issue PBP compile with win10
+ Reply to Thread
Results 1 to 5 of 5
    Dec 2021
    Default issue PBP compile with win10
    Hi All
    i have problem to compile with pbp3.1 with windows10 in my two computers laptop and desktop.
    when i compiling i got message - "The source directory is reed only"
    i try to all solutions including Microsoft support ,reinstall windows , no results .
    i use pbp many years and never meet this problem.
    this problem start before 10 days
    any one meet such problem ?
    Eyal
    Northeast
    Default Re: issue PBP compile with win10
    Is this message stopping anything from working? If it's just a "Message", I wouldn't worry about it. There's usually a "Message" about how HPWM only works with CCPx modules, and so forth. A "Warning" or an "Error" is something different, and should be looked into.
    Of all the things you've tried, have you tried moving the source folder? If not, try putting it in your documents folder.
    +1 ...
    re-install PBP in another place : here it is placed ( by itself ) in " C: Programs ( x86 ) " for years ... but you can create a " C: PBP " folder ( i.e.) ... where you can also place all PBP documentation, datasheets, basic programs ... projects ... etc.
    Reinstalling PBP is not what I'm suggesting.
    Simply moving the folder where the source files are located should be enough.
    If you've switched computers and restored your source files from a backup it's POSSIBLE that the folders read-only flag is set, worth checking.
  1. PBP 3 will not compile
    By grahamg in forum PBP3
    Last Post: - 7th August 2016, 11:12
  2. VAR array compile issue
    Last Post: - 29th March 2012, 14:47
  3. PBP v2.60 upgrade: MCSP compile issue
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2009, 20:49
  4. Cannot get pbp to compile
    By [email protected] in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2009, 17:24
  5. Weird compile issue 7 segment LED display
    By George in forum mel PIC BASIC Pro
    Last Post: - 21st June 2006, 03:12
