+ Reply to Thread
Results 1 to 9 of 9
    Default PIC19176 Configuration bits
    On some PIC's one can define the CONFIG bits by this syntax (for example on the 18F45K22):
        CONFIG  FOSC = INTIO67        ; Internal oscillator block
        CONFIG  PLLCFG = ON           ; PLL Control
        CONFIG  PRICLKEN = OFF        ; Primary clock can be disabled by software
        CONFIG  FCMEN = OFF
    etc
    but on others, like the 16F19176 needs this type of syntax:
        __CONFIG _CONFIG1, _FEXTOSC_OFF
        __CONFIG _CONFIG1, _RSTOSC_HFINTPLL
    etc
    Anyone knows why?
    And then it gives me Overwriting previous address contents (8007)...
    Testing on PBP 3.1.2.3 and MPASMX of the 5.15 MPLABX
    Default Re: PIC19176 Configuration bits
    OK, after many compilations with errors, it seems that for the specific PIC needs this exactly syntax of the configs:
    __CONFIG _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINTPLL & ...
    But this is not very helpful as one cannot add comments as to what each config bit does.
    this format ?
    cfg1  = _FEXTOSC_OFF
    cfg1&= _RSTOSC_HFINTPLL
    cfg1&= _......
      __CONFIG _CONFIG1, cfg1
    This is more entertaining than Free to Air TV
    Thanks Richard.
    Yes, this too works OK. Although more typing this helps keeping the comments about each config bit.
    Still, question remains, why different MCU need different format.
    they don't
    etc
    you cannot do this, its syntatically incorrect
     __CONFIG _CONFIG2, _RSTOSC&_HFINTPLL
     etc
    would be ok if _RSTOSC&_HFINTPLL are in config word 2
        CONFIG  FCMEN = OFF
    etc
    this format is pic18 only
    [CODE]this format is pic18 only
    That explains it. But where is this referred?
    Thanks once again.
    where most things reside these days
    Nice!
  1. Configuration bits
    By CipiCips in forum PBP3
    Last Post: - 14th March 2019, 21:14
  2. configuration bits
    By Izone1173 in forum mel PIC BASIC
    Last Post: - 18th June 2009, 04:17
  3. Configuration bits
    By Perrin` in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2008, 14:40
  4. Configuration bits
    By DJEE in forum mel PIC BASIC Pro
    Last Post: - 14th June 2007, 19:20
  5. Configuration bits
    By Armando Herjim in forum General
    Last Post: - 5th December 2006, 17:51
Members who have read this thread : 12
