How to remove ghost directory from mocrocode studio
Results 1 to 7 of 7
    Feb 2012
    PERTH AUSTRALIA
    Default How to remove ghost directory from mocrocode studio
    Hi Guys
    Been doing some clean up of old installations of PBP
    , however code studio still see them when clicking "view" then "compile and program options "then " find manually " , where it then allows for the selection of the PICBasic compiler and assembly directory
    can someone advise how fix the selection window , so that the deleted directories are not shown in the selection panel
    Sheldon
    OK
    Default Re: How to remove ghost directory from mocrocode studio
    Not is a position to try it right now, but for a lot of programs, just click on it. It may come back and say, "Not Found" (or something like that). "Do you want to delete it from your registry?" Worth a try.
    Hi, Sheldon
    there's a nice little program called CCleaner that ... cleans all the unwanted "deposits" and old registry entries from your computer ...
    note you can also keep chosen cookies for your favourite forums or web pages ...
    https://www.ccleaner.com/ccleaner/download the free version is enough for most users ...
    Feb 2012
    PERTH AUSTRALIA
    hi , yes used cccleaner , , even used regedit to remove all detail that i could find for the prev revs of the pbp i wanted to remove rebooteted etc , then reinstalled the versions i want to keep , in their own directory
    but code studio continues to show the removed directories , when the versions i want to have are reinstalled
    would love to know exactly where it is getting the info that makes up the listing for the manual selection , as that location needs to be cleared and regenerated
    i know its no big deal to have the incorrect listing and you just select the correct one , but , the incorrect listing should be able to be fixed and i spent a few hours hand cleaning the registary and it still not a simple fix , so far
    probally needs charles to advise exactly how it get the listing it presents and how/where it stored , to be able to correct it
    also notice the directoy listing also includes all hidden directories within the list as well
    cheers
    Maybe you need to do a scandisk check of the specific drive. And let it fix any issues.
    I do not think this problem is relevant to PBP, but to MCS ( Mecanique )
    you could drop some lines here https://www.mecanique.co.uk/shop/ind...mation/contact
    Feb 2012
    PERTH AUSTRALIA
    thanks ill contact them
  1. The source directory is read only!!!!!!!!!
    By powerelect in forum mel PIC BASIC Pro
    Last Post: - 30th July 2012, 11:49
  2. A way to remove lookup tables and calculate those values?
    By sccoupe in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2011, 02:47
  3. edit or remove post
    By delta_boogie in forum mel PIC BASIC Pro
    Last Post: - 19th December 2008, 19:45
  4. Can't remove code protection of 16F88!!!
    Last Post: - 22nd December 2006, 13:18
  5. help to compile from a different directory of pbp.exe
    By cirknop in forum mel PIC BASIC Pro
    Last Post: - 9th July 2004, 21:39
