Unable to fit variable XXX in requested bank 0
Results 1 to 10 of 10
    May 2009
    Saint-Quentin-en-Yvelines, FRANCE
    Default Unable to fit variable XXX in requested bank 0
    Hi everybody,
    A very recent problem has appeared with one of my old programs.
    It was perfectly working but I want to add some new capabilities which means more code and more variables and I got the message following the compilation :
    Warning : Unable to fit variable DataTX in requested bank 0
    As I disregarded the Warning and continued to add code and variables I got a second additional message :
    Warning : Unable to fit variable DataT1 in requested bank 0
    DataTX is a LONG type variable (I use PBPL) and DataT1 is a BYTE. They are in bank 0 from the beginning without any issue.
    The reason for using the bank 0 is that these data (and others) are used in a time-critical assembly language routine.
    I was thinking about a memory overload but I use a PIC18F26K22 which has 3896 Bytes for its SRAM and I understand that its BANK 0 may contain up to 96 bytes.
    I use only about 300 bytes (manually counted ...) for my variables and amongst them about 36 are stored in bank 0. None of the additional variables used for the new capabilities is stored in bank 0.
    I don't understand ! Any idea ?
    MikeBZH
    Default Re: Unable to fit variable XXX in requested bank 0
    If you send them to BANK1 does it resolve?
    Sep 2009
    PBP variables are allocated in bank0. There is a lot of variables if you have complex IF AND OR THEN statement.
    OK
    Are these the only 2 variables you are trying to force in Bank0, or are there others the compiler is OK with? You might want to look at the .lst file to see how busy your Bank0 is. Remember, PBP uses Bank0 (Access Bank more specifically) for R0, R1, R2... and other PBP-specific variables.
    Remember that PBP itself uses a bunch of variables and it most likely needs to use BANK0 for them for the same reason that you want to use BANK0. The number of variables PBP uses depends on what library routines it includes and, of course, if LONGs are enabled or not.
    So, when you added new capabilities to your code PBP included some library routine that uses a system variable that wasn't needed before. It was put in BANK0 pushing your variable(s) out.
    That's my guess at least.
    May 2009
    Hello,
    Thanks to everybody for your advices and expertise. Nearly everything becomes understandable
    PBP puts all the variables it can in the BANK0 including those which are not specified to be put there ! So, if a new variable comes with a BANK0 attribute and if the BANK0 is full it can not be placed there. It is placed where some room is available and a Warning is raised.
    But this is not what is written in par 7.3 (RAM Allocation) of the manual. One can read in the middle of the page "If specific bank requests are made, those are handed first". Bug or misunderstanding from myself ? I don't know.
    I have read somewhere (but where ?) that time critical assembly routines should use variables located in the BANK0. It has been very difficult to make this routine work and the execution time is still a little bit long. So I will not change BANK0 for BANK1 for the variables used there.
    On the other hand I have specifed BANK1 for other non critical and recent variables and now the compilation gives no more warning
    MikeBZH
    I am sure that the order of the vars that appear in the program has great impact on compilation.
    I don't know but the way I understand and interpret it is that between user variables that HAVE specific bank requests and those that don't the first ones ARE handled first - but still AFTER the PBP system variables have been allocated space.
    So, if PBP needs 74bytes in BANK0 you can specify 22bytes to be in BANK0 (if it happens to be 96bytes). If you try to specify a 23'rd byte in BANK0 it can't do that.
    Sep 2009
    Same here. And you can confirm that looking at .LST file.
  1. Unable to fit variable
    Last Post: - 29th November 2010, 20:34
  2. incorrect requested number of data bytes recieved
    By doxdlite in forum mel PIC BASIC
    Last Post: - 17th April 2010, 22:47
  3. Unable to pass a variable to LCDOUT without getting compile errors
    By Ferroto Baggins in forum mel PIC BASIC Pro
    Last Post: - 28th February 2010, 16:43
  4. unable to fit variable?
    By MOUNTAIN747 in forum General
    Last Post: - 4th February 2010, 20:20
  5. Fatal xxx.ASM 527: [308] macro buffer overflow
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 5th March 2009, 17:51
