18F45K22 timer/counter
Results 1 to 3 of 3
    Feb 2005
    brookfield, ct, usa
    Default 18F45K22 timer/counter
    Good evening all.
    I'm trying to enable timer 3 and timer 5 as counters, and clearly I have something wrong. I can't write to them to zero them out, and they don't count. Reading the datasheet as well as other examples this should be easy, I'd appreciate any help anyone can provide.
    '* Name : Counter_test_1 *
    '* Author : Alec Noble *
    '* Notice : Copyright (c) 2021 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 9/12/2021 *
    '* Version : 1.0 *
    '* Notes : *
    '********************DEVICE CONFIGURATION**********************************
    CONFIG FOSC = INTIO67 ; Internal oscillator block
    CONFIG PLLCFG = OFF ; Oscillator used directly
    CONFIG PRICLKEN = OFF ; Primary clock can be disabled by software
    CONFIG FCMEN = OFF ; Fail-Safe Clock Monitor disabled
    CONFIG IESO = OFF ; Oscillator Switchover mode disabled
    CONFIG PWRTEN = OFF ; Power up timer disabled
    CONFIG BOREN = SBORDIS ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
    CONFIG BORV = 190 ; VBOR set to 1.90 V nominal
    CONFIG WDTEN = ON ; WDT is always enabled. SWDTEN bit has no effect
    CONFIG WDTPS = 32768 ; 1:32768
    CONFIG CCP2MX = PORTC1 ; CCP2 input/output is multiplexed with RC1
    CONFIG PBADEN = OFF ; PORTB<5:0> pins are configured as digital I/O on Reset
    CONFIG CCP3MX = PORTB5 ; P3A/CCP3 input/output is multiplexed with RB5
    CONFIG HFOFST = ON ; HFINTOSC output and ready status are not delayed by the oscillator stable status
    CONFIG T3CMX = PORTC0 ; T3CKI is on RC0
    CONFIG P2BMX = PORTD2 ; P2B is on RD2
    CONFIG MCLRE = EXTMCLR ; MCLR pin enabled, RE3 input pin disabled
    CONFIG STVREN = ON ; Stack full/underflow will cause Reset
    '*************************DEFINEs***************** **************************
    DEFINE OSC 16 ' Tell PBP the expected systemclock frequency
    OSCCON = %01110010
    OSCCON2 = %00000100
    ' LCD settings
    ' Set LCD Data port
    DEFINE LCD_DREG PORTB
    ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 0
    ' Set LCD Register Select port
    DEFINE LCD_RSREG PORTB
    ' Set LCD Register Select bit
    DEFINE LCD_RSBIT 4
    ' Set LCD Enable port
    DEFINE LCD_EREG PORTB
    ' Set LCD Enable bit
    DEFINE LCD_EBIT 5
    ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_BITS 4
    ' Set number of lines on LCD
    DEFINE LCD_LINES 2
    ' Set command delay time in us
    DEFINE LCD_COMMANDUS 1500
    ' Set data delay time in us
    DEFINE LCD_DATAUS 44
    ANSELA = 0 'all I/O digital
    ANSELB = 0
    ANSELC = 0
    ANSELD = 0
    ANSELE = 0
    TRISA = 0 'PortA all outputs
    TRISB = 0 'PortB all outputs
    TRISC = $FF 'PortC all inputs
    T3CON = %10000111 'timer 3 source pin or osc, 1:1 prescale, secondary osc disabled, not synchronized, 16 bit operation, timer enabled
    T5CON = %10000111 'timer 5 source pin or osc, 1:1 prescale, secondary osc disabled, not synchronized, 16 bit operation, timer enabled
    '********************aliases********************** *************
    Counter_1 var word
    Counter_2 var word
    reset var PortC.7
    '********************inititialization************* *************
    LCDOUT $FE, $01
    LCDout $FE, $80, "hello world"
    pause 5000
    LCDOUT $FE, $01
    TMR3H = $00 'zero both counters
    TMR3L = $00
    TMR5H = $00
    TMR5L = $00
    '*******************program*********************** **************
    TMR3L = Counter_1.LOWBYTE
    TMR3H = Counter_1.highbyte
    TMR5L = Counter_2.lowbyte
    TMR5H = Counter_2.highbyte
    lcdout $FE, $80, DEC5 counter_1
    lcdout $FE, $C0, dec5 Counter_2
    if reset = 0 then
    LCDOUT $FE, $01
    pause 50
    lcdout $FE, $80, "hold to clear"
    pause 2500
    if reset = 0 then
    TMR3H = 0 'zero both counters
    TMR3L = 0
    TMR5H = 0
    TMR5L = 0
    'while reset = 0 | wend
    LCDOUT $FE, $01
    pause 50
    pause 250
    Thanks to all in advance
    Take care, stay safe and talk to you soon
    Alec
    Default Re: 18F45K22 timer/counter
    late night programming ?
    try
     Counter_1.LOWBYTE =TMR3L
     Counter_1.highbyte =TMR3H
     Counter_2.lowbyte =TMR5L
     Counter_2.highbyte =TMR5H
    Feb 2005
    brookfield, ct, usa
    Damn, I knew it was something simple but my eyes kept going over it!
    Now that it works time to complicate it. Thank you very much!
  1. 18F45K22 Pull Up on PortE
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 20th December 2015, 21:34
  2. Internal pullups on 18F45K22
    By Experimenter in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2014, 20:13
  3. timer/counter questions
    By missouri100 in forum mel PIC BASIC Pro
    Last Post: - 7th April 2011, 12:01
  4. Replies: 1
    Last Post: - 27th September 2007, 19:15
  5. Need help with Counter/Timer application
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 6th September 2006, 05:48
