BME280 sensor.
+ Reply to Thread
Results 1 to 20 of 20
Thread: BME280 sensor.
    Default BME280 sensor.
    Has anyone been able to interface the BME280 temp, humidity and pressure sensor to PBP?
    I've been messing with it for two days. Getting temperature to read correctly (at least I think it is) took a couple of hours but the compensation formulas for the pressure, let alone humidity is about as convoluted as they get and I'm really struggling. They do provide code in the datasheet but no real explaination or formulas.
    Take a look at the fixed point version of the compensation code in the datasheet and tell me if you can figure out what it's doing :-) Like I said, I managed to get temperature working (at least it seems to be, don't know what happens when temp goes negative...) but just look at the code for pressure and humidity, they're using bloody 64bit signed variables, leftshift 47 times, rightshift 33 times...jeeez :-)
    Of course there is Arduino code available but it pretty much copies the datasheet.
    Anyone already done it? Anyone interested?
    EDIT:Link to datasheet
    Default Re: BME280 sensor.
    Yer, the compensation is horrible. Sorry don't have PICBASIC code but do have working code from the dark side.
    George
    i posted this some time ago and the topic seems to have disappeared , i can't remember who's post it was and the context
    but the calcs work but for the ones that need 64bit vars
    ' DEVICE CONFIGURATION
        CONFIG  OSC = IRCIO
        CONFIG  FCMEN = OFF
        CONFIG  IESO = OFF
        CONFIG  PWRTEN = OFF
        CONFIG  BOREN = OFF
        CONFIG  BORV = 20
        CONFIG  WDTEN = OFF
        CONFIG  WDPS = 512
        CONFIG  WINEN = OFF
        CONFIG  PWMPIN = OFF
        CONFIG  LPOL = HIGH           ; PWM0, 2, 4 and 6 are active-high
        CONFIG  HPOL = HIGH           ; PWM1, 3, 5 and 7 are active-high
        CONFIG  T1OSCMX = ON          ; Low-power Timer1 operation when microcontroller is in Sleep mode
        CONFIG  MCLRE = OFF
        CONFIG  STVREN = ON           ; Stack full/underflow will cause Reset
        CONFIG  LVP = OFF             ; Low-voltage ICSP disabled
        CONFIG  DEBUG = OFF           ; Background debugger disabled; RB6 and RB7 configured as general purpose I/O pins
        CONFIG  CP0 = OFF             ; Block 0 (000200-000FFFh) not code-protected
        CONFIG  CP1 = OFF             ; Block 1 (001000-001FFF) not code-protected
        CONFIG  CP2 = OFF             ; Block 2 (002000-002FFFh) not code-protected
        CONFIG  CP3 = OFF             ; Block 3 (003000-003FFFh) not code-protected
        CONFIG  CPB = OFF             ; Boot Block (000000-0001FFh) not code-protected
        CONFIG  WRT0 = OFF            ; Block 0 (000200-000FFFh) not write-protected
        CONFIG  WRT1 = OFF            ; Block 1 (001000-001FFF) not write-protected
        CONFIG  WRT2 = OFF            ; Block 2 (002000-002FFFh) not write-protected
        CONFIG  WRT3 = OFF            ; Block 3 (003000-003FFFh) not write-protected
        CONFIG  WRTC = OFF            ; Configuration registers (300000-3000FFh) not write-protected
        CONFIG  WRTB = OFF            ; Boot Block (000000-0001FFh) not write-protected
        CONFIG  EBTR0 = OFF           ; Block 0 (000200-000FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR1 = OFF           ; Block 1 (001000-001FFF) not protected from table reads executed in other blocks
        CONFIG  EBTR2 = OFF           ; Block 2 (002000-002FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR3 = OFF           ; Block 3 (003000-003FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTRB = OFF           ; Boot Block (000000-0001FFh) not protected from table reads executed in other blocks
    ' DEFINEs
        DEFINE    OSC    8                            ' Internal 8MHz
    ' Pin ALIASES
        LED1            VAR    PORTB.0                    ' Orange Lights
        GRNLED            VAR    PORTB.4                    '
        ClockPin        VAR    PORTA.6                    ' IIC BME280
        DataPin            VAR    PORTA.7                    ' IIC BME280
    ' CONSTANTS
        ' --- BME280 Registers---
        BMEADDR            CON    $EC                    ' Chip Address
        ID            CON    $D0                    ' Chip ID (0x60)
        ctrl_hum        CON    $F2                    ' Humidity Control Register
        stat            CON    $F3                    ' Status Register
        ctrl_meas        CON    $F4                    ' Temperature/Pressure Control Register
        config            CON    $F5                    ' Cofiguration
        cal_st_addr        CON    $88                    ' Calibration Start Address
    ' VARIABLES
        FLAG            VAR    BYTE
        IIC_RX            VAR    BYTE[8]                    ' IIC Received Data BME280
       i var byte
        T1            VAR    LONG
        T2            VAR    LONG
        T3            VAR    LONG
        adc_T            VAR    LONG
        var1            VAR    LONG
        var2            VAR    LONG
        T            VAR    LONG
        adc_Tr3            VAR    LONG
    '    T1l1            VAR    LONG
    '    T2r11            VAR    LONG
    '    adc_Tr4            VAR    LONG
    '    T1r12            VAR    LONG
    '    T3r14            VAR    LONG
        t_fine            VAR    LONG
    '    TT            VAR    LONG
    ' INITIALIZE REGISTERS
        OSCCON = %01110000                            ' Set internal osc to 8MHZ
        ANSEL0 = %00000000                            ' Set to Digital PortA
                                            ' -HW RS232 Setup-
    TXSTA = $20   ' Enable transmit, BRGH = 0
    SPBRG = 51    ' 9600 Baud @ 8MHz, 0.16%
    SPBRGH = 0
    BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
                                            ' -HW Timer Setup-
        TMR0H = 0                                ' HighByte of preload value
            TMR0L = 0                                ' LowByte of preload value (the order is important!)
            INTCON.2 = 0                                                ' Clear the flag bit
        T0CON = %10000111                            ' Setup and Enable TMR0 (8.388s)
        TRISA = %00000000                            ' Set ports as outputs (2-4 I/P)
        TRISB = %00000000
        TRISC = %00000000                            ' Set ports as outputs
    CLEAR
    ' PROGRAM Start
        PORTA = 0                                ' Clear PORTA
        PORTB = 0
        PORTC = 0
        IIC_RX = 0
    Init:
        GOSUB P500                                ' Let everything settle
        GOSUB VER_BME                                ' Is the BME280 Connected. Verify
    MAIN:
        GOSUB GETTEMPBME                            ' Get the temperature reading from BME280
        GOSUB P1
        GOTO MAIN
                                            ' Go back to mainloop
    GETTEMPBME:
        'I2CREAD DataPin, ClockPin, BMEADDR, stat ,[IIC_RX]            ' Check to see if busy Converting Measurements, or writing data
        'If IIC_RX[0] != 0 THEN                         ' If not, it should read as 0
        '    GOSUB P100
        '    GOSUB GETTEMPBME
        'ENDIF
    '    DO
    '        IF FLAG.0 = 1 THEN GOSUB P100                    ' If flag is set the BME280 was not ready (Try again)
    '        TOGGLE LED1
    '        I2CREAD DataPin, ClockPin, BMEADDR, stat ,[IIC_RX]        ' Check to see if busy Converting Measurements, or writing data
    '        FLAG.0 = 1
    '    LOOP WHILE IIC_RX[0] != 0                        '
    '    FLAG.0 = 0                                ' Clear Flag
    '    I2CREAD DataPin, ClockPin, BMEADDR, $F7 ,[STR IIC_RX\8]            ' Read Temp/Hum/Press registers
    arraywrite  IIC_RX,[ $55 ,$2F ,$D0 ,$82 ,$D7 ,$90 ,$85 ,$A6 ]
        for i=0 to  6
        HSEROUT[hex2  IIC_RX[i],","]
    next
        HSEROUT[hex2  IIC_RX[i],13,10]
    '    GOSUB P1
        adc_T.Byte0 = IIC_RX[5]                            ' Store Raw Temerature data
        adc_T.Byte1 = IIC_RX[4]
        adc_T.Byte2 = IIC_RX[3]
    '    GOSUB P1
        adc_T=adc_T >> 4
        var1 = ((((adc_T >> 3) - (T1 << 1))) * (T2)) >> 11
        var2 = (((((adc_T >> 4) - (T1)) *((adc_T >> 4) - (T1))) >>12) *(T3)) >>14
        t_fine = var1 + var2
        T = ((t_fine * 5) + 128)>>8
        HSEROUT["T " ,#T/100,".",#T//100,13,10]
    VER_BME:
    '    I2CREAD DataPin, ClockPin, BMEADDR, ID ,[IIC_RX]            ' Read the BME's ID
    '    IF IIC_RX[0] != $60 THEN ERROR2                        ' Cannot Connect to the BME280
    '                                        ' -Read Calibration Data for Temperature-
    '    I2CREAD DataPin, ClockPin, BMEADDR, cal_st_addr ,[STR IIC_RX\6]        '
    arraywrite  IIC_RX,[$6C ,$6E ,$77 ,$66 ,$32 ,$00]
    for i=0 to  4
        HSEROUT[hex2  IIC_RX[i],","]                        ' Display -> 6C 6E 77 66 32 00 0D 0A
    next
        T1.Byte0 = IIC_RX[0]                            ' Calibration data into Unsigned Word
           T1.Byte1 = IIC_RX[1]
        T2.Byte0 = IIC_RX[2]                            ' Calibration data into Signed Long
           T2.Byte1 = IIC_RX[3]
        T3.Byte0 = IIC_RX[4]                            ' Calibration data into Signed Long
           T3.Byte1 = IIC_RX[5]
                                            ' -Initialise the Sensor-
    '    I2CWRITE DataPin, ClockPin, BMEADDR, config ,[%10101000]        ' Config Setting (1000ms Standby, IIR Filter @ 4)
    '    I2CWRITE DataPin, ClockPin, BMEADDR, ctrl_hum ,[%00000010]        ' Humidity Setting (x2 Oversampling)
    '    I2CWRITE DataPin, ClockPin, BMEADDR, ctrl_meas ,[%01001011]        ' Temp/Pres Settings (x2 Oversampling, Normal Mode)
    '    GOSUB P250
    ERROR1:
        DO
            TOGGLE LED1                            ' Flash the Orange LED every 1/2 second
            GOSUB P500
        LOOP
    ERROR2:                                        ' BME280 Connection Error
        LED1 = 1
        GOSUB P250
        LED1 = 0
        GOSUB P250
        LED1 = 1
        GOSUB P250
        LED1 = 0
        GOSUB P1
        GOTO ERROR2
    P100:
        PAUSE 100                                ' Just a pause..
    P250:
        PAUSE 250                                ' Just a pause..
    P500:
        PAUSE 500                                ' Just a pause..
    P1:
        PAUSE 1000                                ' Just a pause..
    I wonder what was thinking the team that designed that sensor...
    Anyway maybe this can be of some help
    http://dt.picbasic.co.uk/CODEX/N-BitMath
    Thank you Richard!
    I see you too got the temperature conversion covered but not pressure and/or humidity which is where I'm currently got stuck. Haven't done anything with it for a couple of days, perhaps I'll get back to it - or I won't.
    Ioannis,
    Yes, I know about the N-bit routines and if I don't succeed in getting the "native" 32bit fixed point routines they do show in the datasheet to work I might try with N-bit but I suspect it won't actually make it much easier.
    Right now, my guess is that the problem has to do with me niot be able to "translate" their mix of signed and unsigned numbers of various bit lengths into PBP lingo.
    I'm reading the compensation values from the sensor and "manually" casts them into LONGs in order to make them signed. But then not all of them are supposed to BE signed but in PBP all longs ARE signed and it becomes a mess quite quickly. It would be nice to have set of input values with a known output so one could split the calculation in steps and figure out where it goes wrong.
    Does anyone have a BME280 sensor laying around?
    Can you read the compensation values and post them?
    I think I've now got pressure working as well but I'm curious to know another sensors comp values :-)
    henrik here is a json dump from my nodemcu/bme280 regs from 0x80 to 0xff
    {"bme":144,111,137,51,54,42,151,6,185,109,247,104, 50,0,61,148,200,214,208,11,181,32,73,255,249,255,1 72,38,10,216,189,16,0,75,61,0,0,0,0,0,0,0,0,0,51,0 ,0,192,0,84,0,0,0,0,96,2,0,1,255,255,31,78,8,0,0,6 4,183,255,0,0,0,0,5,0,0,0,0,0,0,0,96,0,0,0,0,0,0,0 ,0,0,0,0,0,0,0,0,0,101,1,0,20,43,3,30,189,65,255,2 55,255,255,255,255,255,0,5,12,183,0,0,72,115,224,1 26,150,48,112,242,128} and the highlighted corresponding readings
    {"pressure":1011,"roomt":22.06,"humidity":42,"setpoint":27,"damper":1800,"state":1,"fire":21," bv":1340}
    ps
    hope it's ok looks like forum is not json friendly
    Thank you Richard, that did help.
    I've got pressure working as well.
    Temperature is within 0.05°C and pressure is within 1Pa compared to a commercially available BME280 based sensor module.
    I thought I had humidity working although it read about 7% off compared to "real" one but today the difference is 30% so there must be something wrong still.
    Will look at that later and hopefully be able to post some code.
    But geez, these LONG math operatations eats away code space, 8k at the moment.
    There is always the possibility that humidity sensor may not had time to sense the environment. Or the other reference sensor is in a bit different position and gives wrong measures.
    In my experience, humidity sensors are not very trusty.
    Richard,
    Out of curiosity, have you tried the PBP code you posted with negative temperature values?
    The reason I ask is that my temperature compensation code was pretty much exactly like yours but it went belly up as soon as the temperature went below 0°C.
    Reason mainly being the shift operations where potentially negative values (T2, T3 and therfor t_fine) are involved.
    I see you're handling the compensation values quite differently, simply pushing them into the lower 16bits of a LONG no matter if they're positive or negative. With that said, both T2 and T3 are positive in my case, like in yours, but they could potentially BE negative and then I don't think simplt stuffing the "signed short" into the lower 16bits of our LONG will work properly.
    I had to replace the affected shift operations with * and / at quite some cost for the execution time and for any compensation values specified as signed I'm doing this sort of thing:
        ' dig_T2, signed, read to temporary variable and cast to LONG to preserve sign of value
        SHIFTIN BME280_MISO, BME280_CLK, 6, [tmp_W.BYTE0, tmp_W.BYTE1]
            IF tmp_W.15 = 1 THEN
                dig_T2 = -ABS(tmp_W)
                dig_T2 = tmp_W
    sorry no, i never actually used pbp for these sensors after discovering the real potential of esp chips
    if the upper word was set appropriately here maybe that would help , adc_t might need similar treatment but the calculation should be
    then ok ,i think?
        if  IIC_RX[3].7 then
          T2.Byte3=255
          T2.Byte4=255
          T2.Byte3=0
          T2.Byte4=0
        if  IIC_RX[5].7 then
          T3.Byte3=255
         T3.Byte4=255
          T3.Byte3=0
          T3.Byte4=0
    then ok ,i think?
    nah, pbp needs a signed shift right command too. too hard me thinks. pic chip in bin, esp wins
    For anyone who are still interested in using this sensor with PBP I've posted my code as an example in the Wiki:
    http://www.picbasic.co.uk/forum/cont...BME280-Example
    If any questions or suggestions should pop up I suggest we keep them in this thread.
    excellent work henrik, way better than my fp attempt [nearly 10k in size] to get a result.
    i confirm it gets same results temp and pressure wise as arduino calcs for same input data
    not tried hum yet
    henrik
    i made a little change
    used this style
    IF P2.15 = 1 THEN
    p2.highWORD = 65535
    for all the casts to long , it saves a worthwhile bit of code space
    can't test humidity on pic yet , just discovered the dishonest ebayer has sold me 4 out of 5 bmp280's in lieu of bme280 boards.
    i can't tell them apart with naked eye, must admit the temp seems more accurate in absolute terms for the bmp boards there is nearly a 3 deg difference between bme and bmp readings in the same aircon'ed room and thats closer to the mercury bulb . are cheap ebay things always a bit dodgy?
    "are cheap ebay things always a bit dodgy?" not in my experience, most seem surprisingly interested in protecting their feedback score. Try email seller thro ebay and explain the mistake.
    George
    did that , even though i have had the boards for 2 months or more , got a full refund within a couple of hours.
    quite surprised in a good way
    Richard,
    Your change to the "cast routine" saved some 400bytes worth of code space and probably also executes faster. Thanks!
    Yeah, both of my sensors reports temperature which I believe to be 2-3°C above actual. I don't know if it's due to self heating of the sensor itself, the PCB assembly or something else but the fact that they run different code but both reports values very close to each other makes me fairly confident in the code.
    Just now when I started it up again, the humidity reading was way high, around 70%.
    A restart fixed it and it's now around 42% which is more inline with the other sensor. This seems to happen now and then and I'm not sure what's going on.
    Amazing piece of work by both of you! Thanks a lot for sharing!
    seems possible , the fact that the bmp ver is less "hot" tallies with its lower power use [hum sensor nearly doubles the consumption]
    my esp code uses forced mode letting it sleep between readings and fares no better anyway, so maybe it is what it is
    data sheet says writes to config reg 0xf5 may be ignored if device not in sleep mode, maybe por does not always achieve that.
    cannot say i have seen any issues with humidity readings from esp code.
    the pressure readings are consistent within 2hpa spread across the chips i have
    i find just reading the config reg 0xf5 can cause the device to stop responding completely some times
  1. MQ-7 Sensor
    By chipmaker in forum General
    Last Post: - 9th June 2017, 01:05
  2. Speed Sensor Anyone???
    By Ramius in forum General
    Last Post: - 18th May 2012, 05:37
  3. Pir Sensor
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 20th May 2009, 17:34
  4. Accelerometer Sensor
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 27th August 2008, 14:26
  5. Replies: 6
    Last Post: - 18th January 2008, 09:17
