+ Reply to Thread
Results 1 to 2 of 2
Thread: QR Code encoder
    Italy
    Default QR Code encoder
    Does anyone knows how to create a QRCode encoder (at least for QRCode Level 3), or how to translate the Arduino libraries to PBP from the following link?
    https://github.com/ricmoo/QRCode/tree/master/src
    It should be used with a PIC18F family.
    The Arduino library is writed in C and it use pointers and array's pointers... and I'm lost.
    Any clue?
    Thank you.
    Sep 2009
    Default Re: QR Code encoder
    Interesting...
    It doesn't look too easy. But it could be done.
    Arrays and pointers are used almost same way as in PBP.
    But I would suggest to store table data in ASM so it would use much less space.
    4 rows with 40 bytes, are same as one array with 160 bytes(word) long. Instead 2 pointers like here numBlocks = NUM_ERROR_CORRECTION_BLOCKS[ecc][version - 1];
    You can use something similar to this:
    ecc=0 to 3
    version=0 to 39
    Pointer=ecc*40+version
    But you may drop unused 3 rows if you fix Error correction level to one level. So you get only one array with 40 word in it.
    Also if you chose only numbers or text, you can remove more unnecessary stuff...
  1. Absolute encoder with Petherick code
    By stojakovicv in forum mel PIC BASIC
    Last Post: - 1st April 2016, 16:36
  2. Keeloq Encoder example code
    By Ioannis in forum General
    Last Post: - 11th November 2015, 08:58
  3. Convert Rotary Encoder Code from 16F628A to 16F1825
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 7th June 2012, 04:34
  4. encoder wowes
    By wallaby in forum mel PIC BASIC Pro
    Last Post: - 6th December 2005, 21:56
  5. Quadrature Encoder
    By Plasmajocky in forum mel PIC BASIC Pro
    Last Post: - 17th June 2004, 17:35
Members who have read this thread : 15
