Change variable increment/decrement into mid-loop?
Results 1 to 5 of 5
    Default Change variable increment/decrement into mid-loop?
    Hello.
    There is a some loop, which monitors keypress, updates display, etc.
    Also in loop is variable, which should increase from 1 to 100 and then decrease from 100 to 1.
    Is there any way to do it in simple way? without splitting loop into two parts?
    Default Re: Change variable increment/decrement into mid-loop?
    Something like this perhaps?
    Cnt VAR BYTE
    Dir VAR BIT
    UP CON 1
    DOWN CON 0
    SomeLoop:
      ' Monitor keypress
      ' Update Display
      ' etc
      IF Dir = UP THEN
        Cnt = Cnt + 1
        Cnt = Cnt - 1
      IF (Cnt = 100) OR (Cnt = 0) THEN
        Dir = ~Dir    ' Invert direction
      Goto SomeLoop
    Yes, thanks!
    On spectrum, I was doing this by changing the sign of increment variable, but since in PBP we have no negative numbers....
    And yes, CNT=1 should be added in the beginning, or absolutely unexpected behavior will be generated (just tested)
    Regarding negative numbers, as long as both variables are of the same size what you did will work:
    Cnt VAR BYTE
    Add VAR BYTE
    Cnt = 100
    Add = -1
    Cnt = Cnt + Add   ' Cnt now = 99
    But if Cnt was a WORD and Add a BYTE then Cnt woul equal 354.
  1. Replies: 27
    Last Post: - 9th April 2015, 05:51
  2. Can not change variable while using DT_INT?
    By hvguy0 in forum mel PIC BASIC Pro
    Last Post: - 30th March 2013, 00:05
  3. Altering a variable in a loop.
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 18th September 2012, 07:24
  4. Change a variable to the opposite?
    By Hylan in forum mel PIC BASIC Pro
    Last Post: - 21st June 2012, 08:00
  5. Let a variable change from bin to dec.
    By Roy in forum mel PIC BASIC Pro
    Last Post: - 25th May 2004, 20:57
