My code for ADC button handling, it works, but can it be slimmed down?
Results 1 to 28 of 28
    Default My code for ADC button handling, it works, but can it be slimmed down?
    Hello,
    This is my code for handling two buttons connected to ADC input.
    It works fine, and what was most important, it prevents repeated key action -
    user has to release the button and press it again, to call needed action again.
    However, there are quite a lot of variables, and their number will double with
    more buttons being added.
    So maybe there is a way to make it simpler, while still maintaining
    "do not repeat action" functionality?
    menu: 'main loop for button handling
    adcin 1, adcval   'read keys
    if adcval=255 then n1=0: n2=0: left=0: right=0  'if no key, then reset both button variables
    if adcval<10 then left=left+1 'detect button presses
    if adcval>100 and adcval <130 then right=right+1 'detect button presses
    if left>100 and n1=0 then 'if button pressed enough and it was not pressed before
    left=0
    n1=1
    gosub action1 'button 1 tasks
    if right>100 and n2=0 then 'if button pressed enough and it was not pressed before
    right=0
    n2=1
    gosub action2 'button 2 tasks
    pause 1 'input delay
    goto menu
    OK
    Default Re: My code for ADC button handling, it works, but can it be slimmed down?
    SELECT CASE adcval
      CASE < 10 : left=left+1 'detect button presses
      CASE < 100
    @ NOP
      CASE < 130 : right=right+1 'detect button presses
    END SELECT
    You might try the SELECT CASE method of parsing through. The above snippet should give you an idea.[/FONT]
    Thanks!
    My main concern is number of variables needed...
    code snippets do not provide any where near the required info to provide a meaningful answer, not even one var definition is even provided
    for a meaningful answer
    1 how often is routine called
    2 is it called on a regular timed basis
    3 how responsive does it need to be
    the minimum key data necessary would be a count to detect a debounced press a bit to indicate a new press detected and a bit to indicate
    the press has been acknowledged and acted on provided the right conditions exist
    1. At least 10 times per second.
    2. Yes
    3. As responsive as any other device, where user presses key and expects immediate feedback.
    if right>100
    so button has to held for ten seconds till you get a response ?
    not in my book, i doubt the thing is working after 300mS
    2. Yes
    like how regular how often really
    Why not use the genuine BUTTON command ?????????????????
    of course, needs some "brainwork" and practise - and of course at least " read that f...... manual " ... "
    but the result is worth the effort ...
    " Just my two cents " ...
    Read 1st post 1st
    This is ADC input.
    Read 1st post 1st
    This is ADC input.
    ADC for ONLY two buttons and " immediate response " ( sic ) ??? ...
    if it's your choice ... go on ! ( ) ...
    adc key reading is a good tried and tested technique and can be very responsive, the question here is can it be done
    using less memory. the answer is yes of course, if done in a methodical way.
    c1 has opted not to discuss or elaborate on his implementation in any meaningful way. end of story
    This is just an example for 2 buttons
    for 20 buttons there should be 40 variables
    I wanted to avoid that
    this is why I asked
  1. Long / short press button...but reading ADC
    Last Post: - 10th July 2016, 08:37
  2. Replies: 42
    Last Post: - 18th March 2012, 23:02
  3. How come my DS18S20 code still works?
    By Wilson in forum mel PIC BASIC Pro
    Last Post: - 30th July 2011, 02:59
  4. 12 bit or higher ADC on a PIC that works with PBP?
    By Brandon in forum mel PIC BASIC Pro
    Last Post: - 11th November 2007, 17:19
  5. ADC -how it works?, pic -
    By matias in forum mel PIC BASIC Pro
    Last Post: - 13th March 2007, 21:54
