PBP LONG and string-formatting not working ?
Results 1 to 6 of 6
    Italy
    Default PBP LONG and string-formatting not working ?
    Hi all,
    I'm using PbP3.1 with a PIC18F device.
    I need to use the LONG option in a particular program, but seems like the string-formatting modifier does not work properly.
    For example
    FileOffset VAR WORD
    FileOffset=12345
    Hserout2 ["Fileoffset=",DEC FileOffset,13,10]
    Should send this string
    Fileoffset=12345
    but I see only this
    Fileoffset=,
    Also the other modifiers BIN, HEX does not work
    If I remove the "LONG" option in the compiler settings the string is formatted properly.
    Any idea ?
    Default Re: PBP LONG and string-formatting not working ?
    That's weird. I'm working on a large project right now, have LONGs enabled and, except for one thing*, have not noticed any such problems. Have been using DEC, BIN, HEX extensively.
    You show a comma being output after the equal-sign, is that actually being output or is that an error?
    Have you tried with HSEROUT instead of HSEROUT2? Have you tried actually USING a LONG as your variable, instead of a WORD as you're currently doing (both should work of course).
    The one thing I stumbled upon is that using the #modifier does not work properly with LONG variables as it rolls over at 65535 so when outputting decimal digits of a LONG variable I had to specifically use DEC.
    Italy
    ok, it seems troubles are related to a wrong use of "DEFINE RESET_ORG" statement (I'm working on a bootloader code).
    Without it everything works fine also with the "PBP LONG" option enabled.
    Italy
    I see just now your reply. As I told, removing the "DEFINE RESET_ORG" statement then no problem at all.
    And yes, I also discovered the # does not work and a DEC is required.
    Thanks !
    Italy
    Me again guys, problem still exist....
    I'm working on a bootloader, based on this thread
    This code require the PBP LONG option enabled as I have to write code above 64K and LONG variables are required.
    In my adapted bootloader code, I have to use HEX and DEC modifiers, as in the example of the first post.
    Testing normally with ORG 0, everything work fine, but then the code needs to be compiled with
    "DEFINE RESET_ORG 1D800h ' Move all library sub and code to start from that location "
    so the bootloader will stay in the last area of the memory.
    And with this DEFINE, the first line where I use a DEC or HEX modifiers cause a reset of the chip.
    Hope I have explained well. I don't know what to do now.
    Not using DEC or HEX is really hard, they are very powerful ....
    Any idea ?
    Italy
    I'm turning crazy ... I see the problem also without the PBP LONG option
    I copy here the full code to show the problem.
    DEFINE RESET_ORG 1EC00h
    ' device=PIC18F67K22
    ' PBP LONG option enabled
        CONFIG  RETEN = ON          ; Enabled
        CONFIG  INTOSCSEL = LOW      ; LF-INTOSC in High-power mode during Sleep
        CONFIG  SOSCSEL = DIG        ;
        CONFIG  XINST = OFF           ; Disabled
        CONFIG FOSC = INTIO2	    ; Internal RC oscillator
        CONFIG  PLLCFG = OFF           ; Enabled
        CONFIG  FCMEN = OFF           ; Disabled
        CONFIG  IESO = OFF            ; Disabled
        CONFIG  PWRTEN = OFF          ; Disabled
        CONFIG  BOREN = SBORDIS       ; Enabled in hardware, SBOREN disabled
        CONFIG  BORV = 2              ; 2.0V
        CONFIG  BORPWR = ZPBORMV      ; ZPBORMV instead of BORMV is selected
        CONFIG  WDTEN = OFF
        CONFIG  WDTPS = 256           ; 1:256
        CONFIG  RTCOSC = SOSCREF      ; RTCC uses SOSC
        CONFIG  CCP2MX = PORTC        ; RC1
        CONFIG  MSSPMSK = MSK7        ; 7 Bit address masking mode
        CONFIG  MCLRE = ON            ; MCLR Enabled, RG5 Disabled
        CONFIG  STVREN = ON           ; Enabled
        CONFIG  BBSIZ = BB2K          ; 2K word Boot Block size
        CONFIG  DEBUG = OFF           ; Disabled
        CONFIG  CP0 = OFF             ; Block 0 (000800, 001000 or 002000-003FFFh) not code-protected
        CONFIG  CP1 = OFF             ; Block 1 (004000-007FFFh) code-protected
        CONFIG  CP2 = OFF             ; Block 2 (008000-00BFFFh) code-protected
        CONFIG  CP3 = OFF             ; Block 3 (00C000-00FFFFh) code-protected
        CONFIG  CP4 = OFF             ; Block 4 (010000-013FFFh) code-protected
        CONFIG  CP5 = OFF             ; Block 5 (014000-017FFFh) code-protected
        CONFIG  CP6 = OFF             ; Block 6 (01BFFF-018000h) code-protected
        CONFIG  CP7 = OFF             ; Block 7 (01C000-01FFFFh) code-protected
        CONFIG  CPB = ON             ; Boot Block (000000-0007FFh) code-protected
        CONFIG  CPD = OFF             ; Data EEPROM code-protected
        CONFIG  WRT0 = OFF            ; Block 0 (000800, 001000 or 002000-003FFFh) not write-protected
        CONFIG  WRT1 = OFF            ; Block 1 (004000-007FFFh) not write-protected
        CONFIG  WRT2 = OFF            ; Block 2 (008000-00BFFFh) not write-protected
        CONFIG  WRT3 = OFF            ; Block 3 (00C000-00FFFFh) not write-protected
        CONFIG  WRT4 = OFF            ; Block 4 (010000-013FFFh) not write-protected
        CONFIG  WRT5 = OFF            ; Block 5 (014000-017FFFh) not write-protected
        CONFIG  WRT6 = OFF            ; Block 6 (01BFFF-018000h) not write-protected
        CONFIG  WRT7 = OFF            ; Block 7 (01C000-01FFFFh) not write-protected
        CONFIG  WRTC = OFF            ; Configuration registers (300000-3000FFh) not write-protected
        CONFIG  WRTB = OFF            ; Boot Block (000000-007FFF, 000FFF or 001FFFh) not write-protected
        CONFIG  EBRT0 = OFF           ; Block 0 (000800, 001000 or 002000-003FFFh) not protected from table reads executed in other blocks
        CONFIG  EBRT1 = OFF           ; Block 1 (004000-007FFFh) not protected from table reads executed in other blocks
        CONFIG  EBRT2 = OFF           ; Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks
        CONFIG  EBRT3 = OFF           ; Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks
        CONFIG  EBRT4 = OFF           ; Block 4 (010000-013FFFh) not protected from table reads executed in other blocks
        CONFIG  EBRT5 = OFF           ; Block 5 (014000-017FFFh) not protected from table reads executed in other blocks
        CONFIG  EBRT6 = OFF           ; Block 6 (018000-01BFFFh) not protected from table reads executed in other blocks
        CONFIG  EBRT7 = OFF           ; Block 7 (01C000-01FFFFh) not protected from table reads executed in other blocks
        CONFIG  EBRTB = OFF           ; Boot Block (000000-007FFF, 000FFF or 001FFFh) not protected from table reads executed in other blocks
    	DEFINE		OSC			8
    	DEFINE		HSER2_RCSTA	90H
    	DEFINE  		HSER2_TXSTA  	24H
    	DEFINE 		HSER2_BAUD	19200
    	DEFINE		HSER2_CLROERR	1
    	CLEAR
    	OSCCON		=%01100000			; Primary oscillator, internal 8MHz
    	OSCCON2.0	=1
    	OSCTUNE.7	=1
    	Adr			VAR	WORD
    loop1:
        FOR Adr=1000 TO 1005
    	HSEROUT2 ["test1: ",13,10]			' -->>>> this works always
            HSEROUT2 ["test2: ", DEC4 Adr,13,10] 	' -->>>> this works only if you comment the first line "DEFINE RESET_ORG 1EC00h"
        NEXT Adr
        PAUSE 1000
        CLEARWDT
        goto loop1
  1. Replies: 8
    Last Post: - 11th September 2017, 01:21
  2. LCD Display Formatting
    By jimtreg in forum mel PIC BASIC Pro
    Last Post: - 9th October 2015, 15:40
  3. pbp pro compiler console application has stopped working
    Last Post: - 19th June 2012, 22:45
  4. Replies: 3
    Last Post: - 3rd December 2011, 22:48
  5. serial formatting
    By barkerben in forum General
    Last Post: - 7th January 2005, 17:54
