum mel PIC BASIC Pro
    Last Post: - 17th June 2004, 08:44
  5. Smart Card Envelope
    By Art in forum Schematics
    Last Post: - 8th August 2003, 19:15
