with the pic16f628a off, a voltage on an1 comes out from main voltage pin, why?
+ Reply to Thread
Results 1 to 24 of 24
    Default with the pic16f628a off, a voltage on an1 comes out from main voltage pin, why?
    with the pic off (no power) the voltage applied on an1 (a battery) comes out from the vcc pin, i don't understand why...
    Default Re: with the pic16f628a off, a voltage on an1 comes out from main voltage pin, why?
    Because the I/O-pins have protection diodes going to Vdd and Vss:
    thank you Henrik, how can i avoid it?
    Jan 2006
    Istanbul
    You may have PNP transistor between ANpin and battery + pin.
    When there is no power, PNP transistor blocks the way. When the power is ON, battery voltage gets through PNP transistor.
    But, you will have a a V drop on battery voltage.
    You may use a PCH mosfet to reduce the voltage drop.
    I would not put any voltage on the PIC inputs with no power on the the chip itself. Strange things can happen with the most obvious to run the program unintentionally.
    There is danger to destroy the protecting diodes too if the load is too high.
    Why do you have that voltage appear on the PIC inputs?
    i need it for monitoring a battery (4 volts) with the comparator
    And your circuit happens to have no power when battery is still connected to an input?
    Quote Originally Posted by sayzer View Post
    emitter on + battery, collector on anpin and the base?
    the problem is that the circuit disharge the battery when the power is off, cause the voltage of the battery flow on the vcc pin of the pic, where there are many leds connected, they of course absorbe current
    I still cannot understand why your battery is still connected to an1 input while your PIC is not powered.
    Nov 2007
    West Covina, CA
    Use a low ON resistance P-CH like was suggested that is controlled with your program.
    Here's what I did to switch the battery input to keep that from happening and to reduce the over all Sleep current:
    Name:  AD switch.JPG
    Louie
    I think MOSFETS have higher leakage current than say a BC85x series transistor.
    I did something similar using SMD version of the known BC557/BC547, the BC8xx series with very good results. More or less the same circuit as Louie showed.
    Nov 2007
    West Covina, CA
    Thanks for the tip Ioannis.
    Am always looking to improve circuit performance, I'll check these out.
    Louie
    Jan 2006
    Istanbul
    Here you have two methods.
    Method - 2 may not work correctly; it is something like "egg from chicken or chicken from egg? which one is first" issue.
    But you get the idea here.
    Method-1: When the pic is powered on, it will make a pin high to drive NPN transistor.
    Method-2: When there is no power on PIC Vdd pin, NPN transistor should be OFF. But it may catch some leaks from the circuit and turn on anyway:; it may need some improvement around it. Or it may work just as you need.
    cause the battery serve a real time clock, the pic is off most of the times. It's on only when i start the circuit with the multi matrix led display, but i switch it off in the nights.
    Sep 2009
    Why you don't connect A1 after switch?
    i'll try them on a breadboard tomorrow, cause i have the bc327 and 237 in my drawers, thanks
    Jan 2006
    Istanbul
    Quote Originally Posted by lutherblisset View Post
    There is a PCH mosfet; Diodes DMP3098L.
    If you use this one instead of BC327, then you may use 100K resistor instead of 10K.
    Thus, current drawing gets super low.
    But, first, just test the idea if it works as you need; you can then play with the current.
    for pedja089:
    cause i use the comparator for catch the moment when the battery goes under the 3 volts (this happened only after many months cause the rtc absorbe only a few uA) but the pic is fantastic for this, although there are external comparators like the lm339 or 311 if i remember....
    Jan 2006
    Istanbul
    There are other ways to get batt low signal with 628A.
    You can have a diode for Vref, around 0.4-0.6V; feed this vref into PIC's comparator. 1N4148 is perfect for this. Have 56K resistor from Anode to Pic VDD. Anode will give you Vref point. Cathode goes to GND.
    and have a resistor divider from Batt+ with large resistor values ( to draw uA); and feed this into comparator again.
    When the battery voltage gets lower than 3V, resistor divider should give you a voltage below Vref (say 0.4V).
    Then you have the COut signal.
    interesting, i will try this method too
    Does the same battery power the PIC also? Or you have another bat?
    i use the battery only on the rtc (this can be a problem why if the pic is switched off it can't calculate legal-solar hours change....)
    ok, since you have two power sources, your options are:
    1. The circuits above with transistors etc contrlled by the PIC itself.
    2. None of the above, just count a year or two and ask the user to change the battery.
  1. Replies: 8
    Last Post: - 21st March 2015, 17:21
  2. Replies: 7
    Last Post: - 22nd January 2012, 04:50
  3. pin voltage while programming
    By ruijc in forum General
    Last Post: - 4th July 2011, 01:17
  4. HELP !!! How change the voltage of a pin ????
    By stormdacta in forum mel PIC BASIC Pro
    Last Post: - 21st August 2007, 20:55
  5. Voltage output from PIC16f628A
    By bennamanna in forum General
    Last Post: - 13th November 2006, 04:18
Members who have read this thread : 18
