PIC16F15355 config setting to work on internal OSC with clock 4MHz
Results 1 to 7 of 7
    Sep 2015
    Question PIC16F15355 config setting to work on internal OSC with clock 4MHz
    Anyone can help about how to realize to make 16F15355 work correctly with Internal Oscillator on 4MHz clock frequency.
    How to adjust config 1 – 5 and other registers to realize that.
    Here is a default configs from 16F15355.INFO file
    MPASM __CONFIG Directive Options
    ; The PBP default configuration for the PIC16F15355 is:
    ; #CONFIG
    ; __config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT32 & _CLKOUTEN_OFF & _CSWEN_ON & _FCMEN_ON
    ; __config _CONFIG2, _MCLRE_ON & _PWRTE_ON & _LPBOREN_OFF & _BOREN_ON & _BORV_LO & _ZCD_OFF & _PPS1WAY_OFF & _STVREN_ON
    ; __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_ON & _WDTCWS_WDTCWS_6 & _WDTCCS_SC
    ; __config _CONFIG4, _BBSIZE_BB512 & _BBEN_OFF & _SAFEN_OFF & _WRTAPP_OFF & _WRTB_OFF & _WRTC_OFF & _WRTSAF_OFF & _LVP_OFF
    ; __config _CONFIG5, _CP_OFF
    ; #ENDCONFIG
    What have to be changed from Available __CONFIG labels for PIC16F15355 from 16F15355.INFO file in above configs?
    Is it necessary to additionally add setting in OSCON1, OSCON2, OSCON3, OSCFRQ, OSCSTAT, OSCTUNE, OSCEN registers ?
    Default Re: PIC16F15355 config setting to work on internal OSC with clock 4MHz
    I do not have this chip but maybe you should do also this:
    OSCCON1=%00000011
    OSCCON2=%00000011
    So you will have a 32MHz/8=4MHz
    You also have the FCMEN_ON which means that if your main clock is not working you will be informed to do something.
    Sep 2015
    Hi Ioannis
    thank you very much, it works !
    OK
    My understanding is that "FCMEN_ON" is only needed with an external oscillator. If it fails, the PIC reverts to INTOSC.
    Also, if you just configure your OSCCON1 for 32 MHZ, you can then select 4 MHZ in OSCFRQ.
    Sep 2015
    Question Re: PIC16F15355 config setting to work on internal OSC with clock 4MHz
    Here are what I did according to Ioannis sugestion:
    In Config word:
    ;HFINTOSC with OSCFRQ= 32 MHz and CDIV = 1:1 - means Int.Osc 32 MHz
    Then I put
    OSCCON1 = %00000011 ' 32 MHz divide by 8 = 4MHz
    OSCCON2 = %00000011 ' 32 MHz divide by 8 = 4MHz
    Do you mean that I have to do:
    And then to define
    OSCFRQ = %00000010 'by HFINTOSC Frequency Selection bits define 4 MHz Osc.Freq.
    DEFINE OSC 4 'tell PBP that the operating frequency is 4 MHz
    To be all correct with HFINTOSC is it FCMEN_ON or FCMEN_OFF
    OK
    FCMEN is the Clock FailSafe Monitor for EXTOSC. If your crystal oscillator fails, FCMEN will revert to INTOSC, for safety sake. If you aren't running EXTOSC, you don't need FCMEN. It probably doesn't hurt having it on using INTOSC, though.
    Sep 2015
    Red face Re: PIC16F15355 config setting to work on internal OSC with clock 4MHz
    Hi mpgmike
    thank you very much on your suggestions and explanations.
    Have a nice time
  1. Replies: 8
    Last Post: - 20th March 2017, 09:34
  2. Internal osc config PIC12F609
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2008, 16:23
  3. Setting up internal clock correctly?
    By JohnM in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 20:29
  4. Internal Osc help
    By BobK in forum mel PIC BASIC Pro
    Last Post: - 12th January 2007, 20:50
  5. 4Mhz osc, pic18f4550 help please
    By ivymore18 in forum General
    Last Post: - 19th August 2006, 07:44
