"WAIT" modifier with multiple choices - how to?
Results 1 to 12 of 12
    SWITZERLAND (french speaking)
    Default "WAIT" modifier with multiple choices - how to?
    Hi There,
    I'm wondering if it is possible to "WAIT" for more than only one condition at the time in DEBUGIN/SERIN2.
    I usually write something like this:
    START:
    DEBUGIN 1000,START,[WAIT("first")]
    I'd like to wait for more than the word "first" but also for "second" and "third".
    But how?
    Roger
    Default Re: "WAIT" modifier with multiple choices - how to?
    Yes you can. But maybe you can give an example of what you want?
    My circuit has a serial data receiver; it "waits" for three different sets of characters (= commands) to perform different actions, one at the time.
    If "READ" is received, it will do this; if "WRITE" is received, it will do that and so for the third command, "COPY".
    Voilą how I imagine it should be working (this is obviously not the actual code, just the idea of what it should be doing):
    START:
    DEBUGIN 1000,START,[WAIT("READ" OR "WRITE" OR "COPY")]
    IF "READ" DO...
    IF "WRITE" DO...
    IF "COPY" DO...
    I need to "wait" for either incoming command but there's where I'm stuck in the DEBUGIN/SERIN2 timeout loop.
    Due to my lack of knowledge, I have to make my circuit currently doing only one thing...frustrating
    Roger
    OK
    My approach would be to just receive whatever comes in, then parse it later.
    + 1
    though life would be easier if
    "READ" became "*READ/n" ditto for the others {/n=chr 13
    buff var byte[5]
    DEBUGIN 1000,START,[WAIT("*" str buff\5\13]
    then see what you got
    Great! I'll give it a try.
    Thanks a lot
    Roger
    Thanks again Richard
    '======= VARIABLES ================================================================================
    InString VAR BYTE[3]
    LED      VAR RC2
    Counter  VAR BYTE
    Blinks   VAR BYTE
    '======= INITIALIZE VARIABLES =====================================================================
    InString[0] = 0
    InString[1] = 0
    InString[2] = 0
    LED         = 0
    Counter     = 0
    Blinks      = 0
    '======= PROGRAM ==================================================================================
    ' Wait for strings:
    ' *AAA# = 1 blink
    ' *BBB# = 2 blinks
    ' *CCC# = 3 blinks
    START:
    Blinks      = 0
        DEBUGIN 1000,START,[WAIT("*"), STR InString\3\35] ' InString starts with "*" and ends with "#"
        if InString[0] = 65 then
            if InString[1] = 65 then
                if InString[2] = 65 then
                    Blinks = 1
        if InString[0] = 66 then
            if InString[1] = 66 then
                if InString[2] = 66 then
                    Blinks = 2
        if InString[0] = 67 then
            if InString[1] = 67 then
                if InString[2] = 67 then
                    Blinks = 3
    BLINK:
        FOR Counter = 1 to Blinks
            LED = 1
            PAUSE 500
            LED = 0
            PAUSE 500
        NEXT Counter
        GOTO START
    Roger
    that will do it roger
    this might be a little bit faster as only one value of instring[0] can ever be true at any one time
    select case InString[0]
        case = 65 ;    ps you can use case = "A" to make it more readable
                    Blinks = 1
       case 66
                    Blinks = 2
       case 67
                    Blinks = 3
    END select
    Thanks for the tip, Richard
    Using a 16F630 for this project, I'm quite limited in program size.
    I tried something like this too:
    IF InString[0] = 65 AND InString[1] = 65 AND InString[2] = 65 THEN Blinks = 1
    IF InString[0] = 66 AND InString[1] = 66 AND InString[2] = 66 THEN Blinks = 2
    IF InString[0] = 67 AND InString[1] = 67 AND InString[2] = 67 THEN Blinks = 3
    But, if I recall well, this code is around 80 words larger than the nested IF..THEN conditions.
    And as far as I can remember, SELECT CASE is also quite word consuming. I'll still give it a try later...
    Roger
    The AND in the If statement is really memory hungry.
    Long ago, our member Melanie posted this great test program parsing strings and executing commands from a terminal through serial port, with no interrupts in a fast closed loop. It had great structure and expanding possibilities.
    Have a look here for the comms1.bas program: http://www.picbasic.co.uk/forum/show...=2078#post2078
    also, might need a real chip though. 64 bytes for serial work is a challenge
    16f1825 or 16f18326 vs 16f630 price difference trivial performance and resources difference enormous , just saying.
    an asm routine can do a string compare much more efficiently if you have a chip with two fsr's but the old clunkers
    don't have that either. its a difficult path with meagre resources.
    all good fun though.
    InString VAR BYTE[4]
    InString[3]=1
    ARRAYREAD InString, 4, ncb, [WAIT ("AAA"),Blinks]
    goto ncx
    ncb:
    InString[3]=2
    ARRAYREAD InString, 4, ncc, [WAIT ("BBB"),Blinks]
    goto ncx
    ncc:
    InString[3]=3
    ARRAYREAD InString, 4, ncd, [WAIT ("CCC"),Blinks]
    goto ncx
    ncd:
    Blinks=0
    ncx:
    other option is a if elseif chain , not sure anymore which used least ram,flash
  1. How to do the "SerIN" and "SerOut " for the usb ?
    By vicce67 in forum mel PIC BASIC Pro
    Last Post: - 13th March 2015, 02:01
  2. Replies: 0
    Last Post: - 14th November 2013, 03:32
  3. Replies: 3
    Last Post: - 15th October 2012, 08:06
  4. Multiple "AND"'s in select case?
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 1st January 2010, 19:10
  5. Replies: 1
    Last Post: - 16th February 2005, 20:05
