Handling a lot of text data, any simple and practical ways?
Results 1 to 20 of 20
    Default Handling a lot of text data, any simple and practical ways?
    Hello.
    I had a Noritake VFD module lying around, and decided to make a clock out of it.
    Since it is HD47780 compatible, there were no issues for main display code, as you can see from the attached picture.
    And since this is 2x20 lines display, it is logical that for clock setup menu I'd like to use text, rather than icons or numbers.
    This is the text strings I'd like to use in the setup menu.
    Set Year
    Set Month
    Set Date
    Set day of week
    Set Hour
    Set Minute
    Set alarm mode
    Off
    On all week
    On without weekends
    Set alarm hours
    Set alarm minutes
    Set display format
    Imperial (12Hr/F)
    Metric (24Hr/C)
    Display brightness
    Auto
    25%
    50%
    75%
    100%
    Total, 21 lines of text.
    In a "classic", old school basic, I would do it via arrays, say like this:
    DIM A$(21) ' declare string array
    A$(1)="Set Year"
    A$(2)="Set Month"
    and so on, and when needed to display that text in the code below
    I would just write
    LCDOUT $FE, $C0, A$(2) or whatever number needed
    With PBP I can't, so I have to introduce 21 separate LCDOUT statements.
    So is there a way to avoid this?
    Default Re: Handling a lot of text data, any simple and practical ways?
    Here's one way, a bit wasteful on FLASH with the fixed length but compared to individual HSEROUT (or LCDOUT) statements I'd imagine it's quite a bit smaller.
    Strings CON EXT
    i VAR BYTE
    Char VAR BYTE
    StringNumber VAR BYTE
    StartAddress VAR WORD
    Goto OverStrings
    Strings
        ; Strings, fixed length, 20 characters including null terminator.
        ; Actual string terminatesends with a NULL and is then padded to exactly 20 chars.
        db "Set Year", 0, "           "    ; 0
        db "Set Month", 0, "          "    ; 1
        db "Set Date", 0, "           "    ; 2
        db "Set day of week", 0, "    "    ; 3
        db "Set Hour", 0, "           "    ; 4
        db "Set Minute", 0, "         "    ; 5
        db "Set alarm mode", 0, "     "    ; 6
        db "Off", 0, "                "    ; 7
        db "On all week", 0, "        "    ; 8
        db "On without weekends", 0, ""    ; 9
        db "Set alarm hours", 0, "    "    ; 10
        db "Set alarm minutes", 0, "  "    ; 11
        db "Set display format", 0, " "    ; 12
        db "Imperial (12Hr/F)", 0, "  "    ; 13
        db "Metric (24Hr/C)", 0, "    "    ; 14
        db "Display brightness", 0, " "    ; 15
        db "Auto", 0, "               "    ; 16
        db "25%", 0, "                "    ; 17
        db "50%", 0, "                "    ; 18
        db "75%", 0, "                "    ; 19
        db "100%", 0, "               "    ; 20
    OverStrings:
    Init:
        ANSELF = 0
        WPUF.1 = 0
        TRISF.3 = 0
        TRISF.0 = 0
        TRISF.1 = 1
    Start:
        HSEROUT["Program start",13]
        HSEROUT["Address of first string: $", HEX4 Strings, 13]
    Action:
        StringNumber = 20                               ' Select which string to print
        GOSUB PrintString                               ' And, you guessed it, go print it.
        PAUSE 100
    PrintString:
        StartAddress = Strings + (StringNumber * 20)    ' Precalculate address of first char of string in question
        For i = 0 to 19                                 ' Maximum string length is 20 characters
            ReadCode (StartAddress + i), Char           ' Get a char from string in question.
            IF (Char = 0) THEN EXIT                     ' Break out if char is NULL
            HSEROUT[Char]                               ' Otherwise print it.
        NEXT
    Thanks!
    I had a almost similar approach -
    The text is stored in EEPROM part of the IC, in series.
    There is a 40 byte area at beginning in EEPROM, which
    has offset and length entries for these text messages
    so all I have to do, to say display "Set Time" is call a routine like
    READ 1,A 'read offset
    READ 2,B 'read length
    FOR C=A to A+B 'define a loop from this to that
    READ C,D 'read eeprom at needed value
    LCDOUT $FE,D,$14 'Display char and move cursor to next char
    NEXT
    But for some reasons it does not works, seems like that LCDOUT on initialization, resets the offset set by $14 (move cursor right)
    That line of code does NOT do what the comment says.
    You're telling it to interpret whatever you read from EEPROM (into the D variable) as a command, then you're sending a constant $14 which it will interpret as data and print whatever character that code corresponds to (see datasheet).
    To do what the comment says it would look like this:
    LCDOUT D, $FE, $14
    With that said, the adress counter in the HD44780 will automatically increment each time you write to DDRAM (ie send it a byte not preceded by $FE) so by doing the above you will end up with a blank space between the characters.
    Oh thanks, will give it a try!
    on a 16f like this
    ;16f1825#CONFIG
                 __config        _CONFIG1,    _FOSC_INTOSC & _CP_OFF & _WDTE_OFF &  _PWRTE_ON  &  _MCLRE_ON  & _CLKOUTEN_OFF
    DEFINE OSC 32
        OSCCON=$70
        ANSELA=0
        ANSELC=0
        TRISA = %001110
        trisc = %11100010     ' set PORTC I/O
        Strings CON EXT
        i VAR BYTE
        Char VAR BYTE
        ctemp  VAR WORD
        rand      VAR WORD
        lata.0=1
        DEFINE DEBUG_REG PORTA
        DEFINE DEBUG_BIT 0      ;  if not used for pwr
        DEFINE DEBUG_BAUD 9600
        DEFINE DEBUG_MODE 0
        pause 2000
        Debug "Start",13 ,10
    Goto OverStrings
    Strings
        da "Set Year", 0, "           "    ; 0
        da "Set Month", 0, "          "    ; 1
        da "Set Date", 0, "           "    ; 2
        da "Set day of week", 0, "    "    ; 3
        da "Set Hour", 0, "           "    ; 4
        da "Set Minute", 0, "         "    ; 5
        da "Set alarm mode", 0, "     "    ; 6
        da "Off", 0, "                "    ; 7
        da "On all week", 0, "        "    ; 8
        da "On without weekends", 0, ""    ; 9
        da "Set alarm hours", 0, "    "    ; 10
        da "Set alarm minutes", 0, "  "    ; 11
        da "Set display format", 0, " "    ; 12
        da "Imperial (12Hr/F)", 0, "  "    ; 13
        da "Metric (24Hr/C)", 0, "    "    ; 14
        da "Display brightness", 0, " "    ; 15
        da "Auto", 0, "               "    ; 16
        da "25%", 0, "                "    ; 17
        da "50%", 0, "                "    ; 18
        da "75%", 0, "                "    ; 19
        da "100%", 0, "               "    ; 20
    OverStrings:
    Start:
        Debug "Program start",13,10
        Debug "Address of first string: $", HEX4 Strings, 13 ,10
    Action:
         RANDOM  rand
        StringNumber = rand//20                               ' Select which string to print
         PAUSE 1000
        goto  Action
    PrintString:
        StartAddress = Strings + (StringNumber * 11)    ' Precalculate address of first char of string in question
            ReadCode (StartAddress + i), CTEMP           ' Get a char from string in question.
          Char = (CTEMP>>7)
            Debug Char                                   ' Otherwise print it
         Char = CTEMP&$7f
        NEXT
    or if all that padding is troubling , using random length null terminated strings
    ;16f1825#CONFIG
    DEFINE OSC 32
        OSCCON=$70
        ANSELA=0
        ANSELC=0
        TRISA = %001110
        Strings CON EXT
        i VAR BYTE
        Char VAR BYTE
        ctemp  VAR WORD
        rand   VAR WORD
        isa   VAR WORD
        lata.0=1
        DEFINE DEBUG_MODE 0
        pause 2000
    Goto OverStrings
    Strings
        ;  string terminates with a NULL
        da "Set Year", 0     ; 0
        da "Set Month", 0     ; 1
        da "Set Date", 0    ; 2
        da "Set day of week", 0    ; 3
        da "Set Hour", 0     ; 4
        da "Set Minute", 0     ; 5
        da "Set alarm mode", 0     ; 6
        da "Off", 0    ; 7
        da "On all week", 0     ; 8
        da "On without weekends", 0   ; 9
        da "Set alarm hours", 0    ; 10
        da "Set alarm minutes", 0     ; 11
        da "Set display format", 0    ; 12
        da "Imperial (12Hr/F)", 0    ; 13
        da "Metric (24Hr/C)", 0    ; 14
        da "Display brightness", 0    ; 15
        da "Auto", 0    ; 16
        da "25%", 0     ; 17
        da "50%", 0    ; 18
        da "75%", 0     ; 19
        da "100%", 0     ; 20
        dw 3            ;eof
    OverStrings:
    Start:
    Action:
        RANDOM  rand
        GOSUB findIndex
        PAUSE 1000
        goto  Action
    findIndex:
        isa    = Strings
        while StringNumber
            ReadCode isa, CTEMP
            isa=isa+1
            if  CTEMP ==3 then
                isa=0
            if (CTEMP.highbyte==0) then
                StringNumber=StringNumber-1
                if    StringNumber == 0 then  return
        wend
    PrintString:
        if  isa then
            Debug 13,10
                ReadCode (isa + i), CTEMP           ' Get a char from string in question.
                Char = (CTEMP>>7)
                Char = CTEMP&$7f
            NEXT
    Name:  Screenshot 2021-09-13 141521.jpg
    Well, my code has no ASM
    or code either it seems
    OK
    It was once stated by someone with a certifiable IQ that boggles the mind, "There is nothing new in the universe". On a more micro scale, many issues we face as we try to get tiny little black plastic blocks to do what we want them to, using resources available, we have to realize that many of our challenges have been faced and conquered in the past. I try to make it a habit to search forums for clues, or out-right answers before posting questions. Not to discourage anyone from creating a new post, but when effective answers don't seem to be forthcoming, maybe as a second resort, do a search. Don't forget, this is not the only PBP forum (ME Labs, the creator of PBP, has their own forum -- though not as popular -- at http://support.melabs.com).
    I faced some programming challenges in the past using newer PIC chips with Peripherals not dealt with by standard PBP commands. My solution was to familiarize myself with the Microchip Data Sheets, and manipulate the registers manually; which PBP competently allows me to do. I have successfully done what you're struggling with, but not with magic PBP commands. I don't know how to answer or contribute to this thread, because how I accomplished things cannot easily be transferred in a simple post. Try doing Forum searches, varying key search words and phrases. It will probably surprise you just how many different ways folks in the past have fought your struggles, and the solutions they found. Both sites are good at keeping older legacy posts available. Good luck!
    Ok thanks
    I'm trying to read, but the main issue is, that there are very FEW code examples on forums focused exactly on topic being asked.
    Say someone asks "how to debounce ADC input" and someone posts a huge code for completed device, where that code is present, but it is hidden somewhere and you have to guess where is it, which other variables and changes it uses, from that code and so on.
    Contrary to them, the code examples supplied by melabs are short and spot on - they do what they have to do, only few extra lines are present.
    By the way, I got big module running with parallel interface with PBP. The issue was that it needs about 330mA to operate, and PicKit 3 was not able to provide enough juice. With the help of external 5V supply, issues solved
    you have to laugh . it describes this thread to a tee , well thought out practical solutions offered, that were some how unacceptable
    for reasons not given " Well, my code has no ASM " perhaps. op supposedly has better solution not posted
    as you sow so shall you reap
    ps thanks ioannis for the edit on post 6
    Haha, yeah, wow :-)
    You post a snippet and you get complaints about it not working because someone can't be bothered to clear TRIS and ANSEL by them them selves. So, next time you post a fully working, tailor made solution that solves exactly what was asked (which then turns out to not be what op actually MEANT) only to get complains that the code is too verbose :-)
    I've spent countless hours writing snippets and full verified-to-be-working programs, both in response to questions asked on this forum and posted as examples. I enjoy doing it, I hope it helps users. I don't get paid to do it, on the contrary I've SPENT my own money buing devices, development boards, breakout boards and what not to help solve peoples issues because I've found (and still find) it interesting and fun.
    Rarely have I asked myself why bother...
    I'm not complaining, I'm trying to explain.
    The things that are dead simple for you, might be dead hard for me, and vice versa.
    Not everyone has skills and talents for all these digital things.
    You're good in coding - I'm good in something different, and someone else is good in something else.
    That is the way humans are made.
    So that's not a good idea to blame someone for not understanding things that you do understand.
  1. Any elegant way of text string handling?
    Last Post: - 2nd November 2020, 16:21
  2. Replies: 11
    Last Post: - 9th March 2020, 12:37
  3. Serious Help Needed-Tried a Lot & Now I am Here
    By Megahertz in forum Schematics
    Last Post: - 17th December 2009, 12:12
  4. Serial problem with a lot of chips
    Last Post: - 20th October 2007, 12:55
  5. Writing serial data to text file
    By TurboLS in forum mel PIC BASIC Pro
    Last Post: - 2nd March 2005, 22:09
