Audio player
Results 1 to 14 of 14
Thread: Audio player
    Default Audio player
    I have a request for an audio player. The 12 audio files will be stored in a SD card (either mp3 or wav).
    Each file will be 30 sec long and after user selection, it will be played in a loop.
    All these are easy to implement with a DF Player and a PIC.
    But we need the files to be locked so that cannot be copied from the SD card and played in another player from ours.
    Any ideas welcome.
    OK
    Default Re: Audio player
    I don't think you can encrypt an SD card. A password filter may be all you need. The bigger you make it, the better. I know Microchip offers specialty security chips that could be added to your PIC project with random number generation and so forth. You may also simply increment all values by one, and on the read side, decrement all values by 1 so it comes out garbled without that translation.
    Thank you Mike.
    I know that Microchip has an encrypted, or so, unique serial number in some PICs but could not find that info in the parametric search. I can't recall how it is called.
    esp8266 , audio in littlefs partition in flash would nail it, files can be modified with simple https browser i/f
    on the devices own self generated access point
    You mean ESP with in Arduino IDE, which needs good grasp of C, right?
    I do not feel very confident on that IDE for a client project.
    Thanks though,
    Bombay, India
    Depending on the samples and quality, you may find that you need quite a bit of storage (SD card with SDIO interface). The power of the PIC to handle raw samples may be severely short to get a reasonable output. I suggest you look at the VS1003B MP3 chips that you can throw the samples at. This way, you do not need too much processing on the PIC.
    another option you can evaluate is available on http://elm-chan.org/works/sd8p/report.html
  1. WTV020-SD-20SS SD Card U Disk Audio Player Interface
    By andybarrett1 in forum mel PIC BASIC Pro
    Last Post: - 4th March 2018, 04:48
  2. MP3 Player Using VS1011
    By lindomar in forum mel PIC BASIC Pro
    Last Post: - 28th October 2009, 20:26
  3. DVD Player Remote Control
    By koossa in forum Off Topic
    Last Post: - 1st January 2009, 11:35
  4. Build your own CD player for under $20
    By T.Jackson in forum Off Topic
    Last Post: - 12th November 2007, 15:27
  5. is there cd player code in picbasic
    By mech in forum mel PIC BASIC Pro
    Last Post: - 5th December 2006, 20:43
