varable index buffer setup unsing a varable
Results 1 to 8 of 8
    Feb 2012
    PERTH AUSTRALIA
    Default varable index buffer setup unsing a varable
    been a while since been playing on pbp so be nice
    like to have variable to set the index range for test3 , but not sure how to make it work , works for constants for sure
    test1 var byte
    test2 var byte
    test3 var byte[test1 * test2]
    cheers
    Default Re: varable index buffer setup unsing a varable
    Allocation of memory is done at compile time - not during runtime. Hence the content of a variable can not dictate the size of an array since the content of a variable, by definition, can change during runtime while the size of the array is allocated at compile time.
    You really can't resize arrays at runtime like what you're suggesting/expecting.
    Can you elaborate on what problem is is you're trying to solve?
    Feb 2012
    PERTH AUSTRALIA
    hi hendric
    its an exiting program that uses named constants to set the buffer size , the same named constants are used in multi locations to set other variables and math
    problem is now need to set those named constants to be variables , which is ok for all , except setup the size of array bytes
    i dont want to change all the code just for this issue , but not sure how i can get arround it nicely
    cheers sheldon
    Feb 2012
    PERTH AUSTRALIA
    i can fix the problem by assign the max value used to buffer array , but it just a waist of buffers when they are not needed when the value should be lower than the max number , just goes against the grain
    OK
    Unfortunately, the Linker will reserve memory you claim at compile time. I can only suggest reserve test3 var byte[maximum expected size]. Unless you're scarce on SRAM, it shouldn't matter.
    this may be a possibility i have not got around t trying it, it may need asm support
    i kind of forget the vagaries of pbp labels
    asm var RAM_END is set to last byte allocated by pbp
    Ram past RAM_END and the physical end of memory is unused and could be allocated via the ext modifier
    eg
    buff var byte ext ;allocate a label
    @buff=RAM_END (might need +1 , can't remember); set the label address of unused memory start
    as long as you don't try to index buff past the physical end of memory i don't see any issue
    you should calculate the amount you have first
    Feb 2012
    PERTH AUSTRALIA
    thats interesting thought and approach, maybe worth a look to just see if it works
    thanks richard ,
    i got it a bit mixed up RAM_END is the last physical byte for chip
    so you need to read lst file to see where allocated mem finishes.
    pic18's only of course
    so ...
    buff max size = RAM_END -(addr of highest allocated byte)
    @buff=(addr of highest allocated byte+1)
  1. HSERIN string starting index ?
    By gunayburak in forum mel PIC BASIC Pro
    Last Post: - 4th July 2016, 23:54
  2. strange word varable array results
    By longpole001 in forum mel PIC BASIC Pro
    Last Post: - 26th October 2015, 01:01
  3. Index a bit through a portion of a port
    By ecoli-557 in forum mel PIC BASIC Pro
    Last Post: - 12th March 2012, 23:22
  4. How to index Port variable
    By jpadin1 in forum mel PIC BASIC Pro
    Last Post: - 17th February 2010, 11:36
  5. Access pin using index
    Last Post: - 16th October 2008, 03:34
