divide a 10 Mhz signal by 1000 ...
+ Reply to Thread
Results 1 to 8 of 8
    France
    Default divide a 10 Mhz signal by 1000 ...
    I must divide a signal (10 Mhz) to 10 Khz (OCXO asservissement with a GPS)
    I have an example in language "C" and I understand quite nothing !!! it use a 12F675 (clock is the 10 mhz signal)
    and I would like to understand why I see all those "counts" for one division
    I Hope somebody can help me, I think that I have to write in ASM language, not in Basic
    ASM is not easy for me ...
    so if somebody knows how to divide a 10 Mhz signal to get a 10 Khz output signal
    I would appreciate
    thanks
    Francois F1CHF
    here is the "code" see attached file (sorry I didn't know how to use the "code" function !)
    Sep 2009
    Default Re: divide a 10 Mhz signal by 1000 ...
    Just cascade 3 times 4017. It cheapest and reliable way to do it.
    https://www.ti.com/lit/ds/schs027c/s...oogle.com%252F
    its not one division its three with a 90 deg phase shift on one of them.
    one div would be like this
    ;In simple terms  toggle a pin on every 125th cycle
    ;start:;set gpio pin high
    ;delay 124 cycles
    ;set gpio pin low
    ;delay 122 cycles
    ;goto start
    CNT VAR BYTE BANK0
    TRISIO=110
    START
      BSF GPIO , 0
      MOVLW 40      ;2
      MOVWF _CNT    ;1
    DL1             ;119 DELAY = 2+3(CNT-1)
      DECFSZ _CNT
      GOTO DL1
      NOP           ;1
      NOP           ;1
      BCF GPIO , 0
      MOVLW 40      ;2
      MOVWF _CNT    ;1
    DL2
      DECFSZ _CNT    ;119 DELAY = 2+3(CNT-1)
      GOTO DL2
      GOTO START    ;2
    Warning I'm not a teacher , prose like a gushing embroilment is not my style
    France
    thanks for your reply, i know ths solution with divider like 74xx390 etc ... CD4017 at 10 mhz ... not sure ...
    objective : have a small unit to do the job !
    thanks
    francois
    France
    thanks Richard I don't see my first reply
    so I was saying
    "I am not spleeping just trying to undersatnd your asm example ..."
    hold the line !
    regards
    i tested my code while i had the sim running, seems i cant count well
    this is better
     #CONFIGcfg = _HS_OSC                 ; HS oscillator: High speed crystal/resonator on GP4/OSC2/CLKOUT and GP5/OSC1/CLKIN
    cfg&= _WDT_ON                 ; WDT enabled
    cfg&= _PWRTE_OFF              ; PWRT disabled
    cfg&= _MCLRE_ON               ; GP3/MCLR pin function is MCLR
    cfg&= _BODEN_ON               ; BOD enabled
    cfg&= _CP_OFF                 ; Program Memory code protection is disabled
    cfg&= _CPD_OFF                ; Data memory code protection is disabled
      __CONFIG cfg
     ;pic12f675
    ;In simple terms  toggle a pin   every 125 cycles
    ;delay 125 cycles
    ;set gpio pin low
    ;delay 123 cycles
    ;goto start
    CNT VAR BYTE BANK0
    TRISIO=%11111110
    START
      BSF GPIO , 0
      MOVLW 41      ;2
      MOVWF _CNT    ;1
    DL1             ;122 DELAY = 2+3(CNT-1)
      DECFSZ _CNT,f
      GOTO DL1
      BCF GPIO , 0
      MOVLW 40      ;2
      MOVWF _CNT    ;1
    DL2
      DECFSZ _CNT,f    ;119 DELAY = 2+3(CNT-1)
      GOTO DL2
      NOP           ;1
      GOTO START    ;2
    France
    I got a very nice answer on that subject
    here
    Hello François
    Have an eye Here: http://www.leapsecond.com/pic/picdiv.htm
    Great idea. They use external signal as PIC clock and then execute a timed delay to toggle output. So the output has the precision of the input clock signal! Brilliant!
  1. Good way to divide 10bit adc by 4?
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 18th February 2016, 09:32
  2. divide
    By daydream in forum mel PIC BASIC Pro
    Last Post: - 12th May 2012, 15:19
  3. Picbasic Pro divide problem
    By Hebemabo in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2011, 17:10
  4. Replies: 1
    Last Post: - 6th April 2007, 11:50
  5. Storm 1000 Keypad PIC Interface help please
    By digilord in forum mel PIC BASIC Pro
    Last Post: - 30th December 2005, 19:37
