Doing something at predefined amount of steps?
+ Reply to Thread
Results 1 to 26 of 26
    Default Doing something at predefined amount of steps?
    Hello and sorry for bogus title, I just can't explain it simpler in short terms
    The idea is as follows, there is a variable, incremented from 1 to say 1000.
    There is something to be done in each 5, 19, 23, 49 or whatever step of that variable.
    On ZX Spectrum, I was using thing like: IF I/21=INT(I/21) THEN xxxx
    Here we don't have floating math, so trick with INT won't work. So I came up with the following solution - inside the main variable loop, there's another helper variable, which is incremented by 1, along with main variable. When it reaches predefined value - say 84, we do the thing we have to do, and also reset that variable, so count starts again.
    Are there other ways of doing that more simple?
    Default Re: Doing something at predefined amount of steps?
    I think what you're looking for is the modulo operator (//).
    It will return the remainder of a division so whenever it returns 0 it means it was an "even division".
    MainCount = MainCount + 1
    IF MainCount // 5 = 0 THEN  ' Do something every 5th count
       GOSUB Task1
    IF MainCount// 19 = 0 THEN   ' Do something every 19th count
       GOSUB Task2
    Something like that perhaps.
    Thanks! this is way better and simpler. Speaking speed-wise, will this be faster in execution than my code with additional variable?
    I don't know for sure but since it involves division my guess is that this is slower. Speed isn't always everything though.
    Tell you what, why don't you try both ways and measure the difference, that way we might learn something and/or figure out an even better way.
    EDIT: Just tried it, the modulo aproach is about an order of magnitude slower.
    EDIT2: And that's with a WORD sized variable. If using a BYTE sized variable the modulo aproach is pretty much the same while "the other method" is yet again reduced to about 1/4 or roughly 40-50 times faster than the math intensice modulo aproach.
    Aug 2003
    Australia
    Wasn’t it just something like this?
    not even timing of course because every fifth iteration takes slightly longer to execute, but could be balanced up if it mattered.
    variable var word
    something var word
    for variable = 0 to 1000
    'do the first thing
    something = something + 1
    	if something > 4 then
    	something = 0
    	'do the second thing as well
    next variable
    Yes, I meant exactly that one.
    In my case, there will be 16F886 running at 8mhz and maximum frequency will be around 2khz, so I guess, modulo variant will also work. Will assemble test circuit tomorrow and measure speeds.
    Oh and by the way, currently I don't have access to machine with PBP, what will happen if C=A-B and B is > A ? all variables are word length. I need to determine difference between A and B, but sometimes B can be greater then A, so have to invent something
    It will wrap around, 0-1=65535 provided the variable where the result is stored is a WORD.
    How about For..Next...Step
    George
    Thanks Henrik, so Say A=200 B=300, C in this case will be 65535-100=65435, right? So if I take 65535 and minus it result, I should receive correct difference between A and B, right?
    How about For..Next...Step - this won't work, since there are several actions which had to be done at various steps of main variable.
    No, 200-300=65436.
    65435 is -101 in two's complement because 65435+101 = 65536 which, when being truncated to 16 bits is 0.
    If what you want is the difference between the two numbers while not caring which one is bigger or smaller just use the ABS operator.
    A = 200
    B = 300
    C = ABS(A-B) ' C will now be 100
    Aug 2003
    Australia
    for the sign, so long as a & b are the same variable type:
    if (a - b) > a then
    sign = 1 ' result will be negative
    sign = 0 ' result will be positive or zero
    or something similar to what ABS would have to do behind the scenes:
    a var byte
    b var byte
    c var byte
    sign var bit
    a = 10
    b = 20
    if (a - b) > a then
    c = a - b
    if sign = 1 then
    c = $ff - c ' fix the abs value
    'result is sign,c ... or negative 10.
    I'm slowly advancing in this task Here you can see video filmed from slider itself, and video how slider operates (on this video it is running 20x faster than during filming).
    (Some jerking is due to youtube issues, original video is all fine)
    So now I come to "programming" part - where I move slider into start position and set head as needed, record that position and then move it to end position and record settings again. This part of software is done and I'm writing directly to eeprom, so data can be re-called on next boot. Now I have to "play" recorded data back. I see it in the following way:
    Logic:
    1. Measure position readings for both axes at beginning and end, and based on this, calculate number of steps needed on each axis
    2. determine amount of steps on which axis is larger
    3. Divide larger number of steps by smaller, to determine skip value
    4. Make loop with length of longer axis, which gives single pulse on each loop turn for that axis, and skips calculated number of steps to deliver required number of pulses on shorter axis.
    Here is "code" for it, have not tried it yet, since no PBP on this machine, but I'm having feeling, that something is wrong here....
    GOSUB CALCULATOR' This is routine which reads ADC values and returns number of steps in X and Y variables. (already done)
    IF X>Y
    THEN   'DETERMINE WHICH STEPS ARE MORE and make Z equal it and make W equal to less
    Z=X 'Z=more steps
    W=Y 'W=less steps
    Z=Y 'make loop walk more steps which is
    W=X
    E=Z/W 'determine how much is difference
    FOR A=0 TO Z 'LOOP FOR MAKING STEPS
    If X>Y 'need to make step on the correct lane
    Then Gosub PULSEX 'this subroutine makes single step on X axis
    Gosub PULSEY 'this one - on Y axis
    Endif
    'now make pulse with skipping on 2nd axis, based on modulo operation
    IF A//E=0 and X>Y then GOSUB PULSEY
    IF A//E=0 and Y>X then GOSUB PULSEX
    next
    Sep 2009
    Logic look good to me.
    But you have very inefficient part of code...
    This 2 line generate more than 400bytes of code, and it is really slow to execute.
    If you define one more word or long variable, you can get more than double speed of execution with exactly same output. Here is example.
    tmp=A//E 'Calculate mod only once
    if Tmp=0 then check only once if it is zero
        if X>Y then 'if it zero, check is X>Y
              GOSUB PULSEY
        else 'or if Y<=X, your code doesn't do anything if it is =
              GOSUB PULSEX
    Compile do 257bytes.
    It works, but not exactly, the problem is that ADC readings are not linear, so using predefined number of steps does not work, need to read adc constantly and adjust steps based on it.
    Can't Select case help?
    So currently I have the following conditions.
    Slider movement from edge to edge (30cm) is 100 readings from ADC - value changes from 300 to 400.
    Head rotation (it can do 720 degrees) is 800 readings from ADC - value changes from 100 to 900.
    So for one step on slider, I have to do 8 steps on head.
    Now I'm adjusting code based on that.
    Does this come close to what you want?
    SELECT CASE slider_adc
        CASE 300
                    SELECT CASE head_rotation
                        CASE 100
                            do_this1
                        CASE 200
                            do_this2
                    END SELECT
        CASE 310
                        CASE 300
                            do_this3
                        CASE 400
                            do_this4
                    END SELECT
        CASE ELSE
                    anything_else_here_(optional)
    END SELECT
    I run into different problem now - division by 0 returns 65535. Is this normal?
    SPOS1=550
    SPOS2=600
    RPOS1=550
    RPOS2=550
    SLEN1=ABS(SPOS1-SPOS2)
    RLEN1=ABS(RPOS1-RPOS2)
    IF RLEN1/8>SLEN1 then 'if rotator movement is more than slider
    MOVE1=RLEN1/8/SLEN1 'then coefficient equals to   rotator divided by slider
    MOVE1=SLEN1/(RLEN1/8) 'else coefficient equals to slider divided by rotator
    LCDOUT $FE,$01,"sl ",#SLEN1, " rl ", #RLEN1
    lcdout $FE,$C0,"coeff ",#MOVE1
    With above values, MOVE1 becomes 65535, why?
    Division by zero is a meaningless operation. Its result is undefined.
    What does your calculator do when you try to divide by 0? What should it return?
    Division by 0 returned 0 in good old times, and I was hoping for same here, but no problem, adding another IF-THEN fixes that.
    Another question, going on business trip with my laptop, so I will be doing nothing for about 16 hours, which I hope to use for working on this firmware. Are there any freeware, easy to use simulators which can simulate 16F886 with 1602 LCD attached and couple of buttons, leds and ADC input? I
    Free, I do not think so. Cheap yes...
    http://www.oshonsoft.com/pic.html
    Write it your self's....
    EN82fn
    Downloaded trial of that PIC simulator - it appears to not be working, I mean I can load hex, run it, I see instructions cycling, but no led blinking, no LCD is outputting anything....
    Also downloaded trial of Proteus - this is mega huge, still haven't figured out how to simulate
    Just did a quick test on the demo version of PICSimulator.exe with the attached hex file. This program was built for 16F84 and the whole basic code is this:
    led var portb.0
    start:
    high led
    low led
    goto start
    test.HEX.txt
    It is simulated just fine, toggling portb.0.
    I guess you did not waited long enough for the initialization of the LCD. It takes time. Long time. You can speed it up a bit by Ctrl+F6, but this leads to not showing "real time" port changes.
    Best result if you write the program in the PIC simulator editor with the Oshon's basic version. This way you will see the basic commands executing.
    Thanks a lot! it was really time issue, I did not expected it to take so long to show something I waited about 20 seconds and LCD shows text now and led also blinks.
  1. Hserin amount
    Last Post: - 1st March 2015, 05:32
  2. Replies: 4
    Last Post: - 18th September 2014, 07:59
  3. amount of ram
    By vicce67 in forum mel PIC BASIC Pro
    Last Post: - 5th November 2012, 17:15
  4. how to store a very large amount of data
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 06:05
  5. For...Next loop Steps DEC questions
    Last Post: - 3rd February 2008, 22:57
Members who have read this thread : 21
