HSERIN using EUSART RX interrupt - how does it really work?
Results 1 to 8 of 8
    SWITZERLAND (french speaking)
    Default HSERIN using EUSART RX interrupt - how does it really work?
    Hi all,
    I've made this small program to learn how the EUSART RX interrupt works....and it works BUT
    Yes, the code below works but I'm getting confused when I think about having unknown data length to be received. I'm not even sure that this code is really correct.
    In this example, I'm waiting for 5 charaters to be received. As long as 5 characters have not arrived, nothing will be printed out.
    And here is where I'm confused.
    Since the HSERIN command is in the ISR, each time I send a character from the Serial Communiactor, I expect the ISR the receive "at least" one character so the LED should toggle. But no, it doesn't. It seems to wait until all 5 characters have arrived and then, only then, the LED toggles.
    I don't get it....
    How shall I handle this please? What is the correct approach?
    ' ====== FUSES ====================================================================================
    ' PIC 16F690 Fuses (MPASM)
    @ __config _FCMEN_OFF &_IESO_OFF &_CPD_OFF &_WDT_OFF &_INTRC_OSC_NOCLKOUT &_BOR_OFF &_CP_OFF &_PWRTE_OFF &_MCLRE_OFF
    @ ERRORLEVEL -306
    OSCCON     = %01110000 'Internal RC set to 8Mhz - Register not to be used with XTal
    OPTION_REG = %10000000 'PORT A&B Pull-Ups (look WPUA & WPUB)
    ANSEL      = %00000000 'Select analog inputs Channels 0 to 7
    ANSELH     = %00000000 'Select analog inputs Channels 8 to 11
    INTCON     = %11000000 'INTERRUPT Control
    PIE1       = %00100000 'Peripheral Interrupts
    ' ====== UART SETTINGS ============================================================================
    RCSTA      = %10010000 ' Enable serial port & continuous receive
    TXSTA      = %00100000 ' Enable transmit, BRGH = 0
    SPBRG      = 12        ' 9600 Baud @ 8MHz, 0.16%
    ' ====== DEFINES ==================================================================================
    DEFINE OSC 8
    DEFINE NO_CLRWDT 1   ' Don't waste cycles clearing WDT
    DEFINE HSER_CLOERR 1 ' Automatic clear overrun error
    ' ====== VARIABLES ================================================================================
    LED     VAR PORTB.6
    SData   VAR BYTE(5)
    Print   VAR BIT
    '======= INITIALIZE ===============================================================================
    PORTB.5 = 1  ' set to avoid sending serial data garbage
    Print   = 0  ' send out serial data only if some is received
    '======= PROGRAM ==================================================================================
    ON INTERRUPT GOTO ISR
    MAIN:
        IF PRINT THEN
            Hserout [STR SData\5,13,10]
            Print = 0
        GOTO MAIN
    ' ====== INTERRUPT SERVICE ROUTINE ================================================================
        Disable
    ISR:
        HSerin [STR SData\5]
        PRINT = 1
        TOGGLE LED
        RESUME
        ENABLE
    Roger
    Default Re: HSERIN using EUSART RX interrupt - how does it really work?
    i have great reservation that "on interrupt" will be successful @9600 with a 4mhz osc, use dt ints
    puts your 690 in a blocking loop until 5 characters have been received, no matter how long it takes
    its not isr material
    my take
    ' ====== FUSES ====================================================================================' PIC 16F690 Fuses (MPASM)
    @ ERRORLEVEL -306
    ;PIE1       = %00100000 'Peripheral Interrupts
    DEFINE OSC 8
    LED     VAR PORTB.6
    SData   VAR BYTE(5)
    rx_count var byte
    rx_complete var bit
    rx_hit var bit
    ;Print   VAR BIT
    clear
    ,Print   = 0  ' send out serial data only if some is received
    gosub rx_start
    MAIN:
        IF rx_complete THEN
            gosub rx_start
         IF rx_hit THEN
          TOGGLE LED
          rx_hit=0
        GOTO MAIN
    rx_start        ;resume /start    rx
        RCSTA.4=0  ;clear any rcsta error
        RCSTA.4=1
        rx_count=0
        rx_complete=0
        PIE1.5=1
        Disable
    ISR:
        sdata[rx_count]=RCREG
        rx_hit=1
        rx_count=rx_count+1
        if  rx_count==5 then   ;stop rx for now
        rx_complete=1
        PIE1.5=0
        RESUME
        ENABLE
    since most chips have a rxbuffer you could also take advantage of
    ISR:
        rx_hit=1
        while pir1.5
           rx_count=rx_count+1
               rx_complete=1
               PIE1.5=0
        wend
        RESUME
        ENABLE
    Thank you Richard,
    Actually, my program works on a 8MHz basis - it should be more than enough to handle 9600bps serial data, no?
    I'd like to stick to the very basics since I'm not an ultra-programming-geek (just a curious guy). I often heard and read about DT's interrupts but it looks "too much" to me, a least, for my so small projects.
    puts your 690 in a blocking loop until 5 characters have been received, no matter how long it takes its not isr material
    Thanks a lot for explaining this.
    As far as I read the DS, the RX buffer can store 2 characters. Starting this thread, my example was using a 5 characters but in fact, I will always have unknown data length (I'll read sms messages) - so let's forget the 5 characters story
    Since you refer to it, why is there a buffer of "2" characters? What's its use?
    This is my latest code I modified to receive 1 character at the time giving the chance of handling variable lenght incoming data:
    @ ERRORLEVEL -306
    ADCON0     = %00000000 'A/D Module
    DEFINE OSC 8
    LED     VAR PORTB.6
    SData   VAR BYTE(5)
    Print   VAR BIT
    Print   = 0
    MAIN:
        IF PRINT THEN
            HSEROUT [SData]
            Print = 0
        GOTO MAIN
        Disable
    ISR:
        PRINT = 1
    	HSerin [SData]
    	Resume
        ENABLE
    Looks like a silly question, but, can I trust this code? Will it work @ 100%? Could something make it hang or stop?
    BTW, thanks for your code - I'm playing with it trying to understand it
    Roger
    First, there's the actual shiftregister into which the data is shifted bit-by-bit as it's received. You don't have access to this register (AFAIK).
    Once the correct number of bits have been shifted in they are copied to RCREG (where you can read it) and the interrupt flag is set. Now the user code needs to grab the byte from RCREG before a new byte is fully shifted in. So there's your two byte buffer.
    Using ON INTERRUPT is tricky since all it does is poll the interrupt flag BETWEEN PBP statements. What that means is that if you have a PBP statement that takes considerable time the execution of the interrupt handler will be postponed for (up to) that amount of time. In your case, I don't see any issue but lets say that, instead of HSEROUT[SData] in the main loop, you had done HSEROUT["The received byte is: ", SData] then the execution time of that complete statement is longer than the time between two received characters and it would not work properly.
    probably not , on interrupt is not suitable for processing async data streams in any useful way without flow control
    if there is a "real" foreground task being processed incurring data loss is inevitable
    a simple fifo buffer gives you a little bit more time to process the rx data without loss
    @9600 its about 100uS at best
    to approach a task like that you need to have a good understanding of what the message data will look like
    eg is there a start chr? is there and end chr eg /n or /r , does the message have its length encoded in it? is there a chksum or crc
    what is the maximum and minimum length
    there is zero benefit in having an isr capture one chr at a time then immediately pass it back to the foreground task.
    your isr would ideally allow the foreground tasks proceed unhindered by the rx process until a message was
    received and ready to process
    dt ints is not difficult the forum abounds with examples
    Thanks Henrik, thanks Richard.
    I have some homework to do following your info
    Roger
    OK
    I assume you already found this, but several members compiled a book on using DT Interrupts:
    http://www.picbasic.co.uk/forum/forumdisplay.php?f=41
    Just in case you haven't seen it.
  1. Need help: hserin, serin and serin2 does not work for me
    By PerlNoerd in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2014, 21:09
  2. HSERIN + interrupt
    By tacbanon in forum mel PIC BASIC Pro
    Last Post: - 21st April 2012, 14:37
  3. HSERIN with/without interrupt
    By macinug in forum Serial
    Last Post: - 19th January 2009, 17:03
  4. HSERIN doesn´t work
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 29th July 2007, 14:23
  5. USB and Interrupt - can it work together ?
    By Shamir in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2006, 22:24
