16f1847 hserout
Results 1 to 9 of 9
Thread: 16f1847 hserout
    Default 16f1847 hserout
    Hello Folks -- going to (hopefully) use a 16F1847 with HSEROUT. Always have used the software SEROUT before so this is new territory.
    To possibly save time, could someone tell me the commands to configure this chip for using the UART and HSEROUT at 9600 baud please. So much easier to just ask then spend all day searching.
    BIG THANKS for any help.
    Default Re: 16f1847 hserout
    how are you off for socks and underpants ?
    Do this:
    On page 154 of the Pic Basic Reference Manual copy the DEFINES and test them to confirm that your circuit works as expected at 2400 baud.
    I know it is not exactly what you want but after that giant leap I am sure you will be able to do next steps forward.
    Thanks.
    My ultimate goal is to interface a 16F1847 to a Raspberry PI 3B with RS485. The PI UART though needs 3.3v but I do see that the 16F1847 will work at 3.3V ? Can anyone verify that it performs reliably at that voltage?
    3.3v seems to be working well so far. I breadboarded the pic feeding into the PI uart.
    If the datasheet says it works on 3.3Volts there is no doubt that it will. Trust it.
    Jan 2014
    100% 16f1847 work at 3,3v , I worked many time.
    Fellas --
    Is there any way to simply flip a byte so that MSB becomes LSB or vice versa?
    Can't remember what the default is but I need to reverse it (or redo my *^% switches).
    Thanks.
    FOR i = 0 to 7
    Correct.0[7-i] = Mistake.0[i]
    NEXT
    or
    Correct = Mistake REV 8
  1. Micro code studio -- 16F1847
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 19th February 2020, 22:08
  2. Micro code studio -- 16F1847
    Last Post: - 9th February 2020, 00:01
  3. Code verification errors 16F1847
    By wjsmarine in forum mel PIC BASIC Pro
    Last Post: - 7th May 2018, 01:33
  4. Hserout
    By mazytis in forum mel PIC BASIC Pro
    Last Post: - 21st May 2015, 04:10
  5. 16F1847 Usart and I2C
    By Seahound1 in forum Serial
    Last Post: - 18th December 2012, 21:41
