Pickit3 -- hate the friggin thing
+ Reply to Thread
Results 1 to 8 of 8
    Default Pickit3 -- hate the friggin thing
    Life was so easy with my old parallel port programmer.
    Using Pickit3 -- did everything right I think. MPLAB and the IPE are installed. 16F628A is installed correctly (not in a circuit but the zif socket)
    IPE loads fine -- communicates seemingly but get error message
    "Target device was not found (could not detect target voltage VDD). You must connect to a target device to use PICkit 3."
    Please -- would appreciate any leads on what's wrong. Driving me NUTS. --thanks
    Default Re: Pickit3 -- hate the friggin thing
    I think it may have to do something with "power target from Pickit3" ? but don't see an option for that ?
    using IPE V5.15
    ok found that option "power target from tool" but now get this error --
    PICkit 3 is trying to supply 5.000000 volts from the USB port, but the target VDD is measured to be 4.625000 volts. This could be due to the USB port power capabilities or the target circuitry affecting the measured VDD.
    The target circuit may require more power than the debug tool can provide. An external power supply might be necessary.
    Connection Failed.
    what a piece of shite as you say in the uk
    Ok -- got it figured out. seems whenever I post, the answers come.
    QUESTION --
    I had to set the programming voltage to 4.875. Seems to work ok. Is this typical? Any issues with that?
    Way too much of a learning curve with this Pickit
    Yes, I've found that pretty typical. You might not have exactly 5.000V at the USB port of the computer then you have a 1.2m (or whatever) long USB Cable introducing some voltage drop and then you have the voltage drop over regulator circuitry itself (which apparently isn't capable of boosting the voltage) in the PICKit3. So the PK3 can't supply 5V to the target if what it gets on its input is "only" 4.9V - simple as that. Just set it to 4.5 or something.
    You can integrate IPE into MCSP if you want, one click compile and program.
    I have always found with both Pk2 and Pk3 it's much safer to externaly power the device under test (bear in mind USB 2 will only supply 100mA)
    George
    I had enough with the IPE/MPLABX crap...
    Found an alternative to good ol' Stand alone Pickit2/Pickit3 software that was abandoned.
    A programmer developed in a basic variant the new/old Stand Alone IDE that is great and I use it all the time.
    You have to send to Evan (the creator) a small donation to give you a download link and I find it fair enough.
    Link is this http://www.pickitplus.co.uk
    His support is immediate also by emails.
  1. Pickit3 ordered -- what else?
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 5th September 2016, 21:49
  2. pickit3 trouble PLEASE
    By l_gaminde in forum mel PIC BASIC Pro
    Last Post: - 20th February 2016, 23:06
  3. Not getting this timer thing.
    By Szczepaniec in forum mel PIC BASIC Pro
    Last Post: - 29th July 2011, 18:50
  4. Nubie - 2 Pics doing the same thing
    By sparky88 in forum mel PIC BASIC Pro
    Last Post: - 26th February 2008, 01:07
  5. Replies: 5
    Last Post: - 20th August 2006, 23:09
Members who have read this thread : 25
