CCP and timers to capture frequency
Results 1 to 4 of 4
    Feb 2008
    Michigan, USA
    Default CCP and timers to capture frequency
    Related to , but different aspect, of "PPS understanding on 16F15313"http://www.picbasic.co.uk/forum/showthread.php?t=24129. Figured a new thread naming the issue would be better.
    This system receives pulses between 0 and 250Hz. I need to distinguish when it crosses above 45Hz and derive a count that I can use to generate a PWM based on the measured frequency. I don't need to measure below that frequency, just set a flag, so that the Main can still pulse when it has a capture. Basically, it monitors ECU tach pulses and each pulse generates a pulse out, no matter the frequency. Above 45Hz, it synthesizes an output that is related to pulse speed, but is not linear, so it must be generated.
    Still not understanding of why I'm getting quite an unstable timer capture.
    The thought is to let TMR1 roll over and check those (Overflow) and grab the remainder. If the preload is set so that it overflows below 45Hz, I can just ignore anything that overflows, and if no overflow, use the remainder to determine frequency in. I have not applied the preload of 22063 yet to TMR1 (1:1) as I can't even get it to read with any stability yet. Getting 0-2 overflows @45Hz and remainder all over the place. If this is this fragile in the striped down form, there's no way I'm going to be able to add needed code for the rest of it.
    If you eagle-eyed members can see my error, or have a different way of doing this, I'd love to hear it.
    Thank you
    bo
    '*  Name    : 324_CCP1_Test.pbp                                 *
    '*  Date    : 09/30/20                                          *
    '*  Notes   : TEST  using PPS and CCP1                          *
    '*THIS REV:  timing erratic
    INCLUDE "DT_INTS-16F18xx.bas"  ; v1.20 Modified for 16F183xx: IOC INTs added for each pin.
    INCLUDE "ReEnterPBP.pbp"    ; Include for DT_INTS.  ver 3.4
    DEFINE OSC 8
    PulseIn     var PORTC.5  ' Monitor ECM tachometer signal
    PulseFlag   var byte       ' register if CAPTURE Int was entered
    Overflows   VAR word    ' count the times TMR1 overflows
    Remainder   VAR word    ' remaining TMR1 ticks after last overflow
    ANSELA = 0                  ' Set all digital
    ANSELC = 0
    CCP1CON = %10000101     ' On, Capture every + edge
    CCP1PPS = 00010101         ' set CCP1 input to RC5
    'CCPTMRS = %01010101     ' ALL CCPS using TMR1 (already default)
    'INTCON = %11000001
    OSCEN  = %01000000       ' HFINTOSC ENABLED
    OSCFRQ = %00000100      '  100:8mhZ, 101:12MHz, 110:16MHz
    PORTA  = %00000000        ' Outputs
    PORTC  = %00100000       ' Outputs except RC5 for Tach In input
    TRISA  = %00000000        ' Pins output
    TRISC  = %00100000        ' Outputs except RC5 for Tach In input
    T1CON  = %00000001       ' 1:1 prescale, clock=Fosc/4, TMR1=on
    T2CON  = %00000100       ' 1:1 PRE and POST, ON
    '********* USART  ****************************************************
    DEFINE HSER_RCSTA 90h   ' Set receive register to receiver enabled
    DEFINE HSER_TXSTA 20h   ' Set transmit register to transmitter enabled
    DEFINE HSER_BAUD 9600   ' Set baud rate
    DEFINE HSER_SPBRG 25    ' Set SPBRG directly
    HSEROUT ["324_CCP1_test",10,13]
    pause 2000
    ;----[Interrupts]----------------------------------------
    INT_LIST  macro    ; IntSource,   Label,   Type, ResetFlag?
            INT_Handler   CCP1_INT, _Capture,   PBP,  yes        ; WORKS
            INT_Handler   TMR1_INT,  _Timer1,    PBP,  yes
        INT_CREATE               ; Creates the High Priority interrupt processor
    @    INT_ENABLE  CCP1_INT    ; enable Capture interrupts
    @    INT_ENABLE  TMR1_INT    ; enable Timer 1 interrupts
      IF PulseFlag = 1 THEN
    '     PULSOUT tachdrv, 50      '
         HSEROUT ["OF= ",DEC Overflows,"  ,Ticks= ",DEC Remainder, 13,10]
         PulseFlag = 0
         Overflows = 0
         PIR1.0 = 0               ' clear TMR1IF
        HSEROUT ["NoFlag", 13,10]
    GOTO Main
    '---[CCP1 - interrupt handler]------------------------------------------
    Capture:  ' Enter here with input Pulse  (CCP1)
        Remainder = TMR1
        PulseFlag = 1           ' set flag to pulse out @ each +capture
        PIR4.0 = 0              ' clear CCP1IF
    @ INT_RETURN
    ''**** TMR *********
    Timer1:
        Overflows = Overflows + 1
    @ INT_RETURN
    Feb 2008
    Michigan, USA
    Default Re: CCP and timers to capture frequency
    I'm trying to base this on Tip #1 from http://ww1.microchip.com/downloads/e...Doc/41214a.pdf, but evidently I'm not turning the suggested steps into code very well.
    my old proteus can't sim that chip but a 16f1825 is ok
    done like this the "remainder" is time between pulses in uS provided overflow is < 2
    '*  Notes   : TEST  using    16F1825                            *
    '*THIS REV:  timing perfect
      __config  _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_OFF & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_ON
      __config  _CONFIG2, _WRT_OFF & _PLLEN_OFF & _STVREN_ON & _BORV_19 & _LVP_OFF
    INCLUDE "DT_INTS-14.bas"  ;
    INCLUDE "ReEnterPBP.bas"    ; Include for DT_INTS.  ver 3.4
    DEFINE OSC 8
    lastcount   VAR word
    ANSELC = 0
    CCP1CON = %00000101     ' On, Capture every + edge
    'INTCON = %11000001
    OSCCON=$70
    T1CON  = %00010001       ' 1:1 prescale, clock=Fosc/4, TMR1=on
    DEFINE HSER_SPBRG 51  ' 9600 Baud @ 8MHz, 0.16%
    SPBRGH = 0
    pause 2000
         PulseFlag = 0
         Overflows = 0
    GOTO Main
        Remainder= TMR1  - lastcount
        lastcount = TMR1
    @ INT_RETURN
    Timer1:
    @ INT_RETURN
    Feb 2008
    Michigan, USA
    Richard,
    I had to change CCP1CON = %00000101 to CCP1CON = %10000101 to turn on the CCP, but it looks like it works a lot better than what I was trying.
    I'll play with it a bit and see.
    Sorry to keep asking questions, I feel like a dolt sometimes... :-)
    bo
  1. Question regarding CCP
    By spcw1234 in forum mel PIC BASIC Pro
    Last Post: - 8th April 2013, 09:55
  2. Replies: 1
    Last Post: - 9th March 2013, 07:10
  3. Capture without CCP
    Last Post: - 28th March 2009, 23:09
  4. use of ccp mode
    By boboco in forum General
    Last Post: - 6th April 2006, 13:58
  5. CCP question
    By jamie_s in forum mel PIC BASIC Pro
    Last Post: - 5th December 2005, 17:08
