12F683 GPIO.3 MCLR pin - unusual response
+ Reply to Thread
Results 1 to 3 of 3
    Jan 2007
    Default 12F683 GPIO.3 MCLR pin - unusual response
    Today I setup a 12F683 hoping to read pins 2,3, and 4 masked out as a 3-bit word.
    I set the chip's bit config to turn off MCLR on pin 4 gpio.3
    Pin 4 when not used as a MCLR reset functions as input only.
    So I set pins 2, and 3 also as inputs
    Then I put 10K resistors on each - pulling them down to ground.
    I then set the code to read GPIO and mask out all the other pins.
    Then right-shifted the results to derive the lowest 3 bits
    Pulling any combination of these 3 pins high should result in values ranging 0-7.
    Pins 2, and 3 acted as expected.
    However, the MCLR pin was acting flaky.
    Even with the pull down resistor on it - it was flipping back and forth between a high and low reading.
    I've never seen this before.
    I dug through the datasheet to see if I could find something peculiar about pin-4 MCLR with no success.
    Default Re: 12F683 GPIO.3 MCLR pin - unusual response
    GP3 does not have any other function except MCLR if set to.
    So the erratic behavior may be related to the software. Show the code please.
    Jan 2007
    Thank you Ioannis!
    A funny thing happened to me on the way to re-turning to this....... This morning it worked as I would have expected.
    And I couldn't reproduce the previous behavior.
    But I do thank you for prompting me.
    I would have otherwise thought wrong about the chip.
    Here is the code and use case:
    I have a re-built Nintendo game controller.
    It originally had a 4021 shift-register which died.
    So I removed that part and replaced it with 6 germanium diodes - which convert 6 possible button presses to a 3-bit binary word (0-7)
    For my test bench I have a pic-based LCD display I use as a Serial Monitor
    ' Name : 12F683_DiodeSwitchControl_SerialLCD-DisableMCLR.pbp
    ' Compiler : PBP3
    ' Target PIC : PIC12F683
    ' Oscillator : 4MHz internal
    ' Description : Diode Switch matrix 6 switches to 3bit binary
    ' Note: Disable MCLR_reset function PIN-4 to use this pin as input
    ' Send Output to Serial LCD
    '1 VDD
    '2 GP5/T1CKI/OSC1/CLKIN
    '3 GP4/AN3/T1G/OSC2/CLKOUT
    '4 GP3/MCLR/VPP
    '5 GP2/AN2/T0CKI/INT/COUT/CCP1
    '6 GP1/AN1/CIN-/VREF/ICSPCLK
    '7 GP0/AN0/CIN+/ICSPDAT/ULPWU
    '8 VSS
    __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF
    Include "modedefs.bas" ' Mode definitions for Serout
    ' Alias pins
    LCD Con 0 ' Alias GPIO.0 to Serial LCD
    ' INIT global variables
    SwitchNum Var Word
    ' Function Registers Setup
    ANSEL = 0 ' Disable analog A/D functions
    CMCON0 = 7 ' Analog comparators off
    TRISIO = %00001110 ' GPIO.1,2,3 inputs - others outputs - and GP0 feeds LCD
    GPIO = 0 ' Flush GPIO
    ' MAIN PROGRAM
    mainloop:
    Serout LCD, T9600, ["?c0"] ' Turn off flashing cursor
    pause 50
    Serout LCD, T9600, ["?f"] ' Clear screen start at leftmost cell
    pause 50
    Serout LCD, T9600, ["READY"]
    DO WHILE (1)
    SwitchNum = GPIO & %00001110 'Capture GPIO(1,2,3) binary value
    SwitchNum = SwitchNum >> 1
    Serout LCD, T9600, [#SwitchNum]
    Pause 50
    LOOP
    Goto mainloop ' Do it forever
  1. SEROUT 12F683 and GPIO.5
    By AvionicsMaster1 in forum General
    Last Post: - 4th April 2013, 22:58
  2. 12F683: I change GPIO.5 but GPIO.0 also changes...why?
    By chicowoodhill in forum mel PIC BASIC Pro
    Last Post: - 4th December 2012, 17:09
  3. Replies: 2
    Last Post: - 24th February 2011, 01:35
  4. 12F683 GPIO.3 problem
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 30th October 2009, 08:43
  5. Configuring the GPIO.3/MCLR Pin
    By CocaColaKid in forum mel PIC BASIC Pro
    Last Post: - 30th July 2004, 17:00
