getting my head around PICS with SR-Latch registers - and how to properly use them
Results 1 to 4 of 4
    Jan 2007
    Default getting my head around PICS with SR-Latch registers - and how to properly use them
    Hello,
    I am just starting to play with the 16F1825 PIC which has SR latch registers.
    I understand the 16F1xxx family of PICs have the SR latch register - and previous PICs did not.
    I understand this register facilitates better read-modify-write functionality.
    But on the subject of sending commands to PORT registers, I've also read that the commands PORTC.4 = 0 and LATC.4 = 0 are essentially the same command - because the system ends up writing the same thing to the same PORT register.
    With these PICs is there a "Best Practice" command - for turning on/off specific pins?
    dw
    Default Re: getting my head around PICS with SR-Latch registers - and how to properly use the
    In a perfect world (or a simulator) writing to PORT will have the same effect as writing to LAT. In the real world that's not always the case - depending on various circuimstances.
    On any PIC that has LAT register I'd say best practise is to use the LAT register(s), they're there for a reason.
    With that said, do note that having LAT register(s) and having a SR-latch peripheral is not at all the same thing.
    Jan 2007
    Thanks Hendrick!
    Aug 2011
    Yes. Write to the LAT register. Read from the PORT register.
  1. bitwise head scratcher? Rather, pulling my hair out.
    By kevlar129bp in forum mel PIC BASIC Pro
    Last Post: - 20th March 2020, 21:07
  2. 12f675 to latch output while it does something else
    By AVGuru in forum mel PIC BASIC Pro
    Last Post: - 24th September 2014, 03:55
  3. My Head Hurts with Tables, Lookup, EXT etc etc
    Last Post: - 9th June 2012, 07:21
  4. Oh Dear. My head is spinning. HPWM RGB LEDs What to choose?
    By jimseng in forum mel PIC BASIC Pro
    Last Post: - 19th March 2012, 17:03
  5. How to latch an output for a pre-defined time
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 21st December 2009, 18:20
