HSEROUT using STR modifier - length parameter as variable not working
+ Reply to Thread
Results 1 to 15 of 15
    SWITZERLAND (french part)
    Default HSEROUT using STR modifier - length parameter as variable not working
    Hi there,
    I'm using HSEROUT with the STR modifier and I can't find the way to set the number of characters "\n" in a variable instead.
    While this works:
    HSEROUT [STR BalBuffer\40,26,13]
    ...this doesn't:
    BalCount VAR BYTE
    BalCount = 40
    HSEROUT [STR BalBuffer\BalCount,26,13]
    It is to mention that it does compile without error in both cases.
    I didn't try this one, but according to some other post (from Bruce in 2005), DEBUG/DEBUGIN seem to accept a variable for the charater value.
    Is this a limitation for the STR modifier (= it has to be a number) in HSEROUT or is there a way to make it work with a variable?
    Roger
    Default Re: HSEROUT using STR modifier - length parameter as variable not working
    I don't know and I can't test/try if your code right now but a simple workaround would be
    For i = 0 to BalCount   '  (Or possibly BalCount-1)
      HSEROUT [BalBuffer]
    NEXT
    HSEROUT [26,13]
    Thanks Henrik,
    I went this way already but so it is correct, the number of characters cannot be replaced by a variable.
    Strange....
    Roger
    Which device are you using?
    I compiled two different version and looked at the .lst and with my limited understanding of assembly I'd say it "should work"
    First, HSEROUT [STR Buffer\16]
             movlw   low (010h)
             movwf   R4 + 1
             movlw   low (low (HSEROUTJ))
             movwf   R8
             clrf    (R8) + 1
             clrf    R2 + 1
             movlw   low (low (_Buffer))
             call    SEROUT2STRN
    Here it takes the literal 16 and moves it to the low byte (I think) of system variable R4.
    Second, HSEROUT [STR Buffer\Length]
             movf    _Length, W
             movwf   R4 + 1
             movwf   R8
             clrf    (R8) + 1
             clrf    R2 + 1
             call    SEROUT2STRN
    Here it takes the Length variable, and loads THAT to the low byte (I think) of system variable R4.
    In the actual serout macro it then decrements R4 to determine when it's done.
    Page 47 of the manual says "STR must be followed by a backslash and a number that specifies how many
    characters (bytes) to collect."
    So, as I understand it, it should be a number, not a variable.
    If you want to change that on the fly, then Henrik's loop is the way to go.
    it works for me
     ;pic18f26k22 tx  demo
      CONFIG  FOSC = INTIO67
      CONFIG  PLLCFG = OFF
      CONFIG  PRICLKEN = OFF
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRTEN = OFF
      CONFIG  BOREN = SBORDIS
      CONFIG  BORV = 190
      CONFIG  WDTEN = ON
      CONFIG  WDTPS = 32768
      CONFIG  CCP2MX = PORTC1
      CONFIG  PBADEN = OFF
      CONFIG  CCP3MX = PORTB5
      CONFIG  HFOFST = ON
      CONFIG  T3CMX = PORTC0
      CONFIG  P2BMX = PORTB5
      CONFIG  MCLRE = EXTMCLR
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
    define OSC 8
    DEFINE DEBUG_REG PORTB
    DEFINE DEBUG_BIT 7
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 0
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_BAUD 9600
    trisb=$7f
    OSCCON = $60   ;  OSC 8
    anselc = 0
    BalBuffer VAR BYTE[60]
    BalCount VAR BYTE
    latb.7=1
    for   BalCount= 0 to 59
    BalBuffer[BalCount]=BalCount+"0"
    next
    BalBuffer[59]=0
    pause 2000
    debug "ready",13,10
    BalCount = 40
    HSEROUT [STR BalBuffer\BalCount,13,10]
    debug   STR BalBuffer\BalCount,13,10
    debug "full load",13,10
    debug   STR BalBuffer,13,10
    or even
    BalCount = 40HSEROUT [STR BalBuffer\BalCount,13,10]
    HSEROUT [STR BalBuffer,13,10]
    for   BalCount= 0 to 40
    next
    Unfortunately Charles Leo is not monitoring this forum. I 'll make a post on support.melabs.com to clarify this, since the manual is not very clear on the matter.
    I 'd rather be 100% sure that this is trusted all the time on all MCU's.
    It's the one I always use: 16F690.
    Roger
    it works for me
    Well, I'll give it a try with a 18F1220 when I'm back home tonight.
    Roger
    it fails of course for more than 255 chrs
    BalBuffer VAR BYTE[300]
    BalCount VAR word
    latb.7=1
    clear
    next
    for   BalCount= 1 to 59
    BalBuffer[BalCount+60]=BalCount+"0"
    next
    BalBuffer[BalCount+120]=BalCount+"0"
    next
    BalBuffer[BalCount+180]=BalCount+"0"
    next
    BalBuffer[BalCount+240]=BalCount+"0"
    next
    BalBuffer[0]=13
    BalBuffer[60]=13
    BalBuffer[120]=13
    BalBuffer[180]=13
    BalBuffer[240]=13
    pause 2000
    debug "ready",13,10
    BalCount = 40
    HSEROUT ["40 ",STR BalBuffer\BalCount,13,10]
    debug   "40 ",STR BalBuffer\BalCount,13,10
    debug "full load "
    HSEROUT ["full load ",STR BalBuffer,13,10]
    BalCount = 255
    HSEROUT ["255 ",STR BalBuffer\BalCount,13,10]
    HSEROUT [13,10]
    HSEROUT ["260"]
    BalCount = 260
    Of course, since the macro only uses the low byte of R4 to index the array. That would also make it fail when using a constant >255.
    In any case, the "example" posted in the first place had a BYTE sized variable with a value of 40 and everything we've seen this far is that it should (and ideed does, for 18F at least) work. I think I compiled for 16F628 when I looked at the .lst yesterday.
    flotulopex,
    You're going to have to post code that we can just compile, assemble and program into a chip that shows the problem.
    flotulopex,
    Yup, I will do so asap.... Sorry, didn't have much time yesterday.
    Roger
    Charles replied:
    Yes, I believe it can be trusted with a variable. I've used this form to receive a variable number of characters based on a length parameter received immediately prior to the string:
    [wait($80),length,STR idstring\length]
    So officially it is valid syntax.
    For now, here a my two test programs with 16F690 and 18F1220.
    Surprisingly (to me), both accept the STR length as variable in the 3 ways I'm using it (HSEROUT, SEROUT2 and DEBUG).
    I'll go back to my current program and try again....
    Roger
  1. Determining variable length (number of digits) possible?
    Last Post: - 21st December 2020, 20:05
  2. Measuring a variable freq/length pulse and generating more pulses.
    Last Post: - 18th September 2014, 09:10
  3. hserout not working with parity
    Last Post: - 24th March 2010, 13:25
  4. HSERIN for variable length string
    Last Post: - 19th February 2010, 05:58
  5. Serin2 and STR Modifier
    By _Ian in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2005, 16:25
